Welcome to the North American Subaru Impreza Owners Club Tuesday August 3, 2021
Old 06-24-2008, 04:09 PM   #1
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
Default Does a 06-07 cruise control button work on an 04?
I want to add the new updated cruise control steering wheel controls (from 06+ WRX's) to my 04 in order to eliminate the on/off switch on the dash (I have other plans for that spot!). Is this possible? Is it just a simple rewire to the dash wiring?
Any thoughts would be great!
Thanks!
Matt
WrexT is offline   Reply With Quote
Old 06-24-2008, 10:04 PM   #2
subarubloke
Member#: 169000
06 WRX
Rally Blue
Thanks!
Matt
Hi,
I have a 06 wrx, and i have the on/off switch still on the dash (near the fog light on/off switch), it may be in 07 or 08 that have it removed or placed on the cruise control stick, im not sure,
are the 04 & or 06/07 cruse control steering wheel controls the same shape size etc, only reason i ask is, if they wernt the same size etc, wouldnt the connection of where it connects to the steering wheel be different and may not connect properly,
subarubloke is offline   Reply With Quote
Old 07-08-2008, 06:46 PM   #3
WrexT
Member#: 80169
2004 PSM WRX
Anyone know for sure?
Old 07-08-2008, 06:49 PM   #4
sapota
Member#: 175696
2010 legacy
The 07 for sure (just checked mine) USDM WRX has it mounted on the steering wheel.
Does canada get USDM spec?
sapota is offline   Reply With Quote
Old 07-08-2008, 06:54 PM   #5
WrexT
Member#: 80169
2004 PSM WRX
I would think we do, so it should be the same.....would you be able to take a pic of your steering wheel/cruise switch for me?? I am trying to figure this out for my 04! I am not even sure that the steering wheels are the same....Thanks!
AT will a 99 rs cruise control module work on a 01 RS Sir Punk Transmission (AT/MT) & Driveline 0 02-27-2009 12:29 PM
06-07 Diffuser work on an 04 WRB? Jubert69 Newbies & FAQs 6 11-17-2008 07:45 AM
Will 06 wrx rims work on an 04 STi justinpool2000 Interior & Exterior Modification 13 04-14-2006 08:41 AM
Cruise control doesn't work on my 99 Forester ajgraing Electrical & Lighting 6 11-04-2004 05:04 PM
