Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-08-2018, 11:53 AM   #1
RP31
Member#: 123574
2005 STi
CGM
Default UTEC reset at crossover?
Finally got my car running again after being down for a few years... Driving it around I notice if I stay under the throttle position crossover, things are fine. But as soon as I push the throttle enough for the UTEC to take over, the car bucks and leans out and is undriveable. Getting home was a struggle.
At first I figured it was just the tune or a leak, but I started logging from the UTEC and every single time this happens, the logging switches from logger view #1, back to the main UTEC screen, like the UTEC resets itself. This makes no sense but if the bucking and lean out is a symptom of the UTEC resetting for some reason, then maybe it does make sense. I am using Putty to connect to the UTEC. Logs are fine otherwise and only reset when this happens. I don't think it is a connection or software problem.
Any ideas?
RP31 is offline   Reply With Quote
