Welcome to the North American Subaru Impreza Owners Club Monday February 17, 2020
Old 10-05-2009, 12:24 AM   #1
CatfaceType-R
Member#: 81102
Default Anyone running a Twinscroll turbo on a non divided manifold? helper valve tested!
If you are, what's your setup? and you might want to beg your local suby shop to fab up something like this!
This is for a twinscroll turbo with a non divided manifold
here's why I think you would be interested in this
Originally Posted by Sound Performance View Post
Here is a dyno of our new valve for twin scroll turbos that will divert all exhaust to one scroll during spool up and then open to allow both to run normally.....
Seriously..... who else innovates like we do??? Seriously?
Originally Posted by Suprafied View Post
Guys,
This device does work. I have a friend who has been working on for over a year on his car. Its has shown a GT42-74mm to be at full spool by 3700 RPM.
Larry,
IIRC, I thought I mentioned something to you about this or maybe Chris awhile ago.
DP
here's the thread if you are interested http://www.supraforums.com/forum/new...eply&p=5843044
CatfaceType-R is offline   Reply With Quote
Old 10-05-2009, 12:30 AM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Old 10-05-2009, 01:28 AM   #3
TDagen
Member#: 163648
V9 6mt R180 Brembos
Holy%*^* where have these been? I might go twinscroll this winter lol...More fabbing...lol
TDagen is offline   Reply With Quote
Old 10-05-2009, 02:26 AM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i have seen this, but has anyone actually used it on a subaru i understand the concept and have seen it around for a few years now, and 500 rpms faster to 600 is nice and more under the graph, but i would like to see it on a subaru
seanathanq83 is offline   Reply With Quote
Old 10-05-2009, 02:36 AM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
why would someone run a twinscroll housing on a single scroll header?
wouldnt it be cheaper and easier (read less moving parts and possible points of failure) to just switch the turbine housing?
or just cut out the divider on the turbine?
to me this really isnt about single vs twin scroll.....but more about speeding up the exhaust gases at low rpm.
i'd like to see one of these on a single scroll turbine. Obviously it would never be shut, but partially closing it at low rpm should have this same effect, right?
Old 10-05-2009, 03:54 AM   #6
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Humm Idk sounds like they tried to do something like this but further away from the turbo might not have as much of an effect. but who know's.
Check this out. Porsche 911 turbo VGT turbo borg warner makes it so you know they know what there doin with turbo's.
http://en.wikipedia.org/wiki/Variabl...y_turbocharger
spoolinsti05 is offline   Reply With Quote
Old 10-05-2009, 04:02 AM   #7
seanathanq83
Member#: 173241
well i figure the way it works with the twins scroll with single scroll up pipe because it forces the gasses throught the one side which will make it go through only half of the twinscroll exhaust housing, my thought is that it might actually cause more turbulance in the up pipe and exhaust housing
Old 10-05-2009, 05:05 AM   #8
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
It could happen in the same way with a true twinscroll manifold, but the valve could only close half of each port, halving the opening for the gases, speeding the exhaust flow.
Arctic Assassian is offline   Reply With Quote
Old 10-05-2009, 05:07 AM   #9
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
You're misunderstanding the point of this thing. It basically turns a twin-scroll turbo into a variable-geometry single-scroll turbo. Variable geometry as in "you have two ARs to choose from."
With the valve open, you get something roughlyequivalent to a single-scroll turbo with the AR equal to the sum of the ARs of the two scrolls. Nothing special. But, with the valve closed, you get something roughly equivalent to a single-scroll turbo with the AR equal to just the AR of one of the two scrolls.
Sounds great on paper, I'm really curious how well it works in practice. The figures from the Supra site aren't directly applicable to Subarus but they are interesting. "GT42-74mm to be at full spool by 3700 RPM" on a 2JZ I guess, but still...
Old 10-05-2009, 11:59 AM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
thats why i said i want to see it on a single scroll turbine.
cause i do understand that's what's happening and it should have the same effect......
seems like you read the first 3 lines of my post, but not the last 2. The first 3 were basically "why would anyone end up with that setup" and the last 2 were "why dont they make it for single scroll turbines because speeding up the exhaust gases on a single scroll will have the same effect"
its just like putting ur thumb over the end of a hose. i dont think it has anything to do with single vs twin scroll. it should work the same on both.
Old 10-05-2009, 12:07 PM   #11
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
hrmmm
this could lead to great things
BUILTSTI is offline   Reply With Quote
Old 10-05-2009, 12:13 PM   #12
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
someone do this! seen this for a while now always wanted to see it on a subaru, being that lag is our enemy.
WREX88 is offline   Reply With Quote
Old 10-05-2009, 12:33 PM   #13
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Just fab a header system and put two td04's down front with a sump pan. Bang, no more lag. That is my project number two, which should commence over the next couple years.
