Welcome to the North American Subaru Impreza Owners Club Monday January 22, 2018
Old 04-30-2014, 10:16 PM   #276
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
So in terms of o-rings, bought some 1.5mm wide x 6mm ID and 8mm ID o-rings from mcmaster. They seem very close to OEM
The only issue I ran into is that for the return line, it needs a 16mm x 1.5 to 6an adapter. But the fitting female end is too long for the OEM nut. A test fit showed that with the nut bottomed out in the fitting, I can move the combo around the flare. The fitting is 12mm deep while the OEM and nut is 10mm. The high pressure side fitting is 10mm deep as is the oem. For reference:
So what should I do here? Hacksaw/dremmel 2mm of the back end of the fitting? What have you guys done?
Bad Noodle is offline   Reply With Quote
Old 05-06-2014, 07:55 PM   #277
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
So what do you guys think of routing the lines like
Will rub or snag anything?
Old 05-06-2014, 08:10 PM   #278
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Doesn't look like they will snag anything but would consider some heat retention as the dp will be pretty close to those power steering lines and wiring.
trev762 is offline   Reply With Quote
Old 05-06-2014, 09:22 PM   #279
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Fire shield for the ss lines, and get the nifty Velcro heat sleeve from summit or dei for the main engine harness if you don't feel like fabbing up a heat shield.
dstroy is offline   Reply With Quote
Old 05-06-2014, 11:30 PM   #280
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
^ either that ^ or do what I did in both my cars and bend the PS wrack hard lines a little so they are more pointing straight up/toward the bell housing and run the lines under the intake manifold right to the PS pump. Then your not smack up against the UP and cooking the PS fluid.
dangerousatom is offline   Reply With Quote
Old 05-07-2014, 06:50 PM   #281
Type2
Member#: 200436
2004 Forester XT
It will be fine. I didn't go fancy like you. I only used SS on the high pressure side. Seemed like a lot of work to change it over to SS on the low pressure side. But it does look purdy
Type2 is offline   Reply With Quote
Old 05-07-2014, 06:57 PM   #282
Type2
Member#: 200436
2004 Forester XT
This is from my build thread. It shows how I routed it. BTW I am rotated so keep that in mind.
Originally Posted by Type2 View Post
////snipped////
The good news is that I finally got the P&L power steering line installed. I also replaced the low pressure line. It took about 6 hours total. I could probably do it in much less time if I were to do it again. Pretty much the story with this car. ///snipped///
This AN fitting goes on the pump:
Here is the SS line attached:
To get at the fittings by the crossmember, at a minimum you need to removed the turbo. Since the turbo is rotated, and the downpipe is v-band, it's a relatively quick procedure. Plus I've now done it several times so I can knock it out relatively quick.
Here you can see my up pipe. It's been wrapped with DEI Titanium, then on top of that I used some aluminum tape, then wire wrapped the aluminum tape. I think it was Suicidal Eggroll that posted this method. It works great at not soaking up oil, etc. I learned my lesson after soaking my up pipe on install. You can see the blue AN adapter connecting to the power steering line.
Here it is connected:
I also replaced the low pressure line with 3/8" fuel injection hose. I don't trust clamps that only use spring tension, so I put a T clamp on it.
Here are both lines coming up next to the up pipe. I put a heat shield on the high pressure line since it's close to the up pipe.
The low pressure line hooked up to the reservoir. Here I used the spring clamp mainly because if it is leaking I can quickly change it to a T clamp.:
Another shot of the low pressure line. I have it zip tied to the brake line:
Old 05-07-2014, 08:39 PM   #283
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ Looks good.
Old 05-07-2014, 09:03 PM   #284
Type2
Member#: 200436
2004 Forester XT
^ Looks good.
If I had been SMART I would have done it when I had the engine out lol. Would have been a 30 minute job. Makes changing plugs way easier. And valve cover gaskets.
Old 05-08-2014, 10:17 PM   #285
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Advice taken
Fanciness Achieved
It's gonna be a pain fixing these when they leak. And they will leak. I'm used to the good-ol AN / NPT type mechanical seal. These didn't feel like that. They just bottomed out and that was that...
