05-30-2018, 08:13 AM | #101 | |
Member#: 416107
International
Vehicle:2002 WRX Wagon EJ207 Spec C 4EAT |
i would say thats a no because the process of manualizing an automatic is removing and plugging the accumulators with freeze plugs (along with other modifications). since they are not there and the trans still shifts, a broken one would tell me that it’s still possible to select a gear with the shifter.
04-23-2019, 07:33 PM | #102 |
Member#: 151422
BAIC
Vehicle:2005 Impreza T |
I have my set for sale just in case if anyone is interested. It might be the last set in existence!
04-24-2019, 01:50 PM | #103 |
Member#: 13530
NWIC
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
04-24-2019, 09:15 PM | #104 |
Member#: 151422
BAIC
170 shipped
04-25-2019, 06:21 PM | #105 |
Member#: 500805
Vehicle:2009 Impreza Wagon Red |
Resurrecting this, I have an 09 impreza 2.5i wagon with the 4EAT, where can I find a good kit to get better, faster shifts out of it? Am planning on shipping the trans off to level 10 bulletproof trans for a full build on it in a year or two, because of a build I'm doing on the car in the next year or two, but I'd like a better shift feel in the mean time
04-26-2019, 02:06 PM | #106 |
Member#: 151422
BAIC
I would steer clear of Level 10 unless its been revamped. Pistons and trans kit is definitely a must. Let me know, I have a brand new set of pistons for sale.
06-14-2019, 12:43 AM | #107 | |
Member#: 496433
Just put in Ratiotek kit(HD). ITS A MONSTER. My pistons were in perfect shape, but I wish all those ppl from this thread I've messaged, actually answered me... If you send your VB and the kit, we can do it for ~150$. Also recommend to include the 3 small screen filters and the large one. If you have new pistons, we'd throw them in. Wait is yours 4EAT Phase 2 V1 or V2? They're different. On V2 you just need one mod I think. Also when you pull it make sure: 1. Be careful, it'll spill everywhere. Drain it. 2. Take all silver and two long reamer bolts out. 3. Use a pick to disconnect solenoids, carefully. 4. Use brake cleaner and drain pan. There will be TON of ATF. 5. While VB is away, clean the mating surface with razor blade carefully, or with plastic blade, no care required. Clean the pan as well. Magnet, plug, everything. 6. Get new ATF filter if you want at that time. SoA is 32$ NAPA Gold or similar is 9$. 7. Get a fluid transfer pump for the ATF. It won't be easy(on turbo). 8. It will continue to leak throughout the process, just keep cleaning. 9. When it's all in(18.7 Plug 21mm, 3.8 Pan Bolts 10mm, 5.8 VB Bolts 10mm, lb/ft) fill the 2 gallons in. 10. Test the gears 10 sec in each running. 2x. Check fluid level, it'll be on the bottom of cold. Drive 10 min it'll be probably bottom hot. Should be good. Or measure temps. 11. Profit. I'll post this in Ratiotek thread and if people want details HOW to DIY I can post it too. I work on Subaru's a lot, but I took a second seat here to the Pro, who've done those on multiple trannies(not Subaru's). |
08-05-2019, 01:04 PM | #108 |
Member#: 504929
Vehicle:2001 Impreza 2.5RS Pearl Blue |
09-23-2019, 11:46 PM | #109 |
Member#: 151422
BAIC
I do, PM me.
09-24-2019, 10:55 AM | #110 |
Member#: 506711
E. Canada
11-15-2019, 10:45 AM | #111 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
Last call on final set!
12-25-2019, 09:51 PM | #112 |
Member#: 506711
E. Canada
Just PM’d
01-27-2020, 07:01 PM | #113 |
Member#: 511126
BAIC
Vehicle:2003 Impreza Outback silver and gold |
Any more of these floating around?
01-29-2020, 07:06 PM | #114 |
Member#: 131280
BAIC
09-03-2020, 03:04 AM | #115 |
Member#: 317466
South East
Vehicle:2004 wrx blue |
I'm not sure if this is still going but I would very much be interested in a set if there are any still available. I did pm Strider.
09-03-2020, 07:21 AM | #116 |
Member#: 518292
Vehicle:MY05 AUDM WRX 4EAT 1 Owner 38,000Miles |
I want to buy a set of these pistons as well
I will send you a PM |
11-30-2020, 10:21 PM | #117 |
Member#: 514134
Same here, do these fit in a 2011 Forester XT 4EAT?
I am about to send my valve body to IPT. |
12-01-2020, 12:25 AM | #118 |
Member#: 518292
12-05-2020, 01:48 PM | #119 |
Member#: 511126
BAIC
All gone
AFAIK I got the last set, sorry folks
