Welcome to the North American Subaru Impreza Owners Club Monday January 24, 2022
Old 06-11-2018, 11:00 PM   #1
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Default 09 wrx built block garrett 60-1 pump gas
To start please delete if not allowed.
I recently was forced to build the block after spinning a bearing and my shop is kind enough to swap on my rotated kit that i have pieced together over the past 9 months at no additional charge. Its still a 5 speed so im scared to dyno and would like the gurus of the community to use their credentials to give ne a ROUGH idea of what she might put down.
Mods as follows
Wiseco pistons stock bore 8.9:1
Manley h beam rods
Custom machined crankshaft for better oiling
Kelford ti springs and retainers
Garrett t3 60-1 .82 ar stage 3 turbo
HKS equal length headers
Perrin rotated up pipe and down pipe
Tial 44mm ewg
Tial qr bov
Id 1050x injectors (from dan at Boston motorsports, crazy price and connectors for free)
And fuel pump upgraded.
Now, the intention for the car before the bearing going was to have a 400 hp car on 93 that i can still deliver food in. Tune will not exceed 22 psi as i want torque low and to keep the turbo in its efficiency range. Afr will be 11.1-11.2. And elevation for what its worth is sea level.
I have searched for threads on GARRETTS 60-1 but have only found reviews on the kinugawa or 20g versions.
This forum has educated me a ton on our platform to the point i can usually diagnose all my Subie friends problems before they take it to a shop, and for that i am grateful, thank you to all of nasioc
Results were 357 on the mustang setting ( shown in a post below ) and 398 on the Dyno dynamics setting
silversurfer05 is offline   Reply With Quote
Old 04-14-2020, 06:32 PM   #2
silversurfer05
Member#: 366241
Dgm
Long overdue Update
Tune was finalized at 18.5 psi and 10į of timing at 4300 RPM going up to 13į at redline. AFR target is around 10.8. extremely conservative tune due to still being on the stock 5speed. Dyno runs were postponed due to outbreak. Trying to find a way to do virtual dyno but Im not familiar with it. I want to prove my power lol
Old 04-14-2020, 07:22 PM   #3
Waddlz
Member#: 395275
2012 STi
Curious what your power was. my 60-1 was a horrible turbo, that I am glad to be rid of.
Waddlz is offline   Reply With Quote
Old 04-16-2020, 12:27 PM   #4
silversurfer05
Member#: 366241
Dgm
Im dying to find out as well!! Its a garrett stage 3 60-1. Couldnít find a p trim at the time or a t4 kit in my price range so I do wish I at least went with the t67. The 60-1 hits right after 4k which to me is just right but after 24/25 psi ill need to upgrade. But I wonít get there until I swap in a six speed. Iím just hoping to crack 400 on pump, should be doable with some fuel trimming and more aggressive timing.
Old 04-16-2020, 02:46 PM   #5
Waddlz
Member#: 395275
2012 STi
Yeah mine was a Kinugawa td06sl2 60-1 8cm2.
It didn't make 23 psi til 4800 RPMs and made 286 whp, 282 wtq at 20 psi on pump gas 91 at 5500 ft altitude uncorrected.
I almost sold the car after this, but obviously its not a garrett. Update this when you can hit the dyno.
Old 04-18-2020, 04:38 PM   #6
silversurfer05
Member#: 366241
Dgm
The gas and the altitude were definitely contributing limiting factors. I was going to go with a stock location turbo, but wanted the ease of install in case I wanted to go bigger again. And I kind of do want to do that now but should invest in a six speed before I do so for peace of mind. And of course I will. If I knew how to do the virtual Dyno, I would have it done by now haha
Old 04-19-2020, 01:55 AM   #7
tbscamcity
Member#: 508009
2018 WRX STI
WR Blue
Long overdue Update
I feel you there! My car just got off the dyno on Monday... My tuner is still going strong here in Texas.
tbscamcity is offline   Reply With Quote
Old 04-19-2020, 07:31 PM   #8
silversurfer05
Member#: 366241
Dgm
Glad to hear some shops are working through this situation. What did your car put down and what mods?
I personally am about to just order a cheap PC and try to virtual Dyno
Old 04-20-2020, 08:44 PM   #9
pcampbell
Member#: 437670
2005 2.5 SC OB
Default 09 wrx built block garrett 60-1. What do YOU think it will make?
10-13 degrees total timing is way way low. You can probably add 10 degrees.
10.8 is pretty fat too.
pcampbell is offline   Reply With Quote
Old 04-21-2020, 12:41 PM   #10
Waddlz
Member#: 395275
2012 STi
Virtual dyno is easy to use.
make sure the road is flat, and if you're using a 5 speed do your pull in 3rd.
