Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 05-27-2014, 10:16 AM   #26
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Pricing, installation directions (more like with which components it may interfere), actual install pics, etc...
I'm wondering if it's like a modified Christen system.
Edit: a re-application of the Christen system's principles, as we wouldn't require nearly as many parts as their inverted system.
Old 05-28-2014, 12:09 AM   #27
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Originally Posted by Homemade WRX View Post
Pricing, installation directions (more like with which components it may interfere), actual install pics, etc... I'm wondering if it's like a modified Christen system. Edit: a re-application of the Christen system's principles, as we wouldn't require nearly as many parts as their inverted system.
I'll have what ^ he's having.
ASF Machine is offline   Reply With Quote
Old 05-29-2014, 05:01 PM   #28
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There's a little more to it vs the Christian system. The Christian system is based on normal and inverted flight; 2-modes. Our unit will have 3-modes of operation; normal (straight), Left, and Right.
Instructions are fairy simple. plumb both heads into this valve, then a single line to the A/O separator or can. Essentially this valve replaced the 'T'. As far as where it goes, it doesn't matter. Firewall, strut tower, intake manifold, etc., would all work just fine. The device will have mounting holes and I'm working on a bracket for GR (that should be an easy retrofit to the GD) mounting to the firewall although it will be for FMIC only. Creative locations will require custom bracketry on the users part. No pics yet, they will come once we've got some testing completed.
See above
KillerBMotorsport is online now   Reply With Quote
Old 05-29-2014, 06:29 PM   #29
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
I will be running dry sump and no breather, so I guess this should not apply. What do you think?
jdogma is offline   Reply With Quote
Old 05-30-2014, 07:39 AM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ No with a dry sump your vents are going to the reservoir. Even better if you've got scavenge stages on each head to keep them from flooding (which is what we recommend). Although we've only seen a need for dry sump on cars running banked oval or circle tracks.
Old 05-31-2014, 03:53 PM   #31
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Wouldn't this be a good solution and not hinder street ablity
Edit, nvm. Just read the rest of the thread
Irv Weissmanhowerton is offline   Reply With Quote
Old 05-31-2014, 04:04 PM   #32
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Was this to make most of us feel inadequate?
Old 05-31-2014, 05:10 PM   #33
jdogma
Member#: 242350
black
Who makes it? Tech details? How much? I am probably going to get one from Dailyengineering unless convinced otherwise.
Thanks, John
Old 05-31-2014, 09:34 PM   #34
Member#: 278519
30r E85 sti 450+whp
kb'izzle
That's who's it is, and far as price it's well worth it and not as much as going through motors
Old 05-31-2014, 11:52 PM   #35
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That is if it works as advertised. Have not used it, but have heard mixed reviews. Research before buying. Not enough stages either IMHO if you run in circles and MUST run dry sump.
Old 06-01-2014, 12:40 AM   #36
jdogma
Member#: 242350
black
Well thank you both for the info and thoughts. I am going to give it a try. We will be road racing, but at least one track we run - Robleing Road near Savannah - is like an unbanked oval with two opposite corners. So wish me luck![IMG][/IMG]
We were running an EZ30R turbo, which we blew at Savannah, and are now having a 2.1L EJ20 built by Joe Hanna at ASF Machine.
John
Old 06-04-2014, 11:03 PM   #37
funk32
Member#: 245787
GD Race Car
This is a great idea, I had this issue twice last year and during one session I lost close to one litre that came out of the catch can.
funk32 is offline   Reply With Quote
Old 06-10-2014, 07:25 AM   #38
The Cowboy
Member#: 302293
Thanks, John
That's the POO, I have the Daily Engineering dry sump and pump and it's brilliant. We've since imported two more for customer cars. Brilliant piece of kit. Instantly solves all breathing problems but it's expensive and probably only for extreme racers.
So this aeroplane breather control thingy will have a much wider appeal and help a lot of people out if it works well.
The Cowboy is offline   Reply With Quote
Old 06-18-2014, 09:20 AM   #39
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
MSRP will be $395 for the '3-Way Vector Valve' (yes that's what we're calling it), and will include the valve and GR or GD mounting bracket for FMIC setups. TMIC will take some creativity on the users end, but shouldn't be too difficult.
Old 06-18-2014, 10:32 AM   #40
lordsanointed
Member#: 301522
2011 WRX
Any pic?
lordsanointed is offline   Reply With Quote
Old 06-18-2014, 11:51 AM   #41
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ not yet. The valve dimensions are roughly 5.38" wide, 2" thick and 3" tall
Old 06-18-2014, 04:35 PM   #42
C.Plavan
Member#: 339703
When do you expect them to be ready for sale?
C.Plavan is offline   Reply With Quote
Old 06-19-2014, 12:10 AM   #43
Wellyea
Member#: 287314
08 Sti
I regularly fly aerobatic aircraft with christen inverted oil systems. No matter what your vent system is going to dump oil at the end of the day. It reduces loss, but we have an abundance of oil to work with, a 12qt engine can still operate on 3 quarts..... But you will notice abnormally high oil temps and land soon.
Wellyea is offline   Reply With Quote
Old 06-19-2014, 08:20 AM   #44
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Absolutely. And I have to say, working with some of you aerobatic and 'experimental' aircraft people is an interesting experience. I thought car guys were nuts
The Christian valves have limitations and work best with inverted flight and non-inverted flight. In-between... well that's were it gets a little bit fuzzy and functionality is compromised, which is why we use multi-pickup dry sump setups on Suby powered aircraft so the pickup point is almost always in the direction of gravity and PCV becomes a non issue.
Fortunately for those of us that prefer our adrenaline served up on pavement, these issues are a non-issue for this type of valve The valve actuates at a certain side load and not when it's below that point. Fluctuations in force due to vibrations, grip levels, tarmac type, etc. (which are the norm) may cause partial activation near the activation point, but the PCV will still vent as needed, and will definitely be closed above sustained levels.
Old 07-02-2014, 07:33 PM   #45
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
Doing mostly autox so I don't need this, but hoping to do more track days. It's great to know there is a viable solution being made if I run into the problem.
WRX8XB is offline   Reply With Quote
Old 07-03-2014, 10:38 AM   #46
C.Plavan
Member#: 339703
Release date?
Old 07-03-2014, 07:35 PM   #47
tekbroker
Member#: 376622
2013 Ford Raptor 6.2
FF5 818R
I am about to rebuild a EJ20 for my FFR 818R and I would definitely include this in my build if you can find a way to take this to market in the next month.
Do you have a release date?
Brando
tekbroker is offline   Reply With Quote
Old 07-06-2014, 04:12 PM   #48
Homemade WRX
Member#: 33782
96 3MI Racing
Before a release date, I'd ask how testing is going...we engineers do that stuff, so I know it will be done before going to market.
Old 07-08-2014, 06:07 PM   #49
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by C.Plavan View Post
Release date?
We are going to have a beta batch finished very soon. After we have solid feedback, with any potential design changes, well post a release date.
Brando
No release date yet. We do have one beta spot open.
Due diligence comes with every product. This product has been in testing, in one form or another for years, the basics of the design are already know. It's elegant in its simplicity.
Old 07-08-2014, 06:12 PM   #50
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I'm a sucker for testing as Micah knows lol. BTW wheres that special thingy-ma-bopper you were suppose to send me Micah?
Crystal_Imprezav is offline   Reply With Quote
