Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 09-02-2005, 10:46 AM   #1
Keith
Member#: 191
2012 J train
Brown
Default 98 ECU, open iac and closed iac (need help wiring a link)
I'm putting a linkplus ecu in my ej22t/98RS and I'm all set execpt for the IAC.
The link system has seperate wires for 4 different IACs while the 98 RS ecu only has a "open" and "closed" set.
Any ideas on how to wire this up?
Keith is offline   Reply With Quote
Old 09-02-2005, 04:25 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
this is the devorced IAC right?
its a stepper motor it should be the same wiring as a ej20G.. the link+ should be able to drive it
is this mcdade's car?
Old 09-02-2005, 05:10 PM   #3
Keith
Member#: 191
2012 J train
Brown
I don't think it is a stepper motor as 00rs is and it has 4 wires coming out of it (step a-d)
this one only has the two connections. http://www.northursalia.com/m...ring/my982.gif
and yes, this WAS mcdades car now mine
Old 09-02-2005, 05:49 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
that diagram is for the 98 throttel body - useless...does this car have the plug n play link plus kit.. which is designed for the throttel body IAC
you need to rewire it to work with the ej22t IAC (4 wire) the link should do this but not in plugn play fasion...
Old 09-02-2005, 07:13 PM   #5
Keith
Member#: 191
2012 J train
Brown
i actually got it. I went through the manual and it states:
3.15.2 Solenoid
There are 2 pins dedicated to control either a 2 or 3 terminal idle speed
control (ISC) solenoid. Figure 3.32(a) is a 2 terminal, part (b) is a 3 terminal
solenoid.
ISCO (idle speed control open) ORANGE/GREEN
ISCC (idle speed control closed) ORANGE/BLUE
If i'm not mistaken, this is what I'm looking for.
This link is NOT the plug and play one, it is the wire in version. I have the whole harness labled with which pin it needs to go to, it is just a matter of wiring it up now.
I think that was the only question I had though, I was worried about that but the manual seemed to help (who would have thought )
btw, if I'm totally off..laugh at me.
Old 09-02-2005, 08:49 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
ha-ha!
knoob
i feel sooo much better now
open source VF48 tune? xpt? need help please JasonLI25T Open Source Reflashes 4 12-22-2008 10:36 PM
Need help wiring jdm ecu digi Western Canada 6 05-12-2006 08:04 PM
Need help wiring Supertones in WRX BSLICKOH Interior & Exterior Modification 5 01-31-2002 10:18 PM
some 1 close, i need help ! DannyGT Tri-State Area Forum 8 01-06-2002 09:28 PM
need help wiring trunk latch to factory alarm malaki Car Audio, Video & Security 7 02-04-2001 06:56 AM
