Welcome to the North American Subaru Impreza Owners Club Tuesday September 29, 2020
Old 04-24-2004, 07:39 PM   #1
loudog800
Member#: 19683
2002 Subaru
WRX
Default Differential fill plug stuck!!!
My differential fill plug is completely stuck (good thing I tried that one first). I tried all the tricks including using the jack to torque the wrench...nothing has worked. What are my options here???
BS
loudog800 is offline   Reply With Quote
Old 04-24-2004, 07:45 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Give up...i gave up after a bit. I'm just taking it to a shop i think, not worth the trouble imo.
Soon2Bgreat is offline   Reply With Quote
Old 04-24-2004, 10:40 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Did you use a 1/2" drive breaker bar on it? This is the "proper" tool for it. Just slip the 1/2" square socket tip into the diff bolt "hole". If you can't get enough leverage with it, a pipe section slipped over the end should do it. The diff bolt IS a bear, so don't fear getting violent with it.
Old 04-25-2004, 02:07 AM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Definitely use a pipe extension if you can't get it to break loose. I had to bench press the darn thing to get it to break loose. Just be careful of your fingers cause when it pops loose, you'll smash your fingers on the bottom of the car if you're not careful.
Calvin
cnk is offline   Reply With Quote
Old 04-25-2004, 02:20 AM   #5
AVATAR-X
Member#: 4889
20XX Gunstar
I have no idea how to get the damn thing off. I swear, we had a 2-foot bar on it and two of us were trying to turn it. We could push enough to start lifting the car but the bolt wouldn't budge.
If only we had a lift so we could push on the breaker-bar from a standing position instead of trying to get under the car and push up. We managed to get all our stuck lower strut bolts off (and those things must have taken more than 200 ft-lbs to get off) but the rear-diff plug won't budge.
One of these days, I swear, I'll get it.
AVATAR-X is online now   Reply With Quote
Old 04-25-2004, 02:23 AM   #6
esteve
Member#: 28716
2006 STI
Here's what I did, and it was easy. With the car up on jackstands, lie on your back and put your feet on the bottom of the left rear tire with your knees bent. Have the breaker bar or ratchet facing the ground, grab hold, and use your legs to "pull" on the bar. Your legs and hips are much stronger than your upper body. It's like doing a leg press.
esteve is offline   Reply With Quote
Old 04-26-2004, 07:13 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Use about a 1.5 foot 1/2" breaker and a large sledge. I think you will have better success with repeated hard bursts.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 04-26-2004, 08:29 PM   #8
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
This method worked really well for me too. It's all in the hips.
-Bryce
Carnot is offline   Reply With Quote
Old 04-27-2004, 10:17 AM   #9
Hayes
Member#: 11808
I've seen an impact wrench used. Just make SURE it's set to loosen. CCW is the way to turn. I'm sure your are loosening it?? eddie
Hayes is offline   Reply With Quote
Old 04-27-2004, 10:53 AM   #10
Psydotek
Member#: 44168
2017 Silver Forester
with not enough lights...
1: Put car on trailer and tow onto an incline.
2: Open rear diff drain plug and drain fluid.
3: Tow car so it faces downhill (as sharp as possible).
4: Fill rear diff with fluid as much as possible (or factory recommended volume if possible).
5: Torque down drain plug back to 32.5 ft/lbs.
[Hey, i'm trying to be creative here...]
[maybe some sort of "tiltable lift" (if they even exist) could be used...]
Psydotek is offline   Reply With Quote
Old 04-27-2004, 12:14 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I wound up taking mine to the shop after deforming the plug and ordering new ones. I tried an impact wrench with no luck. I watched the guy at the shop bust it loose and imho, it would have been almost impossible to do if the car were not on a lift. In the process of taking the fill plug out, it was mangled WAY beyond the point of being re-used.
Stanley is offline   Reply With Quote
Old 04-27-2004, 06:13 PM   #12
RayO
Member#: 42329
2002 WRX sedan
You gotta love how tight some of the bolts on our cars are.
I've done several "simple" installs where the biggest problem (and sometimes the show-stopper) was getting the factory fasteners off.
I did luck out on the drain plug, with the help of a three-foot pipe.
RayO is offline   Reply With Quote
Old 04-27-2004, 06:29 PM   #13
Karl
Member#: 13110
Use a jack to push on the breaker bar up to loosen the plug.
Karl is offline   Reply With Quote
Old 09-03-2019, 09:52 PM   #14
pjineugeneor
Member#: 505966
2000 Sierra 1500
Here is what worked like a charm for me to get the fill plug loose on the rear differential of my vehicle . I have a 2000 GMC Sierra 1500 that developed a rear differential pinion seal leak. Mount breaker bar into fill plug hole and position handle so you can use a small hydraulic jack as other have suggested. Start jacking till you literally start lifting the back end of vehicle up.
Now for the magic part! I got into the bed of my truck right above the rear axle and launched all 230 pounds of me into the air and land hard. I could hear the fill plug 'crack' and sure enough, I was able to at that point use a ratchet wrench to remove the plug. Im sure a good hard bounce on the fender might have worked as well. Like an impact wrench, the sudden jerk (jump) was all that was needed to loosen the fill plug. Enjoy!
pjineugeneor is offline   Reply With Quote
Old 09-06-2019, 08:00 AM   #15
Mclemo
Member#: 506063
These plugs are really hard to get off, the way I did it was using 2 people, one with a crowbar at the back of the housing mounting studs to keep the diff down, and a long 1/2" breaker bar. Even this method took a few shots, and started rounding the plug also. Just be careful, or use an impact wrench etc.
Mclemo is offline   Reply With Quote
Old 09-06-2019, 08:24 AM   #16
Bansheeboy11
Member#: 182415
1999 RS
Jeeze no one knows how to loosen pipe threads these days lol, tighten the plug until you feel it "pop" and loosen, then it will come right out. If you need to, warm up the diff cover around the plug a little bit
Bansheeboy11 is offline   Reply With Quote
STI rear differential fill and drain plug pj_cab Transmission (AT/MT) & Driveline 1 07-10-2006 12:28 PM
Part # for Rear Differential Fill Bolt sj72 Service & Maintenance 1 08-23-2004 01:05 PM
Differential fill & drain plugs hard to remove - torch 'em? NotFast Service & Maintenance 15 11-17-2003 07:12 AM
Where the hell is the fill plug on my transmission?? ScoobyHead1993 Legacy Forum 7 06-20-2002 07:45 PM
Transmission/differential drain/fill plug sizes Karl New England Impreza Club Forum -- NESIC 5 04-16-2002 10:23 PM
