Welcome to the North American Subaru Impreza Owners Club Saturday June 15, 2019
Old 02-25-2019, 12:00 PM   #3151
Delphi
Member#: 239335
So this entire setup cost less than a Blouch Stock location turbo, and far far less then an EFR setup.
Just got it fired up yesterday. Need to do my Meth and then I am done.
https://www.instagram.com/p/BuP8-G6l...on_share_sheet
Delphi is offline   Reply With Quote
Old 03-05-2019, 02:36 PM   #3152
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Default Borg Warner Registry, post your BW setup & #'s here.
I just recently put together a similar set up for my car. Up pipe pedestal and Borg Warner s257sxe. I 100% agree on price....this whole thing cost less than my new 16g xtr did. The non-efr Borgís are priced really well.
Currently Iím just on a stock ej205 at 20 psi. Hopefully Iíll be getting a built block in there soon and run 25-30 psi.
RavensFan7 is offline   Reply With Quote
Old 03-05-2019, 09:18 PM   #3153
Delphi
Member#: 239335
Looking great man.
If you're handy with a welder and don't mine an few extra couplers if you cant make the boost piping work then this is easily one of the best routes to go.
Old 03-05-2019, 10:47 PM   #3154
T-37
Member#: 175624
0304 WRX WRX
SY WRB
How is spool compared to the 16G-XTR?
Old 03-06-2019, 08:53 PM   #3155
RavensFan7
Member#: 346388
SRP
Itís definitely laggier, but thats expected going from a 38 to 65 lbs per min turbo on a 2.0 engine. Itís really not too bad though. I do have a 0.63 housing, so that helps. Havenít really done any work for spool and low end stuff in the tune yet, so itís hard to compare.
Old 03-06-2019, 09:28 PM   #3156
Delphi
Member#: 239335
Do you have a dyno chart or Virtual dyno or log you can post?
Old 03-07-2019, 02:14 PM   #3157
CursezZz
Member#: 414974
2006 Subaru WRX STi
Obsidian Black Pearl
glad to see my old hotside getting some use instead of sitting around!
CursezZz is offline   Reply With Quote
Old 03-11-2019, 04:38 PM   #3158
cbidwell
Member#: 300154
2006 STI
Steel Grey Metallic
Default Efr 6758 .64 A/r, E85
Hey all,
Finally was able to hit the dyno on my new build. Specs and dyno sheet below.
2006 STi. 78k Miles
Mods:
Full-Race EFR 6758, .64 a/r
Full-Race V-band downpipe
Full-Race Up-pipe
ID1050X
AEM 320
Cobb Flex Fuel
IAG TGV Deletes
IAG Stage 2 Tuff Short block
Stock cams
Stock exhaust manifold (no porting)
Stock heads (Zero mile refresh)
Manley springs/retainers
Perrin Inlet
KSTech CAI
-6 a/n series suel system
Aeromotive FPR
Grimmspeed TMIC
IAG Street AOS
11mm oil pump (stock, no shims)
93 Octane: 352whp/350wtq
E85: 450whp/477wtq
This is a purpose built street/autocross setup, so the goal was neck breaking torque and as close to OEM spool as possible. This car hits hard, and spools faster than stock. Johnson Tuning did all of the map work on the Fathouse Fabrications dyno in Indiana.
cbidwell is offline   Reply With Quote
Old 03-12-2019, 04:27 PM   #3159
CursezZz
Member#: 414974
2006 Subaru WRX STi
RESULTS ARE IN:
BW S362SX-E w/ .82 a/r
on E60 on a mustang dyno
Old 05-05-2019, 03:14 PM   #3160
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
borg S300SXE T3 housing .82AR
Using CarBerry Rom on a Mustang Dyno (don't have a stock baseline for comparison)
93 Octane: 450/380 @21psi
E75: 650/560 @37psi
carnz-pj-410 is online now   Reply With Quote
Old 05-05-2019, 08:20 PM   #3161
lyncher25rs
Member#: 219311
Well I still havenít got the dyno with my 257sxe , fully built and closed deck 2.5 sti swapped 2.5 rs. (Full list will come with my dyno numbers)
Should have some number on E85 early this summer. All nice numbers guys!
lyncher25rs is offline   Reply With Quote
Old 05-06-2019, 11:45 AM   #3162
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I <3 GC/GM cars
Old 05-08-2019, 07:53 AM   #3163
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Your built is a 2.5?
