04-28-2009, 02:28 PM | #51 |
Member#: 202907
Vehicle:2006 Wrx Wagon Blue |
im thinking of getting a set of Epic Springs for my 06 wrx wagon. will i need to get an wheel alignment after i install these. If so to what specs do i set up my suspension?
04-28-2009, 02:41 PM | #52 | |
Vendor Sales Rating: (51)
Member#: 22731
Vehicle:2002 WRB Do-Luck GDA worldoneperformance.com |
http://forums.nasioc.com/forums/show...6&postcount=85 Armin @ W1
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B][COLOR="Black"]WORLD ONE PERFORMANCE[/COLOR][/B] Phone: 253.336.5449 AIM: WorldOneArmin To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B][COLOR="Black"]Building Award-Winning Subarus since 2002, with the track record to prove it.[/COLOR][/B] |
05-07-2009, 03:52 PM | #53 |
Member#: 109905
Thinking about these EPIC springs for my 05 STI. However I am sick of the Stiff ride of lowered springs. My car currently has lowered springs on it and it rides like a truck. Bumps make the dash sound like an explosion just went off. Enough is Enough. I don't track the car any more.
I am looking for a spring that is actually softer than OEM, with just a bit of drop up front to help close the gap. So far no one is making a spring for true daily drivers. Anyone want to compare how stiff these springs are on the STI compared to OEM and say compared to a WRX OEM? Thanks |
05-07-2009, 04:08 PM | #54 | |
Member Sales Rating: (6)
Member#: 193616
Vehicle:06 WRB WRX |
Chk out WorldOne peroformance and speak to armin. i got mine from him. when i explained to him what i was looking for exactly, without any hesitation he recomm the epic springs. i coudnt be any happier.....just an awesome guy to deal with and he'll hook you up with great price. hope this helps your decision. |
05-07-2009, 10:12 PM | #55 | |
Member#: 109905
Thanks for your impressions of these springs. Sounds good. As I said I am sooo tired of stiff springs. There just is no need for springs to be as stiff as they are these days. So again would you say your car rides as soft as it did on the OEM springs? Thanks |
05-07-2009, 10:25 PM | #56 |
Member#: 109905
So, I found a site that still carries the Prodrive springs for the STI. Anyone that has used the Prodrive springs? Or better yet anyone who has used both the Epic and the Prodrive springs that could compare the difference.
Thanks |
05-07-2009, 11:24 PM | #57 |
Member Sales Rating: (11)
Member#: 112148
Vehicle:I feel like I'm in "2 Fast 2 furious." |
I'm sure Dan will correct me if I'm wrong, since he worked for Prodrive, but the spring rides are very similar. The Epics are lower.
If you want softer springs, go to WRX OEM springs. |
05-08-2009, 11:15 AM | #58 | |
Member#: 109905
Thanks |
05-18-2009, 01:01 AM | #59 |
Member#: 174533
RMIC
Vehicle:0694 WRXLtd/LegWagon WRB/Pure White |
I installed Epic springs on OEM WRX struts last week. I'm still waiting for them to finish settling. My initial impression is that the car is a bit more responsive in cornering but also a touch more harsh over bumps, both of which are to be expected.
For people curious about the drop, this is the front fender gap immediately before and after installation: |
06-03-2009, 06:39 PM | #60 |
Member Sales Rating: (8)
Member#: 203579
Vehicle:05 Wrx Black |
Dang...well im sold. I've been juggling suspension in my head for months now about what to do...springs.....coilovers...that cost HUGE $$. My car is a daily driver of about 65 miles, Looks like im gonna be Epic'in too. So if im gonna get new struts....should i just get factory issue with these instead of some nicer ones? New to suspension so enlighten me.
