Old 02-21-2011, 04:29 PM   #101
Full-Race Geoff
Member#: 133386
00 too many turbos
white
great info Jeff! Glad to see you experimenting with the EFR's. Thanks also to everyone for the positive feedback on the EFR training guide.. I actually worked quite a bit on that, and wanted to help make it a "modern turbo bible" of sorts for the BW turbos. hopefully you will agree!
PS: i just ordered a set of Perrin PSRS for my new project car, i feel like this:
Full-Race Geoff is offline   Reply With Quote
Old 02-21-2011, 04:32 PM   #102
azn2nr
Member#: 35276
20 degrees side to side. they dont recomend any front to back tilt at all. iirc it says the bearing should be as close to paralell to the ground as possible.
azn2nr is offline   Reply With Quote
Old 02-21-2011, 09:38 PM   #103
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
Jeff so you can have both coolant lines on one side and just plug the other side?
Bariga is offline   Reply With Quote
Old 02-21-2011, 09:48 PM   #104
n2oiroc
Member#: 141952
2023 M340i
Originally Posted by Bariga View Post
Also 7670 and 8374 have same foot print, so you can swap them easy.
im pretty sure the 7670 is the "b" compressor cover and the 8374 is the "c".
n2oiroc is offline   Reply With Quote
Old 02-21-2011, 09:49 PM   #105
n2oiroc
Member#: 141952
2023 M340i
the inlet is supposed to be on the bottom of one side and the outlet on the top of the other side. i suppose since water cooling is optional, both on one side is fine, but i would make sure the inlet is on the bottom.
Old 02-21-2011, 11:20 PM   #106
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
ok well I guess I need to read.
Old 02-22-2011, 12:15 AM   #107
antonch
Member#: 170384
2006 Sti
Sorry to hijack the thread.
Full Race: any plans to offer this turbo with the turbo kits?
antonch is offline   Reply With Quote
Old 02-22-2011, 01:08 AM   #108
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
Not the comp. housing, the footprint of the exhaust housing!
The coolant will travel around the turbo and will exit on top, so it doesn't really matter. I have 2 video cards water cooled in parallel and they both running same temps
Old 02-22-2011, 01:11 AM   #109
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
They already make kits, just not updated on their website, they not doing very good at keeping website up to date
Old 02-22-2011, 02:02 AM   #110
GundamFan
Member#: 212204
Originally Posted by 4orcefed240 View Post
So is the 7670 supposed to be 'comparible' to the 30r and the 8374 to the 35r?
Thats what it seems like.
GundamFan is offline   Reply With Quote
Old 02-22-2011, 02:28 AM   #111
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
30R - 30R GTX - 35R - 7670 - 35R GTX - 8374 this is how i see it so far with out any data lol
Old 02-22-2011, 02:28 AM   #112
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I'm not aware of any such claims from Borg-Warner, but a lot of us are speculating that things are going to turn out that way.
They have similar compressor exducer diameters, so we're guessing that they will probably have similar peak power potential. But we won't actually know until Jeff shows us some numbers.
Old 02-22-2011, 10:52 PM   #113
copec
Member#: 1808
I haven't posted for a while on Nasioc, but I'm very interested in testing these EFR's on subarus and wanted to subscribe
I realize from reading some of his results that Perrin seems to be a very practical engineer but on a side note I would however love to see someone do a custom low mount setup with one of these using TS/IWG in the future.
copec is offline   Reply With Quote
Old 02-22-2011, 11:00 PM   #114
PERRINJeff
Member#: 74110
Same foot print but different hand print.
Compressor housing is bigger diameter and also inlet is 4" versus the 3.5" on the 7670.
Love it!
PERRINJeff is offline   Reply With Quote
Old 02-22-2011, 11:05 PM   #115
PERRINJeff
Member#: 74110
I trie that a while ago on my STI and there is two issues. Radiator/ core support and then putting the dp where the uppipe goes.
The new LGT has a completely different subframe and core support allowing for a low mounted turbo to work easier. I always battle with doing something cool and custom versus something that a customer can also do and or it's something we can make. In this case I think I could gave made something work but it's not something a customer could do or a kit we could make. But someday I might say screw it! I'll just chop the rad support and go crazy!
Old 02-22-2011, 11:06 PM   #116
PERRINJeff
Member#: 74110
One more for the night!
Old 02-22-2011, 11:16 PM   #117
BlkBumperBandit
Member#: 232015
1990 Legacy
aka Red October!
looks like a really tight fit. also looks like a custom down pipe as well. Ive been wondering when someone was going to start playing with these new turbos. Can't wait to see the power figures.
on a side note. Does this mean that other kits will be cheaper now that this turbo is out in the "wild" ?
keep up the good work. i'll be looking forward to the results
BlkBumperBandit is offline   Reply With Quote
Old 02-23-2011, 01:43 AM   #118
azn2nr
Member#: 35276
so serious talk.
jeff, if you get a kit for these turbos put together before, lets say, april. can i just buy an uppipe and downpipe from you?
Old 02-23-2011, 12:09 PM   #119
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
jeff your the man
Old 02-23-2011, 12:22 PM   #120
n2oiroc
Member#: 141952
2023 M340i
jeff your the man
you guys should be the first company to get this turbos instead of full-race, they not doing ****~~
if it wasnt for full-race i doubt these turbo's would exist or at least have the same features they do.
Old 02-23-2011, 12:27 PM   #121
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
well i don't see them posting anything at all
Old 02-23-2011, 12:38 PM   #122
azn2nr
Member#: 35276
@bariga
i thought you had one ordered. with a full race kit?
Old 02-23-2011, 01:02 PM   #123
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
It's likely that Perrin is still fabricating the required pieces to fit this turbo.... jesus you people, have some patience.
OrbitalEllipses is offline   Reply With Quote
Old 02-23-2011, 01:04 PM   #124
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Jeff that picture does things to me that are not appropriate for public discussion
jeff your the man
Since we all know that FR focuses on TS, it should come as no surprise that no testing data has been released.
Personally, I am not going to waste my time or money on a single scroll turbo bigger than a 30r.
AGREED!! Most will not even buy one of these, cannot afford one, or WILL buy one just to ahve it sit for 6 months while they finish the rest of their build
aboothman is offline   Reply With Quote
Old 02-23-2011, 01:17 PM   #125
n2oiroc
Member#: 141952
2023 M340i
well i don't see them posting anything at all, ether the numbers are not impressive so they get more sales or something "correct me if I'm wrong"
they dont have a pile of turbo's to test. supply is very limited and what they are getting they are shipping to their customers.
Borg Warner Registry, post your BW setup & #'s here. UpSideDownDesi Proven Power Bragging 3174 03-07-2021 04:29 PM
Borg Warner S256 and S362 Turbos AXA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 12-01-2015 09:18 AM
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-22-2010 11:50 PM
small borg warner turbo vid. mattjk Off-Topic 13 07-05-2006 04:25 PM
