01-22-2009, 02:10 AM | #1 |
Member#: 142335
Curve Fit Test Data on Breathing Capacity of Stock '07 STI
From acquired data on 2007 STI for boost > 1 psig (882 of 38313 data points using Ecutek DeltaDash):
RPM: 1800 to 6800 rpm, PSIG: 1.0 to 18.0 psig PPM = ( a + b*RPM + c/PSIG + d*(RPM^2) + e/(PSIG^2) + f*RPM/PSIG )*PSIG a = 2.3624697745957365E-02 b = 1.7202030655447530E-04 c = -2.8041056560228700E-01 d = 1.0516747850613378E-08 e = 3.0268800278786051E-01 f = 2.6850163893927669E-03 Example: Find approx. required CFM to achieve 14 psig boost at 4500 engine rpm. For 14 psig @ 4500 engine rpm: PPM = 26.0 lb/min, CFM = 340 cfm ((26.0 lb/min)/(0.0765 lb/ft^3), @ 59 degF & 14.7 psia) Note: Use at your own risk.
01-22-2009, 02:48 AM | #2 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
If I'm reading this correctly, you've basically come up with an equation that provides VE (though measured in lb/min) at a given RPM and manifold pressure?
Is there a reason to prefer this approach over a VE table, with manifold pressure on one axis and RPM on the other? With a VE table it's much easier to visualize what's going on. Is there something you're trying to achieve next, once you feel confident about this? |
01-23-2009, 02:23 AM | #3 |
Member#: 142335
Re: Curve Fit Test Data on Breathing Capacity of Stock '07 STI
Another way to look at it, is the pressure restriction the engine poses to increasing the air intake mass flow rate. The objective is to make it easier to calculate an operating point for a new compressor, given a compressor map. The supplied equation works nicely in an EXCEL spreadsheet. Besides, where does one find a VE table for an '07 STI available online?
01-23-2009, 02:36 AM | #4 |
Member#: 140444
NWIC
Seems to me it should be possible to come up with a VE table with lots of logs and some Excel. This software almost does it... if you could be sure you were at the same temp all the time it would probably be trivial to turn its "VE" table (which is really a g/s table) into the real thing.
01-23-2009, 09:07 AM | #5 |
Member#: 145145
Vehicle:2006 wrx STi |
Is there a temp correction anywhere in there? neat stuff.
01-23-2009, 09:10 AM | #6 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
VE = 5660*CFM/(L*RPM*(psig/psia+1)) your equation gives you CFM from RPM and psig, so with a few little modifications it could give you VE instead. |
Capacity of stock 04-07 STI ic spray tank? | unclemat | Water/Methanol Injection, Nitrous & Intercooler Cooling | 6 | 09-11-2008 12:22 AM |
What is the torque capacity of stock 2005 WRX clutch? | Carlito2002WGN | Newbies & FAQs | 2 | 09-05-2008 02:15 PM |
Crushing the BOV for 30 WHP on 440 WHP 440 TQ '07 STI FP Green on Alchy | Dyno Flash | Proven Power Bragging | 81 | 12-13-2007 01:24 AM |
Passion and Power with a Stock '07 STi - Ecutek tuned | Dyno Flash | Proven Power Bragging | 50 | 08-13-2007 11:00 PM |
Some pic's of my '07 STI Limited #028/800. | nxttruck2002 | Member's Car Gallery | 58 | 11-03-2006 01:26 PM |
