Welcome to the North American Subaru Impreza Owners Club Wednesday January 19, 2022
Old 06-23-2021, 03:43 AM   #1
umscooby
Member#: 50902
98 GM6
60mm WB
Default '98 Coupe Wide Body Photo Journal - Exterior
Hey Nasioc,
I don't plan on doing a full build thread with loads of boring specs, but here is a little photo history of my '98 RS.
Hope you enjoy!
Body kit pre fitment work complete, running and driving mock up before sending it off to body shop.
Color samples.
At this stage I sent the car out to a body shop that specializes in custom vehicles and has extensive experience with both custom fab a fiberglass.
Some first steps, closing in the rear quarters (inner wheel housings).
They did beautiful fab work on these, note that the flange on the outside is scribed to the inner quarter panel creating another bonding surface for the quarters, not an easy task.
umscooby is offline   Reply With Quote
Old 06-23-2021, 03:44 AM   #2
umscooby
Member#: 50902
98 GM6
60mm WB
Unfortunately missing shots of rear quarters being bonded. These are post bond seam seal photos in the cabin and wheel wells.
More details.
Old 06-23-2021, 03:47 AM   #3
umscooby
Member#: 50902
98 GM6
60mm WB
Lots of blending work here and the tail lights were also pulled out flush to the body.
Old 06-23-2021, 03:51 AM   #4
umscooby
Member#: 50902
98 GM6
60mm WB
Fitting rear wing to decklid.
Body work on roof panel. Note that a carbon roof was purchased but never received, luckily got one of the last three roof panels left at the time. There are no more new OEM roof panels available for these cars.
Antenna delete.
Old 06-23-2021, 03:54 AM   #5
murrdogg24
Member#: 50586
64 Impala
i like it
murrdogg24 is online now   Reply With Quote
Old 06-23-2021, 03:55 AM   #6
umscooby
Member#: 50902
98 GM6
60mm WB
^thanks!
Doors had to be cut for proper clearance over rocker covers.
Back half poly and prime.
Old 06-23-2021, 03:56 AM   #7
umscooby
Member#: 50902
98 GM6
60mm WB
Moving forward and frontward, gapping and flushing of things.
Fenders needed a bunch of glass added on the back side so they could be sanded flush to flow with A-Pillars where they meet.
Old 06-23-2021, 04:03 AM   #8
umscooby
Member#: 50902
98 GM6
60mm WB
Hood
The reverse scoop was a mess.
Old 06-23-2021, 04:04 AM   #9
umscooby
Member#: 50902
98 GM6
60mm WB
Front bumper beams fab'd, and front lip bonded.
Old 06-23-2021, 04:04 AM   #10
umscooby
Member#: 50902
98 GM6
60mm WB
Wheel arches up front had to be trimmed for wheel fitment (18x10 +24). The following photos document the process of making new lips after cutting back the arches.
new lips made from molds
Pre fit
Bonded
Glassed then dura-glassed
Sanded
Fit to vehicle and body work
Old 06-23-2021, 04:05 AM   #11
umscooby
Member#: 50902
98 GM6
60mm WB
Went and visited her today...
Got some adjusting to do on the ol' Stromung when I do the final assembly, in like another year lol. And of course will be grabbing a set of JDM tails.
Can't say enough good things about the body shop and their work.
Old 06-23-2021, 08:28 AM   #12
umscooby
Member#: 50902
98 GM6
60mm WB
Front Inners
1/4 tubs, front inners, call them what you will. Firewall cleanup still to come. Note that car was sent out and remains as a full functioning and full weighted mock-up with the largest wheel/tire combo I will run and ride height set to facilitate proper clearances for fab work and modifications to the body kit. Eventually it will get stripped back down, firewall patched, engine bay and accessories painted, etc.
Car is now headed back to body shop side of the building where the rockers will get installed and body worked which is all that's left before paint. After lots of debating I've decided to cut the rockers at the forward door line to keep the fenders removable.
