09-17-2018, 09:05 PM | #1 |
Member#: 491571
Vehicle:2003 WRX |
Exhaust questions
I want to apologize for anything in the wrong section, I'm new and still learning my way around the forum. Doesn't help that my browser says "page can't be found" and I have to use Tapatalk, which only displays a few words of the section description. Plus I'm completely new to Subaru's. There's a couple questions tuning related, I added it to my other questions since they relate and for the sake of not having many active threads. I can edit, delete questions, and then place them in the tuning section if desired. Your patience and knowledge is appreciated, thanks!
2003 WRX 5 spd wagon. 177,XXX on body and tranny, 1,XXX exedy clutch, and 70,XXX on motor (from a 05). About 10 days after I purchased I was throwing a CEL P0171. I took it in for state inspection (no emission county) and they found 3 exhaust leaks. The party I purchased from guaranteed it would pass so they put a 3" SS exhaust on, downpipe included, with no cats. When I picked up car it seemed to run so much better. They also checked the lines to see if that's why I was getting the CEL. I'm still throwing the code, would it be a safe bet at this point that it's the A/F O2? It's my understanding that with my model year I don't need a tune with a downpipe, correct? I'm of course now getting P0420. I have a Cobb V3 AP on the way, is there a point to using anti foulers since I'll be able to keep that code from coming up with the AP? I will flash the stage 1 map as soon as it arrives since I've read that it's a benefit even on a stock WRX. If I added a CAI would I just keep the stage 1 since a tune wasn't necessary for the downpipe or will I need to use a different map? The car has the stock 03 up pipe with the cat still, I've read this is not good and I need to gut it or replace before it destroys the turbo. What's a quality up pipe that doesn't break the bank and is there different diameters to chose from, if so do I stick to stock size? Will a 06 STI up pipe fit my vehicle?, I feel I've seen this question somewhere. Is a tune needed for an up pipe?
09-17-2018, 09:34 PM | #2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
No tune needed for the up pipe. STi up will fit and allow you to keep EGT sensor though they can break apart and kill the turbo as well. OE diameter is better for spool. Larger is only needed for high hp applications. GrimmSpeed is a solid choice that's not too expensive. Check classifieds section. Up pipes turn up all the time. Ceramic coating or up pipe blanket will help spool as well.
People say you don't need the tune with 02/03 MY but I don't trust that personally. If you have an aftermarket turbo back (down pipe and catback) I'd flash a stage 2 map since that is designed for the extra flow a down pipe offers. Cobb is very specific about what intakes can be used with their maps. Outside their parameters you would need a pro tune. Before you buy an intake figure out what ones are supported with which OTS maps. Make sure you stay within the parameters of that map. Never used anti foulers when I was using an AP. |
09-18-2018, 03:05 PM | #3 |
Member#: 491571
Vehicle:2003 WRX |
Does anyone know what the stock uppipe diameter is for an 03? Tried searching and there's tons of threads on uppipes but can't find the answer for stock size. Also is hks a good uppipe?
09-18-2018, 04:06 PM | #4 |
Member#: 462785
SWIC
Vehicle:2016 WRX WR Blue |
exhaust gaskets
Every time I take off exhaust parts on my 2016 WRX to do work, I always put new gaskets on when re installing exhaust. Is this the right thing to do at all times?
