Welcome to the North American Subaru Impreza Owners Club Saturday August 18, 2018
Old 04-20-2018, 05:43 PM   #3351
ITLXLR8
Member#: 394523
2018 Wrx
Originally Posted by hagerbombs View Post
I haven't checked this forum since I did my first oil change on my new '16 WRX. At that time Mobil 1 ESP or Pennzoil Ultra Platinum were determined to be the two best and I have been using Mobil 1 ESP ever since, changing it anywhere from 3-4k. I have yet to ever to an oil analysis on it, but I haven't had any issues with it. I'd same I'm fairly tame when I drive. I drive fast, but I don't break into boost much unless I need it (after the oil is hot enough).
I was just checking back to see if there were any new oils that have performed better than the Mobil 1 ESP that I've been using?
Sometimes the less you know the better. As things like this may make someone paranoid.
I'm no expert but as long as you change your oil religiously, then you can run whatever top name brand and have be fine.
Although i would get a UOA done on your current oil, just to see what's going on. Then you can base your future oil purchases/oil intervals according to what the report says. A report is only a guide, it doesn't mean it's the end all be all of your engine's health. Not to mention blackstone has been known to make mistakes. So take that into consideration too.
M1 ESP is a good oil. Then again i might be biased because all my cars have M1 in them.
ITLXLR8 is offline   Reply With Quote
Old 04-20-2018, 07:14 PM   #3352
bluesubie
Member#: 767
04 FXT
Default 2015 WRX Used Oil Analysis Thread
I agree with ITLXLR8. I would never use uoa’s to determine which oil is “better” but a new and possibly lower priced option is API SN Shell Rotella 5W-30 Multi-Vehicle. It’s available through NAPA and O’Reilly’s.
Another reduced SAPS option coming soon will be Mobil 1 0W-40 ESP which is the factory fill for the 2019 Corvette. Oddly enough though the HTHS of 5W-30 ESP is a tad higher.
https://www.bobistheoilguy.com/forum...SP_vs_0w40_ESP
Old 04-20-2018, 07:20 PM   #3353
CoffeeBlacker
Member#: 482592
CoffeeBlacker is offline   Reply With Quote
Old 04-20-2018, 08:58 PM   #3354
ITLXLR8
Member#: 394523
2018 Wrx
I already ordered my fill cap that says mobil 1 0w-40 lol. Even though i do all my oil changes anyway.
Dealer still doesn't have it in stock oddly. I can't wait for this to become readily available. My summer oil change for the C7Z is soon approaching.
Old 04-22-2018, 07:28 AM   #3355
LedDriver
Member#: 451791
2015 WRX
Dark Gray
This is on Motul 8100 X-Cess 5w-40. Considering the viscosity I'm wondering if 10w-40 might be better. I've run the 5w-40 because that's what IAG recommends/warranty.
LedDriver is offline   Reply With Quote
Old 04-23-2018, 08:06 AM   #3356
bluesubie
Member#: 767
04 FXT
I think you’re fine with X-Cess but keep an eye on Fe and Al. If those don’t start dropping soon then you might want to consider the 10W-40. Probably best to go with their recommendation for now to maintain the warranty.
Old 04-28-2018, 08:46 AM   #3357
LedDriver
Member#: 451791
2015 WRX
Dark Gray
Here's the second oil change.
Old 06-24-2018, 12:40 PM   #3358
J_ODIE
Member#: 484302
Default 2017 WRX FA20 UOA: Valvoline 5W40 MST
Thought I would share my UOA running Valvoline 5W40 MST and Subaru black filter.
NAPA had it on sale the month of May and believe it is no longer being produced. Approx 2500 miles on this oil sample and TBN was over 5. Viscosity stayed in the 5W40 range but just barely.
I have enough for 2 more OCs and will try the Valvoline Modern Engine.
https://drive.google.com/file/d/1wpZIXF4owz7ljMsB2bejkZJZEEq1oXST/view?usp=drivesdk
J_ODIE is offline   Reply With Quote
Old 06-25-2018, 06:39 PM   #3359
bluesubie
Member#: 767
04 FXT
https://drive.google.com/file/d/1wpZ...w?usp=drivesdk
Viscosity might be in Blackstone’s “expected range” for a 5W40, but it did shear to a 30 grade. No biggie though.
