Welcome to the North American Subaru Impreza Owners Club Wednesday June 29, 2022
Old 10-28-2021, 09:50 AM   #1
DylanRay
Member#: 449826
2020 STI
Default Getting 3.5% Wastegate Duty Cycle at WOT and low boost
So I recently did all the mods listed below and I am working with a very good tuner who worked on the car in its stock form. We are currently working on the pump gas tune (93 octane) and scheduled for the dyno E85 tune on 11/8/21. We started to throw some boost at yesterday but it wont go past the wastegate spring rating 13.7psi. I thought maybe the EBCS was plumbed wrong but I double checked it, then I thought boost leak (ordered a tester), but what seems really strange to me is the WGDC is only hitting 3.53%. The WGDC leads me to believe there is another variable thats telling ECU to keep boost low. I have the logs but I'm not sure how to post them here. Any help would be greatly appreciated.
DAM looks good at 1, Baro at 13.2, AFR at 11.03 with wideband in the car too.
CURRENT Mod List all new, car is 2020 STI with 5k miles:
-Cobb SF Intake
-Cobb Turbo Inlet
-Cobb 3 Port EBCS
-ETS Catback Exhaust
-Cobb Bypass Valve
-Cobb Flex Fuel Sensor
-Cobb Fuel Pressure Sensor
-Injector Dynamics 1700cc Injectors
-IAG TGVs
-5mm Phenolic Spacers
-IAG Fuel Rails
-IAG PTFE Fuel Lines
-Aeromotive Fuel Pressure Regulator
-Walbro 450LPH Fuel Pump
-TurboXS catless Downpipe
-ETS 3.5" Front Mount Intercooler
-AEM X Series UEGO Wideband with iWire PnP wiring kit
-iWire Speed Density Kit (Hybrid for keeping MAF) with IAT Sensor
-Cobb 4 Bar MAP Sensor
-Torque Solutions Secondary Air Pump Delete
-IAG Competition AOS Kit
-PLM Up-pipe with Dump Tube
-Tial 44mm External Wastegate (14lb)
-ETS V2 Header
-FP UHF Green Turbo
-Torque Solutions Cylinder 4 Cooling Mod
DylanRay is offline   Reply With Quote
Old 10-28-2021, 11:07 AM   #2
JSR84
Member#: 469585
2009 STi
If it is tuning related, your tuner should be able to solve it. If not, he shouldn’t be tuning Subarus. There are only a few things that will disable boost control entirely, and only a few W/G related compensation tables.
JSR84 is offline   Reply With Quote
Old 10-28-2021, 12:34 PM   #3
DylanRay
Member#: 449826
2020 STI
Yeah its sounds like it was a Baro issue limiting the WGDC.
