#1 |
Member#: 31702
Vehicle:2013 WRX |
![]() well, i didn't even know what halo's were until last week. i saw a pic of them on a green WRX. well, i liked them. sooooooo... i made them! let me start by saying that these are a PITA to make and install. they look good though. i'll post more pics in the daytime or evening when you can see them better. what you all think?
(i'm sure this will be called rice sooner or later... but then again, so is everything it seems!) ![]() ![]()
#2 |
Member#: 22664
![]() those look mean as hellll!!
![]() the only thing i dont like is that the ring is more like hid like and the other bulbs are yellowish color |
#3 |
Member#: 15533
Vehicle:2010 Dodge Ram Hemi boat, dirt bikes, bobcat |
![]() me likey, not ricey
#4 |
Member#: 5885
NWIC
Vehicle:2000 RS (GME) SilvAr |
![]() Those look freak'n awesome.
Okay, so you'll have to tell us: - what you used (hexagonal v round plexy)? - make little slits or ribs? - what is your light source (LED, color, voltage, etc)? - how did you splice this in electrically (slaved of of driving lights)? Yeah, day time shots would be really nice. Thanks... and again, those look excellent, not rice man. |
#5 |
Member#: 10292
Vehicle:2002 WRX Sedan Silver |
![]() Give details you jerk!
#6 | |
Member#: 21641
International
Vehicle:4EAT [email protected] Now a 6MT! beyatch! |
![]() Quote:
little slits. LED for me. 5mm, 3.7 volt, 20mA, 2600mcd...you will need resistors from radio shack run a search thru google, there's tons of websites that show tutorials. jason |
#7 |
Member#: 31702
Vehicle:2013 WRX |
![]() thanx! i just checked back and saw that you all posted. didn't mean to be a jerk
![]() -definatly hex shaped rods. you can get them at wal-mart, lowes, etc. -made little slits. i tried a few different ways, but light, little slits worked the best. -3.6 volt white LED's from radio shack. also put a 220 ohm resistor inline with the positive lead. -i used the DRL lamps on the morette's. the little bulb that is in the high beam housing. made my own little plug out of a piece of the mini-blind wand. i like the way they look too. i also agree that the HID look is kinda off with the regular lowbeam color. i guess it gives me a reason to switch to HID's in the low beams! thanx again! |
#8 |
Member#: 31702
Vehicle:2013 WRX |
![]() here's a pic of the test rod.
![]() From right to left: -small little vertical slits -small X's -medium/deep slits -light diagonal slits this pic is with a normal flashlight. you can see how quickly the light degrades, so LED's were a must. i chose the light slits, placed decently apart. about 4mm. the light also will not degrade as quick with light slits. i tried a couple other rods, and the deep slits block too much light from going from one slit to the next. i like the X's, but decided not to go with it. |
#9 |
Member#: 18647
![]() Very
Very Very Nice ![]() |
#10 |
Member#: 38983
SCIC
Vehicle:2004 WRX Platinum Silver |
![]() I agree, that looks pretty cool.
Check out this website for a DIY. Granted, it's a corolla, but I think the concepts are the same. ![]() vamp.darkravers.net Cheers! -C ![]() |
#11 |
Member#: 12434
Vehicle:2002 WRX #332 2019 BMW m240ix |
![]() That first pic is one of the coolest things I have ever seen.....Good job!!!!
#12 |
Member#: 16906
Vehicle:2k3 wrx wagon PSM |
![]() how did you manage to get your morettes apart? I've heard that the silicone or whatever they used to seal the housing in is really tricky to work with and it's easy to mess up your lights. I've been wanting to do this for a while now but i'm just scared. Did you oven bake your headlights? How long did you put them in there and at what temperature? What were some of the major issues/hangups you encountered? Any pointers? Any and all information would be extremely appreciated. Awesome job!
#13 |
Member#: 31702
Vehicle:2013 WRX |
![]() i used a heat gun, and a flat tip screwdriver. heated the housing up, and started prying. make sure you DON'T try to bend the 4 little clips that help hold the housing!!! they WILL break. i broke 2 right off. just pry around the whole thing, and when you've gone all the way around it, pry the housing NEXT to the clips. then they will come off. it's no joke. it is a SERIOUS PITA to take them apart.
#14 |
Member#: 20267
Vehicle:|'02 GGA WRB| |'03 BH6 PSM | |
![]() That looks nice,
#15 |
Member#: 8305
BAIC
Vehicle:2001 2.5RS Gunmetal |
![]() i lav it. it makes me feel warm and fuzzy.
#16 |
Member#: 16147
Vehicle:no more turbo 11 Outback, 17 Impreza |
![]() The original evil set is up for grabs if anyone is interested.
![]() ![]() http://forums.nasioc.com/forums/show...ight=evil+eyes |
#17 |
Member#: 5885
NWIC
#18 |
Member#: 9320
Vehicle:2002 Subaru WRX |
![]() That's hot
#19 |
Member#: 33031
TXIC
Vehicle:2008 4B11T P26 MZ314000 |
![]() WOW!!!
![]() I found an instruction over the web. http://students.washington.edu/ashis...gel%20Eyes.htm but for some reason, the car on the above website doesnt do justice for the Angel Eyes. edit: and I found this too ![]() Dual Beam Projector Headlight w/Halo for 00-02 Impreza ![]() Last edited by WR xplosive; 07-11-2003 at 12:59 PM. |
#20 |
Member#: 30512
Vehicle:01 2.5rs black |
![]() they were sweet untill i found out they were on morrettes. They definatly are cool, and i bet look great at night, but it seems that they are now just less ugly morrettes.
#21 |
Member#: 16906
![]() morettes rule... <--- matter of personal taste, as is everything else.
I saw a member on the boards that put DIY angel eyes into his stock headlight housings and IMHO it didn't compliment the look at all. Looked very incongruous with the whole headlight. There was too much open space around the ring, not like the isolated orbs of the morettes. |
#22 |
Member#: 7792
Vehicle:2002 Prodrive widebody Cosworth 2.5 6sp |
![]() I so want to try this on my STi projectors.
#23 | |
Member#: 30512
![]() Quote:
you think that looks funny, some guy on vwvortex did this to a mk4 jetta. ![]() |
#24 |
Member#: 20492
Vehicle:4 -valve Derper Let's JDM styling! |
![]() If someone has the balls to crack open a set of JDM/EDM projectors and try this I bet that would look insane
#25 |
Member#: 39737
![]() that looks solid. too bad you can't do that with the JDM projectors. those look even meaner than the BMW's.
OT - Embarrassing pic of coworker, wife's evil plan | BiG 10 | Off-Topic | 18 | 10-06-2006 09:28 PM |
yet another new car thread (56k avert your eyes) | shikataganai | Off-Topic | 37 | 08-28-2006 01:15 AM |
TURBOXER Detailed! (56K watch your eyes) | TURBOXER | Member's Car Gallery | 34 | 07-12-2006 09:41 AM |
see, videogames DO make people violent... (roll eyes) | RaceCarRiot | Off-Topic | 17 | 08-09-2004 01:36 PM |
request pics of WRB (bug eyes) w/18" Tarmac IIs | datdudedennis | Member's Car Gallery | 3 | 05-05-2004 11:31 AM |
