Welcome to the North American Subaru Impreza Owners Club Wednesday May 18, 2022
Old 12-01-2021, 11:03 AM   #1
jayhawke499
Member#: 524736
2010 STI
Default Aquamist HFS3 Kit with Innovate Failsafe. Options for set up?
Hello all! I'd like to start some conversation around how I should set up my kit and maybe end up with a blueprint that others can follow. I have searched and found a couple of threads with set-ups that I like the sound of, but they are either old, don't have pictures anymore, inconclusive, etc.
Background, I have a 2010 STI, an Aquamist HFS3 kit and I will be using an Innovate PSB-1 failsafe. Tuning via Accessport V3, I am not married to any one tuner. Planning on running 80/20 WMI, probably just approved windshield washer fluid.
I have not begun installing any of these components yet, so I am an open book in terms of suggestions for setting it up. I found the Aquamist wiring diagram for how they suggest setting it up which I am not totally against using if this other idea does not work out.
The other idea in question: I found discussion of a member who hooked up the Aquamist flow sensor output to an auxiliary input (TGV sensor plug a la Cobb flex fuel, 5v for 100% WMI flow and vice versa for 0V). I am a big fan of that idea as it allows me to have a blended 93 and 93+wmi map without having to switch maps manually or worry about variations in flow. And then I would add on the Innovate PSB-1 as an extra failsafe based on the boost pressure and target AFR of my tune. As I mentioned before I am not super worried about getting a tune for this setup, if I present this setup to a prospective tuner and they do not like the idea I will just find someone else who can work with it.
Now is where I turn to the good citizens of NASIOC who are far more experienced than I. I am lost on the execution and if it will work exactly as I imagine. I know it will involve add-a-circuits, extensive wiring, etc etc but I am up for that challenge. If anyone has experience, thoughts, wiring diagrams(?????), tuners who have experience with this setup or is just generally interested in this approach let me know! Thanks guys!
jayhawke499 is online now   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
