Welcome to the North American Subaru Impreza Owners Club Sunday September 19, 2021
Old 08-12-2006, 01:03 PM   #1
vica153
Member#: 76586
2006 9-2x Aero
Default Cruise control from 93 SS into 95L
I'm installing cruise crontol from a 93 SS into my car and I can't seem to find all the plugs for the module.
There are 2 white plugs on the module, and 2 small modules attached to it (4 prong, one black one blue)
I found the one of the whiteplugs and I think the black one. But I cant find the other white one. And I found a blue plu but its 2 wires not 4.
If I have to get the correct module for my wiring, will it work with a 93 SS engine?
vica153 is offline   Reply With Quote
Old 08-12-2006, 02:13 PM   #2
avk
Member#: 17252
'06 WX8
59E
A c.c. from Legacy will not plug in because it uses an electric vacuum pump while Impreza uses manifold vacuum (which might not work so well with forced induction). The wiring is not the same.
avk is offline   Reply With Quote
Old 08-12-2006, 03:47 PM   #3
vica153
Member#: 76586
2006 9-2x Aero
So if I buy the impreza module, would it work with the electric pump from the legacy?
Old 08-12-2006, 04:21 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
The impreza module will not work with the legacy parts--If i remember correctly, Subaru has some of the older cruise control kits on blowout sale. You might check with your local dealer on the price of the complete kit.
SubeTek is offline   Reply With Quote
Old 08-12-2006, 06:23 PM   #5
avk
Member#: 17252
'06 WX8
59E
I suppose you can connect the vacuum hose from Impeza actuator to the pump instead of the manifold. The pump will have to be wired in to run when c.c.'s on which shouldn't be difficult. But if no one has tried it before, there might be a problem or two before you get it to work.
Old 08-12-2006, 07:30 PM   #6
vica153
Member#: 76586
2006 9-2x Aero
All the cruise control stuff I have is off the 93 SS. Actuator, pump, module, switch, control, cable...everything but the wiring.
So will the 95L module work with all that 93SS stuff?
Oh and what are the 2 things attached to the 93ss module?
Old 08-12-2006, 10:56 PM   #7
avk
Member#: 17252
'06 WX8
59E
The Impreza has wiring for its own system (very cheap to buy now in a kit, as SubeTek said) and the plugs are not the same as you already know, except maybe for the dashboard switch. The controller uses a single white plug (16 or 20 pins, can't remember off-hand) and in the engine compartment there's a 4-wire plug for actuator, taped to the harness near AC lines at the bulkhead.
That plug is all you have to work with. You'd need to look at a Legacy wiring diagram to see if the plug can be used to run a Legacy pump and actuator. I have a '95 Impreza diagram, in case it might help. The two things you're asking about are probably relays, or relay sockets, although I haven't seen a control module from a Legacy. They aren't used on the Impreza.
Old 08-13-2006, 01:45 AM   #8
vica153
Member#: 76586
2006 9-2x Aero
I already wired the plug in the engine bay. The plugs are different, but the wires looked all the same.
Were all the 93-01 Manual trans module the same? Just 93-96? Or just 95?
Old 08-13-2006, 02:00 AM   #9
avk
Member#: 17252
'06 WX8
59E
So the wire colors were the same?
The modules for 1.8 l (like a '95 MT would have) were probably the same between years at least prior to 1996 but you'd need to check. If you want to buy new, it's much cheaper to get the whole kit.
Old 09-07-2006, 11:50 AM   #10
vica153
Member#: 76586
2006 9-2x Aero
Can you actually get the kit anywhere now?
And does anyone know if the module for my 95 would actually run the 93 SS pump and things correctly?
Hazards, horn, and cruise control dead on 93 Impreza Dodge Aries K Electrical & Lighting 1 11-05-2009 02:13 PM
EJ22T into 93 L Wagon 5spd/EJ22 into 93 SS auto swap. WagonMafia01 Subaru Conversions 13 06-01-2009 02:51 PM
diy! cruise control mod! 07 sti into 04 ts! antho! Electrical & Lighting 0 02-24-2009 12:48 AM
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 07:30 PM
Cruise Control into a 99 OBS 5mt???? opious Electrical & Lighting 5 07-05-2006 11:26 PM
