Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 08-27-2016, 12:17 PM   #226
dingobite
Member#: 82391
08 OBP Sti
Avoid spraying water on air filter, battery and alternator or use foil or plastic to cover the exposed parts.
dingobite is offline   Reply With Quote
Old 05-25-2017, 05:09 PM   #227
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
So I've done the scrubbing bubbles cleaning on my engine bay twice and for the most part it got rid of a ton of built up grease and grime. My chassis ID plate was unreadable and my shock pillars and firewall were basically black before I tried scrubbing bubbles.
While I am happy with the overall results I need to find something to scrub my intake manifold. I was thinking a stiff bristled plastic brush as I'm afraid even a soft metal brush is going to start polishing the manifold and I don't want that. I just want to clean out all the nooks and crannies that don't seem to respond to the scrubbing bubbles. Suggestions? Or is the stiff plastic brush going to be my best bet?
Preludicrous is offline   Reply With Quote
Old 05-26-2017, 09:10 AM   #228
jimbobborg
Member#: 465391
2018 WRX M6 Premium
Easy Off Oven Cleaner.
jimbobborg is offline   Reply With Quote
Old 05-26-2017, 01:51 PM   #229
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Ugh...that stuff stinks. I prefer my engine to smell like fresh linen or cut lemons, thank you very much.
I'll give it a shot. Do I spray it on cold and then run the engine? Similar to cleaning the oven.
Old 05-30-2017, 03:22 AM   #230
Archeech
Member#: 427131
2016 WRX Limited
Dark Grey Metallic
If any of you 15+ WRX owners looking to wash your engine I highly recommend you don't take off the engine cover. I heard stories of people breaking the bottom clips on the first or second try since they become fragile over time.
Archeech is offline   Reply With Quote
Old 01-07-2018, 07:02 PM   #231
Deckersixx
Member#: 472696
17 Wrx
Always use this stuff in the bathroom never knew it could be used as engine bay cleaner good to know
Deckersixx is offline   Reply With Quote
Old 01-12-2018, 10:28 PM   #232
VR4ownzU
Member#: 122700
I was told by someone I know to try WD-40 on the manifold and small brush. I'm going to try an old toothbrush.
VR4ownzU is offline   Reply With Quote
Old 02-05-2018, 07:59 AM   #233
joebrowntech
Member#: 481561
2016 Passat 3C
Engine bay cleaning could be one of the critical topics whichneed an immense expertise. And additionally, you need to follow the guidelines in the user manuals which help you get an expert knowledge of the engine bay.
But if you lost the user manual for your vehicle, you could get a copy of it most effectively at manuals.co.
joebrowntech is offline   Reply With Quote
Old 02-09-2018, 11:04 AM   #234
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Originally Posted by joebrowntech View Post
Engine bay cleaning could be one of the critical topics which need an immense expertise.
Wat? Just spray with scrubbing bubbles, agitate with various sized brushes and rinse with a spray bottle of water or a garden sprayer full of water. Avoid alternator and obvious wire connections.. Let it sit and drip dry for a few minutes. Blow engine dryish with a shop vac or similar, wipe dry with microfiber.
The car gets plenty damp under the hood when you drive in a rain storm.. you don't need to overthink it unless you are working with high pressure and or high volumes of water. If you take your time and dont use a pressure washer or hose you probably wont mess it up.
MtnXfreeride is offline   Reply With Quote
Old 02-09-2018, 11:05 AM   #235
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Wouldn't that be messy and stinky when the engine warms up? It would be hard to rinse all the residue off...
Old 02-14-2018, 10:27 AM   #236
2.5L Monster
Member#: 307177
2k4 WRX/WRB
+1
2.5L Monster is offline   Reply With Quote
What color for engine bay/ interior? djelly84 Car Care & Detailing 1 01-31-2012 10:27 PM
Looking for engine bay shots of Mishimoto equipped cars! Mishimoto Vendor Announcements 0 09-14-2011 10:21 AM
FS : OEM Fuel Filter For Engine Bay wrxroberts Engine/Power/Exhaust 15 03-03-2011 04:30 PM
Need a part number for engine bay brake lines 06 STI Cyclops Brakes, Steering & Suspension 2 01-26-2010 07:56 AM
Bubbling noise from Engine Bay Shikamaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-05-2005 08:52 AM
