01-30-2009, 12:19 PM | #1 |
Vendor Sales Rating: (26)
Member#: 67199
Vehicle:07 8.8@171mph STI 97 RS 8.3@165mph |
3 Day Freeze Sale, Service and Parts!!!
If your in the mid-west and you are in this HORRIBLE WEATHER, than you know that your ride needs to be maintained. Come on in for our 85.00 dollar special to ensure that your car is running right.
We will make sure that your car is ready for the cold weather with these services... - Pre Dyno Inspection . - Checking and topping of of fluids. - Checking tire pressure, Rotation of the tires. - Checking over all structure of brakes, suspension, and tires. - Conventional 5w30 oil change (add 15.00 dollars for synthetic). - Inspecting mechanical systems under hood for any possible failure points. Give me a call or shoot me a pm...limited opening available!!! 847-678-4311 ask for Mark!!! Dyno Services and Tuning Dyno Tuning with Jorge w/ EMS - $199 per hour (AP tunes estimated at 1 to 1.5 hours) Dyno Tuning with Jorge w/ Open Source - $199 per hour (estimated at 1.5 - 2 hours) Dyno Baseline - 2 wheel drive, 3 pulls with wideband o2 AFR printout - $80 Dyno Baseline - 4 wheel drive, 3 pulls with wideband o2 AFR printout - $110 Dyno Rental - 2 or 4 wheel, unlimited pulls with wideband o2, priced per hour - $140 Fabrication and Porting Roll Cage Fabrication - $2999 (6 point, includes chromoly piping and materials) EWG Flange Welding - $199 (install an EWG flange on your GTspec/etc. header) Stock Exhaust Manifold Hand Port - $149 Turbo Internal Wastegate and Volute Entry Hand Port - $149 TGV Delete and Housing Hand Port - $149 Service and Labor Clutch Installation 5spd and 6spd - $399 5spd Rebuild and/or Gear set Install - $449 Fuel Pump Install (02-07 WRX/STI) - $95 Fuel Pump Install and Housing Modification (08+ WRX/STI , 05+ LGT) - $249 30k Service - $361 60k Service - $560 90k Service - $361 Turbo Back Exhaust Install (02-07 WRX/STI) - $95 Corner Balance - $300 Front and Rear Brake Pad and Rotor Swap - $228 Oil Change (oil provided by customer) - $10
__________________
[B]P&L Motorsports[/B] p: 847-678-4311 e: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIGPIC][/SIGPIC] Last edited by P&L Motorsports Inc.; 12-11-2009 at 07:59 PM. |
Similar Threads | ||||
P&L Motorsports Service / Fabrication / Labor Pricing and Specials | P&L Motorsports Inc. | MWSOC Vendor Classifieds | 67 | 10-27-2009 02:34 PM |
P&L Motorsports 2007 Calendar ! Sexy ladies and HOT cars! | P&L Motorsports Inc. | Accessories & Misc | 13 | 03-12-2007 01:29 PM |
P&L Motorsports 2007 Calendar ! Sexy ladies and HOT cars! | P&L Motorsports Inc. | MWSOC Vendor Classifieds | 4 | 12-15-2006 07:06 PM |
