Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 06-04-2010, 10:57 PM   #1
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
Default Noise from speakes 2010 impreza
whenever I plug in the wire for the auxiliary input for my ipod, at a certain volume level, I hear this fuzz like noise from the speakers. the louder the volume, the noise was higher. And ideas as to why this happens?
Help I'm Stuck! is offline   Reply With Quote
Old 06-05-2010, 02:51 PM   #2
profoak
Member#: 212520
I have the standard package aux in my Impreza. I think it might just be a piece of crap. With mine, you can't hear audio until radio is up to 25. CD's sound much better.
Which audio package do you have?
profoak is offline   Reply With Quote
Old 06-05-2010, 06:46 PM   #3
TheLegacyGT
Member#: 36720
2015 WRX Limited CWP
Crystal White Pearl
I would try turning the volume way up on the iPod so you don't have to turn the stock radio up so high. That may be part of it. You could just have a bad patch cable, too.
TheLegacyGT is offline   Reply With Quote
Old 06-05-2010, 08:49 PM   #4
DLWRX
Member#: 242689
2013 WRX 5-door
This, and check the EQ on the ipod itself, turn it off if it is on and control the EQ through your radio.
DLWRX is offline   Reply With Quote
Old 06-06-2010, 11:31 AM   #5
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
Same, its standard and I use a kensington charger/ audio wire.
Old 06-06-2010, 07:02 PM   #6
DLWRX
Member#: 242689
2013 WRX 5-door
It could be ground loop noise is what your hearing. dont have the charger and the aux cable plugged in at the same time and you shouldnt hear the noise
Old 06-06-2010, 07:34 PM   #7
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
The charger doesn't work. Its just this empty fuzz noise. It's only heard when there is no music playing at the louder volume like low 20's
Old 06-06-2010, 08:36 PM   #8
silvercookie
Member#: 180033
2005 WRX
dont put whatever you are plugging in past ~85% volume,
for everything i have hooked up to any aux cable, i found ~85% is the max before it distorts or makes a fuzzy sound.
silvercookie is offline   Reply With Quote
Old 06-06-2010, 08:38 PM   #9
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
Maybe I should be getting a new adaptor then. That could be the problem
Old 06-09-2010, 05:50 AM   #10
SLDWYS
Member#: 58877
BMW 340xi
From JDM to DTM
I have a gigaware charger / aux output for my iPhone. Took all that fuzz away on the stock aux input sound system.
SLDWYS is offline   Reply With Quote
Strange Noise from 2010 WRX b154wheel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-24-2009 10:13 AM
2009 Impreza Sport clunk/poping noise from back of car when first taking off 97seadoospx Service & Maintenance 31 08-23-2009 10:55 PM
Hey guys could I have some input on a strange noise from my '99 Impreza Outback Sport Malasubidude Newbies & FAQs 2 08-20-2008 01:51 AM
Click Noise from Axle 08 Impreza AT MXImpreza Transmission (AT/MT) & Driveline 1 12-20-2007 12:51 PM
Imprezas with buzzing noises from under the hood? generalganja Off-Topic 16 02-12-2007 08:58 AM