The concept of this valve is interesting, so hurry up and do the testing on your Subaru so the rest of us can see how it goes.
UFOpilot is offline   Reply With Quote
Old 10-05-2009, 01:08 PM   #14
TDagen
Member#: 163648
V9 6mt R180 Brembos
I was thinking today for awhile about this thing .... What would be more cost effective jdm. Twinscroll manifold or this puppy... Plus with the jdm manifold less chances for things to go wrong...
Old 10-05-2009, 01:17 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
these valve setups seem like their favorite thing....they make an exhaust cutout too that uses it.
http://www.spracingonline.com/store/...ctivated_/3673
and damn, this things $500
http://www.spracingonline.com/store/...ool_Valve/3659
Old 10-05-2009, 01:21 PM   #16
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Just using a twinscroll turbo on a single manifold would by theroy speed exhaust gasses up to some extent.. as air gets forced through smaller aperatures its velocity increases right? Twinscroll designed hotsides have a nice divider plate in them that can be modified for efficient splitting.
Dubstar112 is offline   Reply With Quote
Old 10-05-2009, 01:22 PM   #17
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
btw wheres the boost charts?
Old 10-05-2009, 01:30 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
Without boost applied the valve is closed, correct?
So how did they dyno the car 4 minutes apart with "no valve" and "valve operating"?
If they just unhooked the line from it, then the valve would be closed the entire run, right?
Old 10-05-2009, 01:54 PM   #19
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I think for this to actually work It would have best results on a twin scroll since it's actually divided like a true VGT setup.
But yet it's not.. Because a true VGT setup is done with the turbine wheel itself.
Old 10-05-2009, 01:58 PM   #20
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
I don't really think it would have the same effect at all because on a single scroll turbo you are not changing the effective turbine A/R.
Sure exhaust gasses will speed up to go through on side of the twin scroll valve but will then slow back down to its original speed(actually slower) right after before it even gets to the nozzle area. Its conservation of energy and has to happen.
On a twin scroll setup you have two equal nozzles that should get half total exhaust flow on a single scroll header. With this valve you're forcing on scroll to take all the exhaust flow and like it. Instead of full exhaust flow going through a 1.06 A/R housing it like going through a .53 A/R housing.
Old 10-05-2009, 02:18 PM   #21
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
They are controlling the valve with a AEM or ProEFI through a solenoid.For no valve they would apply constant pressure and keep it open, after words they set the solenoid to function the valve like it normally would.
Junior
Junior2JZ is offline   Reply With Quote
Old 10-05-2009, 02:47 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
ah. i see.
Old 10-05-2009, 05:02 PM   #23
CatfaceType-R
Member#: 81102
Originally Posted by BUILTSTI View Post
hrmmm
my thoughts exactly chaps
ron-this DOES work and works very well, do some more research and let me know what you think.
JR-Do it up, I know you have a customer somewhere with a non split manifold and a twinscroll turbo
I also made this thread to let people remember the fact that you DO NOT need to run a twinscroll exhaust manifold to run a twinscroll turbo
This valve that SP has come up with(maybe not invented, but developed) will allow people to run huge turbo's and mitigate lag in a huge way!
Cheers guys, I want all subies to go faster; this is why I am doing a lot of research on different platforms and conveying anything that can/will help the subi family.
Since I only have a stock BMW K1200RS and it's not getting modded, it's time to save and do research
Where's engineer STiMIkey on this ?
Old 10-05-2009, 05:11 PM   #24
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i have a t4 twin scroll housing (.85a/r), if anyone wants to purchase to do testing
this valve sounds good in theory....subscribed!!
blowbyu24 is offline   Reply With Quote
Old 10-05-2009, 06:42 PM   #25
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
interesting concept, i'd like to see some tuner data on the effects of possible increase in backpressure prior to the valve opening. The valve would have to be at a lower spring rate than the EWG spring when signaled off the same manifold boost source or a separate solenoid inbetween.
fastnoypi is offline   Reply With Quote
Turbo on a non-turbo legacy 2.5 97LegacyGT2.5 Normally Aspirated with bolt-on Forced Induction Powertrain 26 04-09-2018 01:50 PM
Anyone ceramic coat their turbo, up-pipe, and exhaust manifold yet? Corn-Picker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-24-2003 03:31 AM
Anyone put STI fog covers on the non-STI's? linnboi Interior & Exterior Modification 24 12-01-2003 09:14 PM
Anyone running cattless MRT turbo back? JDWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-04-2002 01:58 AM
Anyone tried the scoopless look on their non-turbo GC8s? edkwon Interior & Exterior Modification 11 12-13-2001 05:55 AM
