Welcome to the North American Subaru Impreza Owners Club Monday January 24, 2022
Old 11-27-2021, 08:41 AM   #1
teamslow
Member#: 523852
Default Considering buying an 05 sti that has 2 issues that make me a bit nervous...
Last time i posted up askin for opinions on a car I was buying I appreciated the input, but the car turned out to be much worse than the ad made it seem so I bailed.
Now im looking at another one that's in not the greatest shape but may end up priced accordingly. There are 2 issues that i think could be signs of real costly repairs.
Shifting into 5th i noticed that the stick will easily go past 5th (to the right), but doesnt have any issue going into 5th once you find it. Im wondering if this is likely an issue with the shifter assembly/bushings and not the actual trans?
the other issue is a whine that based on my googling could be pinion bearings in the front diff. you only hear it when you clutch in and are slowing down, its not loud, but like most noises i suspect it will get louder until something eventually breaks and causes damage...
any thoughts appreciatized...
thanks
teamslow is offline   Reply With Quote
Old 11-27-2021, 10:41 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
When there's that much slop in the shifter it's probably the roll pin in the gear selector shaft. It's a PITA ass to get to, but you can replace it with a bolt and nut rather than using a new roll pin. If that doesn't fix it then it's more likely internal. I had this issue when swapped an 05 6 speed into my car. Replacing that reduced slop by 50%. But unfortunately I'm finishing out my trans was more neglected/mistreated than I had hoped. I would still replace the bushings, just don't expect them to reduce movement like that very much.
As for whine, the STi gears are helical, but still quite aggressive and have a bit of whine to them normally. Without being in the car it's going to be hard for any of us to say if it's excessive or not. Do you know if the current owner has replaced any of the driveline bushing with stiffer options? This will make the whine more pronounced.
snow_bound26 is offline   Reply With Quote
Old 11-27-2021, 12:06 PM   #3
xtremewlr
Member#: 525652
2006 STI
WR Blue
Yeah, I agree with @snow_bound26, the 6 speed STI trans is naturally whiny, especially in the GD chassis. GDs seem to have less sound deadening material than the newer cars. You will mostly notice it at slower speeds. But, they are extremely strong transmissions, especially compared to the glass-like 5 speeds. I think what you are feeling with the shifter is just play in the shifter bushings and maybe not being used to the 6 speed transmission shift pattern. If it goes easily into all gears, then it's not a concern. New shifter bushings should clean most of that up and is something you could do yourself. Change the gear oil as well and that trans should be fine.
xtremewlr is offline   Reply With Quote
Old 11-27-2021, 12:32 PM   #4
teamslow
Member#: 523852
thanks a lot for the info! I did some googling on what you guys mentioned and i think im gonna make an offer and see what happens
thanks again!
Old 11-27-2021, 12:34 PM   #5
xtremewlr
Member#: 525652
2006 STI
WR Blue
thanks again!
Good luck!
Old 11-27-2021, 12:34 PM   #6
K3rm1tth3fr0g
Member#: 508105
2002 WRX - Link ECU
being installed :)
I'd get a pre purchase Inspection by a shop who knows the WRX/STi.
They'll likely be able to tell you if the whine is normal. The stock 6MT with OEM clutch and flywheel does not whine that much. The 5mt whines a lot more in my experiences
K3rm1tth3fr0g is online now   Reply With Quote
Old 11-27-2021, 12:41 PM   #7
xtremewlr
Member#: 525652
2006 STI
WR Blue
While I haven't driven a GD WRX with the 5MT, my 06 STI 6 speed is pretty loud at slower speeds. It shifts perfectly and doesn't have any issues. So I would disagree with your statement on the 6MT not being very loud. It's pretty noticeable, even with a healthy transmission and fresh fluids.
Old 11-27-2021, 01:10 PM   #8
K3rm1tth3fr0g
Member#: 508105
2002 WRX - Link ECU
being installed :)
Every 5mt I've heard has been louder *shrug*
