Welcome to the North American Subaru Impreza Owners Club Wednesday September 30, 2020
Old 09-12-2020, 08:41 PM   #1
Bizarre11
Member#: 196910
Default GR WRX Fuel Stumble
My 2011 WRX is experiencing a stumble at around 2700-3000 RPM. Everything that Iíve researched it seems this is only an issue that pertains to Stiís of this generation. Typical fix is fuel regulator/rails, but again it only references Stiís and not wrx. Has anyone run into the same issue with their GR wrx and were able to fix it?
Car has an IAG block, ID1000 injectors, AEM fuel pump, TGV and air pump delete.
Bizarre11 is offline   Reply With Quote
Old 09-12-2020, 08:50 PM   #2
truck7575
Member#: 516780
2008 Subaru wrx sti
The easiest fix to try is hook the fpr vacuum reference under the throttle body instead at the driver side intake manifold.. Doesnt work for everyone but some.. Also what ive read is the 1000cc injectors have a little more issues than other sizes.. Good luck with this annoying issue
truck7575 is offline   Reply With Quote
