Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 07-04-2019, 08:51 AM   #1
whiterabbitrexy
Member#: 379271
Default V4 wrx heads on v6 ej205 block
Hi everyone i have a 1998 subaru Australian Wrx Gf8.....it has everything from factory stock beshides 3inch Tbe, vf22, fmic, and ecu is standard but soon will be fully tunable by installing a chipset and rom to turn it into a live standalone ecu......*
The ej20 block Bottom end craprd it self long story short so i thought about installing a 2002 wrx ej205 for cheap.....i found one cheap for $300 aus, and now thininkg to myself my 1998 ecu parameters might be a bit diffrent fireing order compared to a ej205 block because of crank angle sensor might be off compared to my phase 1 ej20k block being suited to the factory harness and sensors?*
Also notice somthing scarry the pistions come out complety FLAT to the top of the deck...my old block only had a ej20 wrx 75mm stroke and stoped a fair bit before the decking of the block.... will this mess with my timing and Valves hiting the pistons????*
In all that said.....Block will bolt up perfectly with the ej205 oem gaskets.... i will use a ej205 harmonic balance Not my 1998 ej20k factory harmonic..... i want to play it safe i can run everything from Oil pump to cooling and block matting....so the rest im a little puzzled.
Please give us your advice on what u known i might be missing
whiterabbitrexy is offline   Reply With Quote
Old 07-04-2019, 10:18 PM   #2
binny
Member#: 198108
MY98 WRX
Heads will bolt on fine but CR will be higher due to the 98 heads + the 205 block (you may want to check out the combinations actual CR probably be a bit higher)
Use the 98's timing belt kit for the crankshaft position sensor (I think they are different)
binny is offline   Reply With Quote
Old 07-18-2019, 11:42 PM   #3
whiterabbitrexy
Member#: 379271
Thanks binny I've got no idea how to calculate the Cr.....i think i need to use ej205 crank position sensor to read the magnet in the ej205 harmonic balancer not my original on that came with my 1998 ej20 block
Old 07-19-2019, 12:16 AM   #4
whiterabbitrexy
Member#: 379271
Here is a video with me trying to explain what i want to do
https://youtu.be/auiWy5QKM1A
Old 07-21-2019, 11:26 PM   #5
binny
Member#: 198108
MY98 WRX
Watched your video -
Anything to do with sensors - use the 98 year stuff
Also the PCV system (as you will be using the 98 intake manifold)
Old 07-26-2019, 08:02 AM   #6
whiterabbitrexy
Member#: 379271
Thanks Binny....do you know of anyone having good success with my v4 wrx heads on a v7 wrx block ? Anyone know what my compression ratio will be?