Old 06-26-2018, 10:52 AM   #3360
wrx12tt
Member#: 108462
2016 WRX
After 36k on Mobil 1 ESP, I switched to Rotella T6 Multi Vehicle 5w30 and this is the first UOA. Same driving habits, mostly highway and stop and go traffic. A few autocross events on the oil. This sample was also sent to Blackstone (with TBN and TAN tests) so I'll update this post when I get those results in the next couple days.
Phosphorus and zinc are flagged as an abnormal amount of additives, but I wonder if they're using RT6 5w40 as a baseline? Oxidation was also a bit worse than the ESP. It seems like the RT6 MV 5w30 also has a higher starting TBN than ESP. Viscosity retention was better than ESP.
wrx12tt is offline   Reply With Quote
Old 06-26-2018, 06:54 PM   #3361
bluesubie
Member#: 767
04 FXT
Oxidation is actually better with RT6 but it’s hard tell if the previous numbers are true oxidation or false readings from possible ester base stocks used in ESP. Looks like good oil!
Old 06-27-2018, 06:14 PM   #3362
Rowrx11
Member#: 338312
Any here with FUCHS Titan GT1 5w40 on 2017 WRX STI stage 2 ? how about this oil ?
Rowrx11 is offline   Reply With Quote
Old 07-04-2018, 09:31 AM   #3363
LedDriver
Member#: 451791
2015 WRX
Dark Gray
Third times the charm. Metals are dropping, I think I'm in good shape.
Old 07-05-2018, 08:06 AM   #3364
bluesubie
Member#: 767
04 FXT
Yep looks good. I’m surprised that viscosity dropped to a 30 grade with a short interval and some make-up oil.
Old 07-05-2018, 06:05 PM   #3365
wrx12tt
Member#: 108462
2016 WRX
Blackstone version of the Rotella T6 MV 5w30 analysis, see post #3360.
Old 07-06-2018, 09:08 AM   #3366
LedDriver
Member#: 451791
2015 WRX
Dark Gray
I have three 5qt jugs of 5w-40 left. Once they're gone I'm going to try some 10w-40.
Old 07-12-2018, 10:53 PM   #3367
Rowrx11
Member#: 338312
....Any?
Old 07-26-2018, 02:16 PM   #3368
anarekist
Member#: 468117
2017 WRX
DMG
looking good! that previous UOA was after some intense canyon carving. thinking of sticking with ESP or just going to a cheaper Mobil1 5w-30. Mobil1 has been meeting the SN-PLUS standard for years in a variety of their oil lines. SN-PLUS standard is oil formulated to help prevent LSPI
anarekist is offline   Reply With Quote
Old 07-28-2018, 10:52 AM   #3369
bluesubie
Member#: 767
04 FXT
Not a huge difference in add packs between the two. Biggest difference is that the SN+ has more magnesium. ESP has low calcium which is good for LSPI and higher zinc which is also good for LSPI.
Old 07-28-2018, 03:40 PM   #3370
nosliwrx
Member#: 420514
2015 WRX
I have a bone stock 2015 WRX and my lease is up in a few months. I'm probably going to purchase the vehicle because the residual ($17300) is too good to pass up. I have only used Subaru 5W30 full synthetic. As you can see the viscosity continues to come back low, especially this last one. I did the first 3-4 oil changes myself but had subaru dealer do the last 2. I haven't seen subaru 5w30 viscosity come back this low in other UOA. I wonder if they used the wrong oil or this is just normal for subaru oem oil. I plan to to change all the fluids very soon using Motul for both trans/diff and engine. Appreciate your thoughts!
nosliwrx is offline   Reply With Quote
Old 07-30-2018, 01:14 PM   #3371
bluesubie
Member#: 767
04 FXT
If I did it correctly on my phone, there’s at least one other uoa on the Subaru oil in the spreadsheet in the first post in this thread where viscosity dropped to under 7.0, so I suppose it’s possible this is Subaru 5W-30. Since most GF-5 oils shear well into the 20 grade range, there’s no way to know for sure what grade they used. There’s also really no way to know if the used oil came from your car or if it was contaminated with other oil or something else.
For anyone that has someone else change their oil and wants a uoa, I’d purchase an oil sample pump. If you run the GF5 Motul that can shear to a 20 grade as well.