Very nice.
E75: 650/560 @37psi
west_minist is offline   Reply With Quote
Old 05-14-2019, 06:40 PM   #3164
lyncher25rs
Member#: 219311
Originally Posted by Homemade WRX View Post
I <3 GC/GM cars
Me too lol
Old 05-15-2019, 08:58 PM   #3165
Homemade WRX
Member#: 33782
96 in the garage
Ignore this and move along.
Last edited by Homemade WRX; 05-22-2019 at 08:23 PM. Reason: The phone app is glitchy.
Old 05-21-2019, 11:17 PM   #3166
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Facility: SDR Performance
Type of Dyno: Mustang
Tuner: jaz TUNING
Boost: 26 psi
Fuel:E85
Target AFR: 12:1 (gas referenced)
SAE Corrections: CORRECTED (unforgiving calibration)
Peak HP: 367
Peak Torque 367
2005 STi - 41k Miles
Manley A/B drop-ins and head studs on new short block
EFR 6758, ETS TMIC, 3" TBE
Unforgiving power @ 50 and weight...
Compared to: https://i.imgur.com/pGcMzrf.jpg from https://forums.nasioc.com/forums/sho....php?t=2799707, which made roughly the same power on gas and 5-6 PSI less. My MAF was registering 420ish g/s.
yamahaSHO is offline   Reply With Quote
Old 05-22-2019, 08:25 PM   #3167
Homemade WRX
Member#: 33782
96 in the garage
Meh, still looks like a fun DD.
Old 05-27-2019, 09:15 AM   #3168
Delphi
Member#: 239335
Event: Dyno
Temperature: 70.00 F
Elevation: 3600 feet
Car: 2011 WRX Hatch
Tuner: Sunny @ Airboy Tunning
Dyno: Dyno Dynamics
Peak HP: 415 AWHP on 94+Meth / 365 AWHP on 94
Peak Tq: 415 ftlbs on 94+Meth / 360 ftlbs on 94
Target AFR: 11.4
Stock STI: 220 AWHP / 220 ftlbs
Target Boost: 26psi 94+Meth/21psi 94oct
Notable Mods:
Turbo - Borg Warner s257SX-E with a T3 single scroll 0.63 Hotside
Built Motor
40mm Turbosmart Wastegate
IAG Fuel Rails
DW65c Pump
ID1000's
Tomei ELH
Turbo Kit.com Rotated Turbo Pedestal
FMIC
Catless 3in Exhaust
Aeromotive FPR
Speed Density Tune
Dyno reads very low, and as all of you know it is just a tool. We stopped at 26psi because my crappy tires were deflecting a lot under load (it was seen under wheel speed on the dyno and it was not even close to linear) so we weren't seeing much more gains as we turned it up, it also could be the reason why the numbers appear low. For what its worth on pump gas I hit 385g/s this morning and on meth I've hit 445g/s now.
Old 05-31-2019, 09:07 AM   #3169
Delphi
Member#: 239335
Just for craps and giggles. Here is a virtual dyno run in 4th gear with the meth turned on. Ambient temp was 88F. Note the AFR, my DW65c can't keep up on the top end, I have an AEM 320 going. Thank goodness for Differential Fuel Pressure.
Old 05-31-2019, 09:48 PM   #3170
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Event: Dyno
Car: 2011 WRX Hatch
Dyno: Dyno Dynamics
Target AFR: 11.4
Notable Mods:
Built Motor
IAG Fuel Rails
DW65c Pump
ID1000's
Tomei ELH
FMIC
Catless 3in Exhaust
Aeromotive FPR
Speed Density Tune
That reads low? I hit around the same g/s a second and the dyno I was on spit out 367whp.
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
