Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 11-13-2019, 11:11 PM   #1
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Default Chinese made tires?
Hi Everyone! Do you have any experience with Chinese made tires? My 08 OB is only going to last another 2 years. I juuuuust squeaked by NJ emissions inspection. I need another set of all seasons next spring. I do run dedicated snow tires so snow traction is no concern with the all seasons. I donít want to spend more than I have to for tires that I will put 30k mikes on at the most. Are they more prone to puncture?
Thanks in advance!
Steve
jetfan2207 is offline   Reply With Quote
Old 11-14-2019, 11:41 AM   #2
jaidmaster
Member#: 213446
PSM, Forged Hybrid, GT35R
I ran the Nankang NS20 for awhile and didn't have any problems.
I've been getting used tires off craigslist for years - can find some good deals on good tires!
Good luck!
jaidmaster is offline   Reply With Quote
Old 11-14-2019, 12:13 PM   #3
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Thank you very much. A lot of people trash these tires saying they are poor quality but I have noticed quite a lot of cars with them recently.
Thanks again!
Old 11-14-2019, 04:29 PM   #4
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
Good luck!
FYI, Nankang is from Taiwan, not China.
OP: They are a good 2nd tier tire company, and I think they will be more than just fine for your purpose.
TifosiWA is offline   Reply With Quote
Old 11-24-2019, 08:31 PM   #5
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Thank you. I will be going with these come spring. Thanks again!
Old 11-24-2019, 09:04 PM   #6
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Originally Posted by jetfan2207 View Post
Hi Everyone! Do you have any experience with Chinese made tires? My 08 OB is only going to last another 2 years. I juuuuust squeaked by NJ emissions inspection. I need another set of all seasons next spring. I do run dedicated snow tires so snow traction is no concern with the all seasons. I don’t want to spend more than I have to for tires that I will put 30k mikes on at the most. Are they more prone to puncture?
Thanks in advance!
Steve
Now if they are Nankang, they aren't horrible. Just don't get Chinese tires, I've yet to see a good set on any vehicle.
Old 12-01-2019, 03:58 PM   #7
Alex_Rochester
Member#: 508924
The problem with most el-cheapo Chinese tires is that they use harder, less pliant rubber, which in turn means less grip, longer stopping distances, etc. Also, quality control on just about anything sourced from the Peoples Republic of China is just awful, so expect a much greater chance of things like poor roundness, broken belts, bad seats, etc.
Alex_Rochester is offline   Reply With Quote
Old 01-02-2020, 12:22 AM   #8
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Thanks all!
Old 01-06-2020, 05:10 AM   #9
brylemr
Member#: 414507
Just remember that cheap tires are a hit and miss.
brylemr is offline   Reply With Quote
Old 01-15-2020, 07:13 PM   #10
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Thank you!
Old 01-18-2020, 10:20 PM   #11
cis2711
Member#: 476365
News Sumitomo
Iíve had excellent experience using sumitomo htr po2 all season tires, despite them being a foreign Brand name
cis2711 is offline   Reply With Quote
Old 01-20-2020, 10:20 PM   #12
benders
Member#: 181247
2004 WRX Wagon
Thanks in advance!
Steve
They won't really be more prone to puncture, the balance will be worse, wet traction will probably be pretty bad, snow traction even worse. But if you only need them to last two years, better than running worn out tires.
benders is offline   Reply With Quote
Old 01-25-2020, 08:23 AM   #13
Petrol Head
Member#: 511057
Default Dont Ever Do It, I Nearly Died
6 months ago I nearly lost my life due to using cheap Chinese tyres on rpf1 wheels.
I clipped the edge of the road at high speed and rolled the tyre off of passenger rear wheel, which sent the car like it was on rails straight into a tree.... well more through the tree.
Watch "2003 WRX Sti 400hp E85" on YouTube
https://youtu.be/qxcJopxtweI
This video was 3 days prior and if you look as I wind on boost on some corners you can see the car wasn't very settled in the rear.
If I could wind back time I would buy the most expensive tyre I could as everything else on the car was. Tyres from previous owner
Petrol Head is offline   Reply With Quote
Old 01-25-2020, 11:44 AM   #14
Opie
Floresbian
Member#: 470
2020 Canyon Denali
'18 FXT, '16 XV, '13 BRZ
Just because a lot of people have them, doesn't mean they aren't poor quality...
Opie is offline   Reply With Quote
Old 01-25-2020, 12:41 PM   #15
NighthawkSTI
Member#: 495630
had a set of imperial snow dragons for a year, they were 60 each. Compared to a dedicated snow tire that I had used before(dunlop graspic), the snowdragons were nowhere near as grippy in the snow and the handeling was iffy at best. In the wet they were dangerous, I did a 180 going into an onramp (slightly over the limit) on wet pavement and the car just suddenly started sliding. They were acceptable in dry. After one of the tires went completely flat for no reason at all while driving(no leaks or punctures were found), I Replaced the Chinese tires with a set of all season continental DWS which are better in the snow(still not a dedicated snow tire good), but WAY better in the rain and dry.
If your going to get Chinese branded tires...you have to end up getting the higher end priced versions, to get a decent tire anyway, and then your not really saving money and are still giving up the attributes of the better popular high rated tires available here.
NighthawkSTI is offline   Reply With Quote
Old 01-30-2020, 12:39 PM   #16
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Thanks all! I actually came across Nexen tires (Korean made) that are a decent price and will probably be going with them once the snow tires come off in a few months. I know they are not the best but I only need to get like 30k out of them.
Old 01-30-2020, 02:57 PM   #17
NighthawkSTI
Member#: 495630
I had nexen 3000 tires on my 06 STI when I bought it, they actually rode quite well on the highway, and the handeling was good due to stiff sidewall, easy to break traction in wet though especially compared to continental DW's I switched to. On Cool dry pavement the nexens were also easy to break loose. These were more of a dedicated summer tire...so I cant say what their all seasons are like but probably more of the same.
My go to now is either dunlop or continental...currently have continental DWS all season that I have had for a year and they are really good all around tire. The DW summer tire have unreal grip in rain and dry....probably the best tire I have run. Still have them wrapped in plastic.
Old 01-30-2020, 03:18 PM   #18
NighthawkSTI
Member#: 495630
also dont overlook getting a set of used higher end brand named tires...craigslist facebook market place etc. Just be careful of how old the tires are by checking the date codes on all the tires in a set, and get a tread depth gauge to make sure that they are all within depth varience..2mm tops variance for subarus.
You can save HUNDREDS by going this route and get a brand name with better reputation if you are lucky.
Old 01-30-2020, 10:21 PM   #19
Boxcar80
Member#: 491471
2009 Impreza
Very true. I got a set of Goodyear Eagle F1 that were brand new take offs for $250 for the set. A local tire shop sells a lot of tire and wheel packages for guys that replace their stock sets on their brand new cars.
Boxcar80 is offline   Reply With Quote
Old 02-04-2020, 11:50 AM   #20
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Ok, wait.
You use snow tires in the winter, which means you have snow tires. Just run them year round? I've done this on vehicles numerous times and our 13 Crosstrek is currently running year round on some General Arctic Altimax snows. Contrary to popular myths, they don't burn themselves off in a summer or some other ridiculous claims.
Here's another good reason to do that. Tires go bad with age. Not just wear. You can end up with 12 year old snows at nearly full tread depth that are so cracked and dry rotted, you have to throw them out. Might as well get the wear out of them.