09-18-2018, 04:29 PM | #5 |
Member#: 459312
Vehicle:2004 WRX Wagon Hybrid 6MT Swapped WRB |
Exhaust questions
The up pipe should be around 2.25-2.50 inches but in 03 you have a catted uppipe so there’s a large portion that is catted and this bigger in diameter
Go with the above and get a catless and retain the EGT sensor I opted for an invida one it to allows you to keep the EGT |
09-18-2018, 04:29 PM | #6 | |
Member#: 395793
HKS is fine. They make descent parts. Generally if an up pipe isn't close to OE size then the company making will say its larger in the product description. |
09-18-2018, 04:31 PM | #7 | |
Member#: 395793
Exhaust questions
Not a bad thing to do. If it's one that I have replaced very recently or a GrimmSpeed 2x thick gasket less then 2 years old I do t replace it. But otherwise yes. Last edited by snow_bound26; 09-18-2018 at 06:49 PM. |
09-18-2018, 06:39 PM | #8 | |
Member#: 491571
Vehicle:2003 WRX |
09-18-2018, 06:41 PM | #9 |
Member#: 459312
That’s up to you seems like a small chance to me I kept mine and this is the first I have heard of it
09-18-2018, 06:47 PM | #10 |
Member#: 491571
Vehicle:2003 WRX |
Thanks, I've been looking at the hks and invidia bc they can be found under $150, anything has to be an improvement over the cat uppipe.
09-18-2018, 09:27 PM | #11 |
Member#: 491571
Vehicle:2003 WRX |
I talked to the party I bought the car from and they have an aftermarket uppipe without the cat. They said it would be $160 parts and labor so I think this is my best option. I need a lift lol I'm use to working on my own vehicles but I can't even slide myself under it, even hard to up on ramps but I'm able to do some things with them.
09-18-2018, 09:33 PM | #12 | |
Member#: 395793
Get jack stands. I recently swapped my engine and trans by myself with the car on jack stands. Although I just lose the crawler if it's on ramps. Just takes a little creativity and you can do a lot with what you have. That said, getting the catted up pipe out is a PITA. I did it without jacking up the engine but it wasn't easy. Once out, the new one goes in very easy without the cat in the way. |
09-18-2018, 10:19 PM | #13 |
Member#: 491571
Vehicle:2003 WRX |
I have some jack stands, idk but they make me nervous (as well as jacks) but I do use them at times. If they were asking a lot for parts and labor I would of purchased online and figured out how to do it myself but the price they are asking seems more then fair. Really great group of guys, pretty much all they do is work on WRX's and other turbo vehicles.
Being the uppipe is being swapped for a catless and the rest is a cat delete, will I have any issue passing state inspection (non-emissions area) being completely catless? Is there any reason (besides environmental) that I should buy and add a cat? I'm not sure if the uppipe they will be installing has a EGT bung or not. I'm going to pick up an oil drain bolt just in case before I drop car off. I'm assuming I won't need to add a resistor since my AP will be here tomorrow and I'll be able to shut off the code along with the cat code. Last edited by chris16371; 09-18-2018 at 11:43 PM. |
09-19-2018, 01:21 PM | #14 |
Member#: 491571
Vehicle:2003 WRX |
Well I just took it in for inspection again and failed for not having all 3 cats, guess I'm going to need to find someone that isn't as strict.
09-21-2018, 12:12 PM | #15 |
Member#: 491571
Vehicle:2003 WRX |
So I had the catless uppipe installed yesterday and they also put an aftermarket BOV on for free. They said if I dont like the BOV that they would put the stock one back on, idk if I can really tell the difference.
I also got my AP installed with a stage 1 map, definitely improved some things. I was watching the different monitors on my way to work and I have a concern. First of all the P0171 is still coming on, they tested the volts of the O2 and they said it was good. The A/F Correction is what my concern is. On a normal flat driving it's running around +14 to +15, letting off gas while going down hill I'm reading 0, starting out from a stop or accelerating up a hill (even a small incline) it's jumping up to +20 to +25, at a stand still idle I'm fluctuating between -1.76 to +2.34 with spikes to -3 to +4 (rarely) but average seems to be -.78. Do these numbers seem right? |
09-21-2018, 08:04 PM | #16 |
Member#: 483821
Vehicle:2004 WRX 2.0 18g |
Buy a used STI catless uppipe or $40 ebay special they work fine, if the smog station is strict you may need to hollow out your current uppipe so it looks catted. Get rid of the BOV today! If it is recirculated it might be ok but really there is no reason to upgrade OEM BPV ever unless you are full race car or speed density, but even then I would always recommend to recirculate.
