Welcome to the North American Subaru Impreza Owners Club Sunday July 25, 2021
Old 11-04-2009, 11:16 PM   #1
Dodge Aries K
Member#: 211842
Lots of different
vehicles
Default Hazards, horn, and cruise control dead on 93 Impreza
Okay, I recently picked up a new work beater Impreza wagon and it has a few stupid issues. Before I continue, I did check ALL fuses to make sure they were okay.
Item 1: The hazard lights don't work. Turn signals are fine, but no four way flashers. I tried swapping the hazard switch with one I know works as well as the flasher unit behind the radio to no avail.
Item 2: The horn doesn't work. Didn't hear the relay clicking either when pressing on the horn buttons.
Item 3: Cruise control doesn't work as well. I tried setting it at 30-80 MPH with no results. Pushing the CRUISE button on the dash in between tries didn't help. Also, the cruise button doesn't light up when pressed.
That's about it for now, it runs and drives all right and besides being rusty and having the exhaust fall off it's a pretty decent car for $440.
Dodge Aries K is offline   Reply With Quote
Old 11-05-2009, 02:13 PM   #2
Dodge Aries K
Member#: 211842
Lots of different
vehicles
The horn issue has been solved! Thanks to some good ol' corrosion, the relay was ultra nastified as well as it's plug. I cut the plug off and wired in a regular relay and all is well with that. Trying to find out how it got corroded led me to the rust surrounding the windshield, the damp headliner board around it, and the fact that the windshield wasn't setting right. So last night I attempted to remove it in one piece and that didn't happen... oops...
At any rate, now I have to clean up all this nasty rust and get a new windshield installed... subpar windshield installs suck and will cause your car a lot of damage, trust me on that.
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
Horn and cruise control help please! PDX25i Electrical & Lighting 1 03-13-2009 08:27 PM
Horn, E-Lights, and Cruise Control connected? rotarydelight Electrical & Lighting 6 07-18-2007 02:04 PM
Check engine and cruise control light on TENAZ Engine Management & Tuning 6 03-13-2007 01:16 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