06-04-2009, 08:16 AM | #61 |
Member Sales Rating: (2)
Member#: 43853
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
^Get some KYB GR2s and some scooby 921 spacers from turninconcepts.com
I installed Epics and GR2s about a month ago after one of my 5yr old Eibach prokit springs broke. The car definetly handles better than before. The ride is similiar, but the car does not roll as much in corners as it did with the eibachs. The springs have also now settled nicely too. At first the car looked really jacked up in the rear to me, but part of that was probably because I use to the saggy butt look of the eibachs. |
06-04-2009, 06:41 PM | #62 | |
Vendor Sales Rating: (26)
Member#: 191347
SCIC
Another option is Koni inserts. I'm not sure how much they cost but I do have quite a few customers using this setup and they all seem to be very happy. Kind Regards Dan Antonielli |
06-09-2009, 08:37 PM | #64 |
Member#: 177769
Vehicle:2006 WRX |
I got the springs install this last Sunday and have 125 miles on them at this point. I am very impressed with the ride quality so far, I expected it be harsher. The ride height is perfect, and the front and rear wheel wells really look even now.
I installed them in about four hours forty five min. with a friend (Our first time). No major problems with the install and it went pretty smooth. So far I am very happy with my spring choice and glad that I went with the Epic's. Thanks Dan for making such a sweet set of springs. I promise that I will get some before and after pictures as soon as the rain clears. Also if I could get a dye cut black Epic sticker, I would rock it. |
06-10-2009, 05:06 PM | #65 | |
Member#: 191347
SCIC
Bordwgn, Thank you for the kind words. I am glad that you are happy with our product. I look forward to seeing your pictures.... I have sent you some stickers. You should receive them shortly. Kind Regards Dan Antonielli |
06-15-2009, 04:07 PM | #66 |
Member#: 177769
Vehicle:2006 WRX |
Here is the car before the drop.
After Epic Springs Thanks Dan For the sweet sticker and just put 500 miles on my springs. Last edited by Bordwgn; 06-16-2009 at 04:35 PM. Reason: I had to get it back to the fort wall. |
06-16-2009, 01:34 PM | #69 |
Member#: 22731
__________________
06-25-2009, 01:32 AM | #72 |
Member#: 97576
Vehicle:2006 Evolution |
I agree...some BUGEYE wagon pics would be fantastic.
Considering going with these and some new struts. Now I just have to figure out which struts to go with. WorldOne, do you have a spring and strut combo with wagon specific struts? |
06-26-2009, 08:29 PM | #73 |
Member#: 177769
Vehicle:2006 WRX |
I really need to say some more great things about my Epic springs. The car now has 1000 miles and it amazes me that Subaru didn't put springs like these on as a stock part. What were they thinking when they put that great engine on granny suspension? This product has made my wagon what it should have been from the start.
My wagon handles perfect and the whole front end lift and dip thing (porpoising) is nearly gone. The ride is nowhere near as harsh as some lowered subies I have been in. The rear never gets away from itself, like it did before. I do have a 22mm rear sway and end links, they were in before the springs went on. They were a nice upgrade, but the Epic springs put it over the top. As for looks (FYI 0 saggy butt) I really don't need to say anything more, just look at the pictures a few posts back of my wagon. It makes me smile every time I walk up to it. I just needed to thank Dan again for a great product, it has made me fall in love with my wagon all over again. EPIC Engineering FTW! +1 we need to see some bugeye's on here. |
06-26-2009, 08:44 PM | #74 |
Member Sales Rating: (13)
Member#: 164171
SCIC
Vehicle:08 EvoX <3 Wagon rear prodrive plate frame |
^^ +1 for epic springs.
Im glad all the wagon owners are happy with the springs from Epic. Bordwgn, i would suggest some decent -camber up front and a ALK and youll be PRRRIIIME for a DD...Your setup is identical to mine and i know exactly what your explaining! im starting to miss my wagon deeply......sucks... evoX still isnt making me as happy as i should be! Maybe cause its stock height??? hahahah |
Similar Threads | ||||
Epic Engineering springs and Cusco suspension sale! | WorldOne | Suspension/Brakes/Handling | 35 | 02-25-2009 01:13 PM |
Epic Engineering springs for 04-07 WRX/STI! They truly are EPIC! Swaybar combos too! | WorldOne | Suspension/Brakes/Handling | 69 | 12-23-2008 03:30 PM |
Epic Engineering Springs $100 install special! $848 Element Tuning turbobacks too! | WorldOne | NWIC Vendor Classifieds | 4 | 11-09-2008 05:34 PM |
