Welcome to the North American Subaru Impreza Owners Club Saturday September 25, 2021
Old 11-23-2002, 04:01 PM   #1
wrx2sti
Member#: 24128
2002 WRX Wagon
Metallic Silver
Question Standard Headlight to JDM (Non-HID) Headlight
does it requires some mods? from the way i see it.
the standard headlight has 3 wires, signal light, dimmer light & head lights combines with the High beam....
the JDM (Non-HID) has 4 wires, signal light, dimmer light, head lights and the high beam which is not connected..
correct me...
wrx2sti is offline   Reply With Quote
Old 11-23-2002, 07:00 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
this has been covered many times... there should be lots of info if u do a search.
or u could go to http://www.jimhoyd.com
Benjamin Tang is offline   Reply With Quote
Old 11-25-2002, 02:16 PM   #3
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
it's not hard. like ben said, do a search and you'll have more than enough info to do the job.
eric m. is offline   Reply With Quote
Old 11-27-2002, 11:38 AM   #4
wrx2sti
Member#: 24128
2002 WRX Wagon
Metallic Silver
i did run a search.. but doesnt specify my problem. thanks 4 the link. if any doubt comes.. i'll ask again.
Old 11-27-2002, 01:25 PM   #5
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
wrx2sti,
You've got it all wrong.
Standard headlight has 2 plugs:
1 9007(3-wire) for the HI/Lo beam and
1 Generic plug for the blinker.
"JDM" Non-HID headlights (and JDM HID headlights) have 3 plugs:
1 9005(2 wire) For the high beam
1 H1(2 wire) for the low beam
1 Generic plug for the blinker.(same as stock)
The High beam and the Low beam on the "JDM" lights need to share a common ground from the 9007 plug coming from the car. Then they use their individual power wires from the 9007 plug for their power connection.
Zahnster is offline   Reply With Quote
Old 11-27-2002, 01:38 PM   #6
wrx2sti
Member#: 24128
2002 WRX Wagon
Metallic Silver
oh, ok... thanks for that.. i took off my head light off the car.. and found 3. one more is the small light (parking light).
from what i found again. the jdm headlight, the highbeam and the parking lights are in the same place(u noe what i mean, share the same reflector) then the low beam, then the turn light.
ok.. from the link, really gave me a idea..
thanks.. ya all... for the great help, advice and corrections.
merry christmas & have a wonderful upcoming new year..
JDM Non-HID Headlights krazedant Interior & Exterior Modification 4 08-06-2002 04:17 AM
what bulb does the jdm non hid headlight use. STEALTH-WRX Interior & Exterior Modification 4 07-01-2002 04:36 PM
JDM Non-HID Headlight adjustement zacek Interior & Exterior Modification 1 06-04-2002 09:38 PM
JDM non-HID headlight conversion... KillerRex Interior & Exterior Modification 2 02-25-2002 11:54 AM
WRX JDM non-hid headlight part number DarthChicken Interior & Exterior Modification 3 01-25-2002 12:57 AM
