Welcome to the North American Subaru Impreza Owners Club Wednesday September 18, 2019
Old 07-21-2019, 12:50 PM   #1
NewHouseTM
Member#: 464863
Default STi 2014 Cruise Error 64
Hi
Recently I got a car that has ERROR 64 (Engine Sensor Failure 1). I check it with FreeSSM.
But there is no Engine CEL codes...
There are only two mods in the car
Forged CP pistons and Catless downpipe.
I already check every sensor in the car and seens to be working fine.
The problem happens when traveling around 100 km/h with constant speed and constant throttle, then it simple turn on the check engine light.
Before the check engine lights come on the cruise control works fine.
What could it be?
NewHouseTM is offline   Reply With Quote
Old 07-21-2019, 05:19 PM   #2
hrbutler52
Member#: 295691
Blue Mica
DTC P0064 is for the heated O2 sensor. Google search gives https://www.obd-codes.com/p0064. The cruise being in-operative with the CEL on is normal for this car.
hrbutler52 is offline   Reply With Quote
Old 07-22-2019, 12:26 AM   #3
NewHouseTM
Member#: 464863
In another words it should have a catalyst to turn of the cel light.
Will it be ok if I put the o2 sensor outside the exhaust?
Old 07-28-2019, 04:54 PM   #4
hrbutler52
Member#: 295691
Blue Mica
Does your catless down pipe not have the O2 sensor installed? If no sensor is installed your tuner can reset ECU parameters to not store the code and trip the CEL. Putting the sensor out side the exhaust would result in it running cold and the problem would probably persist.
Old 08-05-2019, 01:26 PM   #5
NewHouseTM
Member#: 464863
I already disabled the errors on the ECU, but this error appears on the cruise control module.