Cheers,
UM
Old 06-23-2021, 08:28 AM   #13
umscooby
Member#: 50902
98 GM6
60mm WB
saved
Old 06-23-2021, 05:29 PM   #14
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Thumbs up Need a space between images
Originally Posted by umscooby View Post
There's more but I'm getting the dreaded 'upload error' on NASIOC's hosting site... Bummer I can't figure out how/why the server won't accept the photo uploads.
Your photos would present better, and possibly even avoid upload errors, if you'd hit the Enter key twice between image links.
You're doing a great job on the car. Gotta love a '98!
Vancouver98STi is offline   Reply With Quote
Old 06-23-2021, 06:52 PM   #15
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Looking forward to the day I can finally build one of these. Looking good. Looking forward to seeing the progress
snow_bound26 is offline   Reply With Quote
Old 06-24-2021, 12:35 AM   #16
umscooby
Member#: 50902
98 GM6
60mm WB
Originally Posted by Vancouver98STi View Post
Your photos would present better, and possibly even avoid upload errors, if you'd hit the Enter key twice between image links. Like so...
Thanks for the tip and done. The upload problem is with the image hosting site, might try a different one.
Thank you.
Old 06-24-2021, 01:33 AM   #17
Vancouver98STi
Member#: 459287
V4 GF8 White
Question
Hmmm... that's odd. Over the last couple of years since its inception, the NASIOC image host has handled absolutely everything I've thrown at it.
Is there something different about the images of yours that won't upload?
Old 06-24-2021, 01:00 PM   #18
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
Nice work, looks really good!
I've had a ton of issues with the NASIOC image hosting site as well recently with nothing that I can pin down - all JPGs under the size limit.
whozatguy is offline   Reply With Quote
Old 06-24-2021, 05:33 PM   #19
umscooby
Member#: 50902
98 GM6
60mm WB
same
Old 06-24-2021, 08:15 PM   #20
Vancouver98STi
Member#: 459287
V4 GF8 White
same
I've sent you an email.
Old 06-25-2021, 08:53 PM   #21
umscooby
Member#: 50902
98 GM6
60mm WB
Didn't receive, sent pm
Old 06-25-2021, 09:04 PM   #22
umscooby
Member#: 50902
98 GM6
60mm WB
Hope you get a chance soon as finding them in decent condition is getting tough and nearly every interior and exterior trim part is discontinued and no longer available. I purchased every replacement exterior trim piece possible over a year ago, which wasn't everything, and some of those are no longer available today.
UM
Old 06-25-2021, 09:46 PM   #23
Vancouver98STi
Member#: 459287
V4 GF8 White
Thumbs up
Okay, second email sent.
Old 06-25-2021, 11:12 PM   #24
Vancouver98STi
Member#: 459287
V4 GF8 White
Lightbulb Why are there upload errors?
I asked umscooby to email me some images of his that wouldn't upload, so that maybe I could discover something about them that was causing upload issues/errors.
I received three images, and the first thing I noticed was that every image had a different extension... jpeg, jpg and JPG. What this told me was that different methods of acquisition and/or editing/saving were occurring.
This was confirmed when I checked the metadata for each image. One image had no metadata, and the other two had metadata which indicated that two different iPhones had been used to take the photos (6S and SE), and different software (Windows Photo Editor and unknown 13.7) was used to save the images.
All three of these images uploaded no problem to the NASIOC image host after they were imported into my photo editor (IrfanView) and simply re-saved with no further modification.
I suspect there's something funky with the compression scheme being utilized by certain types of photo conversion/editing apps. This may or may not be a problem specific to iPhones (and the way the images are formatted/saved).
It appears the simplest solution to the upload issue here is to find a photo conversion/editing app that doesn't trigger an upload error, and then stick to using that particular program.
Old 06-26-2021, 06:31 AM   #25
Cohick324
Member#: 525106
That's dope. Can't wait to see the finished project
Cohick324 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