Old 05-08-2014, 10:35 PM   #286
Type2
Member#: 200436
2004 Forester XT
Advice taken
Fanciness Achieved
Hey that looks good! Mine haven't leaked in over 12k miles (cross my fingers)
Old 05-12-2014, 09:53 AM   #287
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
as long as you have cleaned the surface and properly used a crushwasher, then fully tightened - the fittings are unlikely to leak
Full-Race Geoff is offline   Reply With Quote
Old 06-08-2014, 10:01 PM   #288
stuiephoto
Member#: 205742
1995 RSTI
Has anyone had an issue like this? On my track car with one of these setups, when the car heats up I lose power steering-- its gradual, the tighter the turn the less the power steering works. No leaks, no bubbles in reservoir.
stuiephoto is offline   Reply With Quote
Old 06-08-2014, 10:35 PM   #289
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
What did you do to slide the hose over the tube?
Cefaln452 is offline   Reply With Quote
Old 06-09-2014, 05:46 AM   #290
bashar_ra
Member#: 393019
good info
bashar_ra is offline   Reply With Quote
Old 06-25-2014, 04:04 PM   #291
Topher03
Member#: 209375
2002 wrx wagon
Ill have to get a pic of what I did. But I took my stock line to a local house place and the cut it and crimped a -6 fitting onto it. That way I need the factory connection at the rack connection.
Topher03 is offline   Reply With Quote
Old 07-05-2014, 04:12 AM   #292
boczo777
Member#: 305314
2010 STI
BLACK
anybody got parts list for 2010 sti?
boczo777 is offline   Reply With Quote
Old 07-06-2014, 03:06 PM   #293
Type2
Member#: 200436
2004 Forester XT
I would save yourself the trouble and buy a kit but if you really want to build it this thread has everything you need.
Old 10-27-2014, 05:52 PM   #294
ColesSTi
Member#: 99205
2005 Impreza WRX
I am in the process of doing this now. I have a forge motorsport aluminum tank I want to mount it somewhere tucked but in a clean way. I used to have it mounted on the passenger side up high, near the factory boost control. Anybody have any tips on where to mount it? Somebody told me I mounted it a little high. I am keeping the left and right side of the engine bay empty.
ColesSTi is offline   Reply With Quote
Old 10-27-2014, 06:07 PM   #295
dangerousatom
Member#: 70710
If its lower then the PS-pump be sure its sealed and never closer then an inch or so from the top for expansion and froth up
If its above the PS-pump just keeping it full is all you need to know..... Id still make it sealed.
I have always wanted to put it in the wiper cowl with a round cut out access in the cowl and a nice threaded cap....so the lines will go through the fire wall into the cowl. That spot is a empty space asking to be filled with necessary but hidden bit removed from the engine bay
Old 10-27-2014, 06:17 PM   #296
ColesSTi
Member#: 99205
2005 Impreza WRX
Funny you said that I was thinking the same thing. Perfect if that made it in the shaved and wire tucked thread.
Old 10-27-2014, 06:20 PM   #297
ColesSTi
Member#: 99205
2005 Impreza WRX
I just tried it would require a lot of work or a smaller tank, my tank has two nipples on the bottom.
Old 11-03-2014, 07:30 PM   #298
nj kiter
Member#: 241501
im in the process of replacing my high pressure power steering line with a braided one, i bought the inverted flare fitting for my steering rack. from my understanding some fittings utilize the seal, and other fittings do not use the seal going off the steering rack. Im just wondering because I'm only looking to do this once. here is the fitting i have……
seal, or no seal?
http://www.3sx.com/store/comersus_vi...dProduct=30271
nj kiter is offline   Reply With Quote
Old 11-03-2014, 08:19 PM   #299
dangerousatom
Member#: 70710
nj kiter
The pic's you linked are basically standard flare fittings = No O-ring They can be used but with alot of extra work
The ends/fittings coming directly off the rack hard lines are male and have O-rings in them see post 276, so you need female O-ring type fittings, unless you cut the hardlines and hand flare them with female flare ends to accept the flare fittings you linked to.....that is lots of work and hand flaring is tuff along with there is only enough length on the rack hard lines for maybe 1 re-do.
Get the fittings Bad Noodle used or one of the SS/braided kits on eBay for under $80 ( search "wrx power steering line" ) there will only be 20-30 hits and probably 2-4 SS line kits in that ,some kits have separate fittings others have the fittings pressed onto the line.
Old 11-03-2014, 09:12 PM   #300
nj kiter
Member#: 241501
ah man i was under the impression that the flared fitting was going to mate up to the racks hardline better than the traditional earl fitting, but it seems like I'm in the wrong ball park. looks like i might be doing this more than once.
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 04:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 07:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 11:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 11:58 PM