If you have a second car to rely on for daily I would highly highly recommend returning that AP and getting an opensource pro tune after you install all parts you will use. Take the car off the road....install everything then limp over to a pro tune, it is so much safer than AP if you have a good tuner. 400 crank hp is daily driveable with a pro tune and supporting mods, with an AP I wouldn't push it that far. Get an AEM wideband and boost gauge and you are good to go. Disclaimer: it doesn't matter what state you are in, removing functioning cats is a federal no no, everything said above is for entertainment purposes only. |
09-21-2018, 08:05 PM | #17 | |
Member#: 483821
One more thing....your AF ratios will never be right with a blow off valve, it cracks open under vacuum and lets in unmetered air. |
09-21-2018, 08:39 PM | #18 |
Member#: 491571
Vehicle:2003 WRX |
It's a Turbo XS recirculating BOV, runs the same as the OEM as far as I can tell.
I already have a catless uppipe on, installed yesterday. I drive 100 miles round trip 5-6 days a week, I bought this car bc I needed a daily driver with good fuel economy. I didn't want to do any mods but when the exhaust broke and the party I purchased from said the only exhaust they have were 3" catless and it would be free including installation what was I suppose to say, that I will buy a different one out of my pocket instead lol? I'm getting 26 mpg with the 3" downpipe, that was before the tune. Will calculate what I'm getting with tune after my gas goes down since I just filled it. Driving my 12-14mpg truck 100 miles round trip 5-6 days a week isn't an option. The only other thing I may do is add the Cobbs intake & box. There's literally no one within 100s of miles from me that does pro tunes. Ik they are better but being an 03 doesn't require a tune with a dp and neither does the Cobb's intake/box I figured a stage 2 tune with those 2 mods would be good enough, not ideal though. My biggest concern is the P0171 lean bank 1 I've been getting pretty much since I started driving it, I need to find the source. The O2 voltage was checked, MAF cleaned, and I'll be doing the smoke test for vacuum tomorrow as well as find the source of the coolant leak that causes heavy smoking after more aggressive driving. If I can't find a vacuum leak I guess I'll buy a new MAF unless there's a way to check those, after that I guess it would have to be O2 related. |
09-22-2018, 12:11 AM | #19 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
Trouble ahead dude, it’s only a matter of time. If you already have an aftermarket down pipe go ahead and flash stage 2 for the correct fuel grade. It will actually be more fuel efficient. Keep the stock air box, make sure it is sealed properly. When the front tabs on the lower half are broken the box will not seal properly. Take the money you would waste on a Cobb air box and intake and put it towards oem o2 sensors and maf.
09-22-2018, 01:03 AM | #20 |
Member#: 375462
Vehicle:2006 Impreza WRX STI WR Blue |
09-22-2018, 09:45 AM | #21 |
Member#: 491571
Vehicle:2003 WRX |
How many psi do I push in when checking for a vacuum leak?
09-22-2018, 10:38 AM | #22 |
Member#: 395793
If you have a boost gauge it should read -20psi give or take 1psi at warm idle. Otherwise you can let the car idle and spray a little carb cleaner around the vac lines. Change in rpm indicates boost leak. This has worked for since I don't have a way to pressure test. |
09-22-2018, 11:07 AM | #23 | |
Member#: 491571
Vehicle:2003 WRX |
09-22-2018, 03:26 PM | #24 |
Member#: 459312
Buy a regulator to up the pressure slowly at the tool I used a paint gun regulator I test to 25 psi on my car with a target boost of 21
09-23-2018, 01:11 AM | #25 | |
Member#: 491571
Vehicle:2003 WRX |
So I want to hook the tool to the intake and then slowly add air, not to exceed 25 psi? |