Do your regular pull, for me that was 3500 RPMs to redline and log ONLY that pull.
take the the log file from your AP, and install Virtual dyno. Open the log file with VD, and set your car information.
For instance, this is a VD of my car with the 60-1 on E85.
Old 04-21-2020, 10:09 PM   #11
silversurfer05
Member#: 366241
Dgm
The thing is Iím using ecutek and not cobb so I do need a computer just to log
Old 04-21-2020, 10:13 PM   #12
silversurfer05
Member#: 366241
Dgm
Yeah, I requested it to be conservative because of the five speed, but had no clue as to what the power was. So we definitely could have pushed it further. Iím hoping to get timing to at least 17į at red li yeah, I requested it to be conservative because of the five speed, but had no clue as to what the power was. So we definitely could have pushed it further. Iím hoping to get timing to at least 17į at redline. Tha afr is likely due to to the filter I have being filthy and being restrictive. But will most likely be around 11-2-11.3 when finished. From what I understand there are torque limiting tables on the software my tuner recommended using(ecutek), which should help me quite a bit as I am about to say **** it and send it since i had a close call with an ecoboost with performance pack. Those things have stupid torque
Old 04-21-2020, 10:32 PM   #13
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Do yourself and everyone else a favor, and don't send it .At least get all of your 6mt parts purchased and be ready if it happens. There is always someone faster and some people have sneaky fast vehicles and you don't know until you kill yours trying to race. Besides, you can sell that 5mt to help with the 6mt cost.
2slofouru is offline   Reply With Quote
Old 04-21-2020, 10:45 PM   #14
silversurfer05
Member#: 366241
Dgm
I wont fully send it lmao. But i do want to max it out at the current boost level of 18 psi. We initially tried 21 and inadvertently 26 psi for a race tune and it was more than i could handle haha way over 400 for sure. With these checks coming Ill be able to start putting the swap together hahaha
Old 04-22-2020, 02:24 AM   #15
tbscamcity
Member#: 508009
2018 WRX STI
WR Blue
451/419 on mustang dyno. IAG closed deck with 1.5XTR turbo. Was very happy my tuner is still fully operational. You should give the virtual dyno a try!
Old 04-22-2020, 02:26 AM   #16
silversurfer05
Member#: 366241
Dgm
Im guessing thats on e? Great numbers. If the opportunity arose back around Iím definitely going closed deck
Old 04-24-2020, 01:28 AM   #17
tbscamcity
Member#: 508009
2018 WRX STI
WR Blue
Yeah plenty of e where I live, no way this turbo will break 400 on pump gas. Curious what you end up making with the 60-1. When are you going 6 speed?
Old 04-24-2020, 02:42 PM   #18
silversurfer05
Member#: 366241
Dgm
Keep in mind that mine is the garrett 4 inch inlet version and we are inly at 18 psi. This turbo likes to be in the 20 to 26 pound range so we have barely even started to move any air
We re-tuned last night and added 6į of timing
Old 04-24-2020, 02:43 PM   #19
silversurfer05
Member#: 366241
Dgm
Spaceholder
Old 04-24-2020, 05:25 PM   #20
silversurfer05
Member#: 366241
Dgm
Iím definitely going to need help. I put all the information in and itís telling me Iím over 500 hp Lmaoo
Old 04-24-2020, 05:33 PM   #21
silversurfer05
Member#: 366241
Dgm
Also says 252 hp when I put the second gear log in. Based on the cars I have raced, thereís no way Im making that little.
Old 04-24-2020, 11:32 PM   #22
silversurfer05
Member#: 366241
Dgm
It was done using the STI I was my car for the upload setting. The WRX setting produced the weird numbers for whatever reason. Only difference is my car weighs about 200 pounds less than the listed weight on the app for the STI
Weight is corrected to reflect my cars weight
https://img.nasioc.com/i/1WlqA.jpg
Last edited by silversurfer05; 05-04-2020 at 11:36 PM. Reason: Graph updated with cars correct weight information
Old 05-04-2020, 05:51 PM   #23
silversurfer05
Member#: 366241
Dgm
This is the dynojet graph I just received. I feel the mustang numbers are more accurate but this may help those who don't have a Mustang dyno near them and want to compare results
Old 05-04-2020, 05:54 PM   #24
Waddlz
Member#: 395275
2012 STi
You should take into account how much you weigh also in your weight calculations.
Old 05-04-2020, 11:26 PM   #25
silversurfer05
Member#: 366241
Dgm
The weight and graph have been updated
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
