01-09-2005, 12:20 AM | #1 |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
Do I have the right oil filter for '05 RS? SCI530009
I went to the local Subaru dealership to pick up an oil filter for my '05 RS for it's first oil change. They gave me a tiny looking Subaru filter with part number SCI530009. The parts guy commented that they just switched to a smaller filter...
The part numbers that I see here refers to AA060 and AA080? This thing looks just tiny....I haven't had a chance to look under my car to check the filter since it is -20C right now.
01-09-2005, 11:38 AM | #2 |
Member#: 63076
Vehicle:2004 Outback Sport Red! |
I believe the new, tiny, filters are WRX specific, but we'll let someone else post up.
01-09-2005, 11:42 AM | #3 |
Vehicle:OK buy Nates beans westcoastroasting.com |
There is a HUGE oil filter thread in the 'stickies' at the top of this forum....read it, love it, live it.......
01-09-2005, 01:43 PM | #4 | |
Member#: 72829
W. Canada
01-09-2005, 03:28 PM | #5 |
Member#: 50070
Vehicle:2002 Black Slushbox 2.5 Ounces to Freedom |
Scotty -- gettin on the RS boys I see -- see ya at On Tap when you get the Kong back in Melbourne again
01-09-2005, 05:14 PM | #6 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Sounds like you got the USDM 080 filter but thats the canadian part number you have, AFAIK the the n/a motors are still using the 060, so you will need the 060 canadian equivilent.
The part numbers in the oil filter thread are the us part numbers, the candian part numbers will be different. what color is the filter you got? the 080 in the US is black, and made in Japan, by tokyo roki (sp?), and is very small in size. Maybe in SOC is using the small filter on all its cars, dunno. Jay |
01-10-2005, 04:48 PM | #7 |
Vendor
Member#: 43552
Vehicle::o) Need Parts Now? |
Agreed...and those turbo filters are quite a bit more expensive than the filters that your car takes.
01-10-2005, 08:37 PM | #8 |
Member#: 32153
VIC
Vehicle:2001 GMC Sierra burgundy |
I went in a couple weeks ago and they handed me the same thing for my MY04 2.5RS...
they said subaru has switched to this ridiculously small oil filter... I asked the parts guy if he had any larger ones left in stock and took it instead... You have the right filter it just looks all wrong! later Daniel ps I'm hoping two dealers in different provinces aren't wrong! |
01-11-2005, 01:30 AM | #9 |
Member#: 72829
W. Canada
Finally got around to changing the oil...it was "only" -12C tonight...
Anyways, the stock filter that came with my '05 2.5RS wagon is indeed the small filter (A100) that is now used in the WRX, per Sticky above, not the A060 filter. The filter from the dealership (SCI530009) is the same size but the construction of the Japanese filter looks to be better (seal has round x-section vs the typical square). I picked up a filter for my Passat 1.8T also since the dealerships were next to each other. VW went the opposite direction in terms of filter size, after problems with oil sludge clogging things up. Any wonder I was nervous after getting that tiny filter for my 2.5RS? |
01-11-2005, 02:35 PM | #10 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
01-11-2005, 04:03 PM | #11 | |
Member#: 72829
W. Canada
04-06-2005, 04:41 PM | #12 |
Member#: 35794
VIC
Vehicle:2004 wrx wagon auto silver |
yeah I just picked up a few filters and got the tiny sci530009, it does look all wrong.
why would we go back to a bigger one though as said by North Ursailia? |
04-06-2005, 06:51 PM | #13 |
Member#: 3313
Well, it's cheaper.
I thought the whole reason they thought they switched to the smaller filter was due to a clearance issue(for heat) on the turbo blocks. They have never come out and said it needs replacement. I'd check the 05 RS service manual and see what it states is the Subaru replacement part for the EJ25 NA engine. If they still allow the AA060, and it's cheaper, that would be the logical choice. Maybe they just use the AA100 on the new cars to simplify parts availability on the line. |
04-06-2005, 11:25 PM | #14 | |
Member#: 82118
Vehicle:2017 WRX |
04-07-2005, 04:39 PM | #15 | |
Member#: 2808
03-27-2006, 01:07 AM | #16 |
Member#: 109912
E. Canada
Vehicle:2005 Legacy 2.5i 5dr OBP |
Resurrecting an old post here... the SCI530009 is just a private label FRAM.
There's a post on IWSTI by Wolfplayer that has pics and when you compare the two - it's obvious it's a FRAM. Based on the data he gathered cutting them apart etc, he rated it as one of the worst of the bunch. Ugh. I just bought a case of them from the local dealer. I think I'll be taking them back and start looking for a deal on the Tokyo Roki's... Andrew |
Similar Threads | ||||
Do I have the right engine mounts for my 09 - help, under my car now | last lemming alive | Transmission (AT/MT) & Driveline | 2 | 04-24-2010 09:15 PM |
Did I get the right oil filter? | some dude | Newbies & FAQs | 3 | 08-27-2009 01:44 PM |
Do I have the right filter for '05 RS? SCI530009 | Airboy | Canada Region Forum | 1 | 01-09-2005 02:49 PM |
What is the best Oil Filter for the RS. I keep hearing that Mobil 1 doesn't make one. | wrxman555 | General Forum Archive | 12 | 11-09-2000 02:33 PM |
