Welcome to the North American Subaru Impreza Owners Club Tuesday October 23, 2018
Old 08-26-2006, 08:20 PM   #1
dodiox
Visiting NASIOC Timeout
Member#: 85718
06 WRX
Cobb Stage 2
Default 06 wrx with vf39 and stock intercooler?
I'm getting the vf39 for my car but i was wondering if it would be alright to run it with the wrx stock intercooler and run cobb's map for that turbo.
what kind of power gain differences would i see if i use sti IC and stock IC.
thanks!
dodiox is offline   Reply With Quote
Old 08-26-2006, 08:56 PM   #2
Sypher
Member#: 106366
2006 WRX
no !!!!!!
Sypher is offline   Reply With Quote
Old 08-26-2006, 09:09 PM   #3
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
you will need at least an sti top mount to run that turbo injector and fuel pump will run close a little past 80 % which is recomended duty cycle, best thing to do is get it tuned , now you will hear people say theres always a guy telling you to get tuned and not everybody has the money to get tuned will its not as expensive as things can be if you dont do it right . A good road tune not dyno tune is always pretty cheap as long as you search remember that dyno run can come after a "it feels badass" road tune. No scooby is the same so why would you use a map that is a genearal map .Cobb is awsome but it is only a tool that is awsome when used right and belive me you will save al ot of money in the long run
blue m&m is offline   Reply With Quote
Old 08-26-2006, 09:22 PM   #4
sti234
Member#: 116908
05 STi
at least STI TMIC or maybe some thing bigger than that. You should be better with the bigger TMIC.
sti234 is offline   Reply With Quote
Old 08-26-2006, 09:29 PM   #5
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
yes sir and when you do you have to make sure that it can suck the air out as easy as posible or you can get detnation
Old 08-26-2006, 09:45 PM   #6
deblas66
Member#: 114096
The STi top mount should be fine. The stock IC on the 06 is so ridiculously small that it has to be replaced.
deblas66 is offline   Reply With Quote
Old 08-28-2006, 10:39 AM   #7
Sti"izzle"
Member#: 77879
2005 Saab 9-2x
Artic Silver
Get an Ebay tmic. Bigger than sti intercooler, and a lil cheaper.
Sti"izzle" is offline   Reply With Quote
FS (NC) STOCK STI Injectors, VF39 and Stock Intercooler ///M Power Engine/Power/Exhaust 10 02-20-2009 08:49 AM
GA, Marietta Utec 02-05 wrx non STI and stock intercooler with Y pipe subyxx Engine/Power/Exhaust 0 06-18-2008 01:12 PM
Used utec 02-05 wrx non STI and stock intercooler with Y pipe subyxx Engine/Power/Exhaust 2 06-08-2008 03:04 PM
2002 WRX With VF39 and Stock Fuel scoolbuzz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-02-2006 07:51 AM
06 WRX with VF39 and STi IC? bcristea Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 54 01-23-2006 12:34 PM
