07-13-2018, 07:22 PM | #1 |
Member#: 488297
2018 STI p0441 Help!!
Heres the mod list
-cobb flex fuel kit, fuel lines, rails -1050x injectors -cobb ss turbo back, with catted downpipe -Aem fuel pump -cobb sf in take, and inlet -tomei headers and uppipe -IAG tgv deletes -IAG Street AOS So after installing all those parts and reflashing with a base map supplied by my tuner, after about 20-30 miles I throw a P0441 code, it won't throw a check CEL until about 60 miles. I have replaced the purge solenoid, checked and replaced all vacuum lines that connect to it but I still have the P0441 code. I'm stumped with this code! I don't have a rough idle and it it seems like I have no vacuum leaks, idle seems normal. ANY HELP would be appreciated Ive been trying to figure this out for a week and some change and now my tune is coming up and I want to be 100% fixed before that!
07-14-2018, 04:16 PM | #2 |
Member#: 349542
Can't find much for 2018 so this is from a 2015 STI. There are 2 purge control solenoids on the manifold, although the code isn't specific to either one it just has you check both for a fault. Unless they were broken or damaged somehow during the parts install it seems unlikely they would fail, so double check the lines going to them for any cuts/damage. Also check that the lines are going to the correct ports on the solenoids.
Subaru lists solenoid 1 as the one with a triangular shaped bracket that mounts with a bolt, I think it's lower down behind the p/s pump. https://imgur.com/a/jYtewcw Solenoid 2 is higher up above solenoid 1, it has a threaded stud at the back and mounts with a nut. https://imgur.com/a/qLlL91Q Last edited by blue wrench; 07-14-2018 at 04:23 PM. |
07-15-2018, 05:15 PM | #3 | |
Member#: 488297
07-16-2018, 02:55 PM | #4 | |
Member#: 488297
