Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 07-23-2015, 05:15 PM   #26
shadrag
Member#: 393545
2015 WRX (6MT)
Originally Posted by sooper_wrx12 View Post
Even the worst feeling rod shifter has a more positive shift than a good cable shifter.
Lol, no
shadrag is offline   Reply With Quote
Old 07-25-2015, 10:15 AM   #27
Professor WRX
Member#: 426430
2016 WRX
Ice Silver Metallic
Try pushing it straight forward out of second. Palm, thumb, pistol grip. Whatever works for you. Let it center itself and push straight forward into third. Going second to third you should only push straight forward not to the right.
Professor WRX is offline   Reply With Quote
Old 07-30-2015, 08:32 AM   #28
shamrock 05
Member#: 120057
2018 WRX (base) 6spd
Even the worst feeling rod shifter has a more positive shift than a good cable shifter. The point is, a car like the WRX shouldn't have a cable shifter. The natural aspirated BRZ has a rod shifter and it's based off the same boxer platform. This is why you wait for the mid model year refresh.
Doubt that.....I would bet you that this current 6spd trans will be transplanted in future WRX's for years to come, subaru is not going to refresh this.
shamrock 05 is offline   Reply With Quote
Old 07-30-2015, 09:11 AM   #29
sooper_wrx12
Member#: 415051
2014 WRX STI Limited
Well I guess that's one way to further differentiate the WRX from the STI. Sucks for WRX owners.
sooper_wrx12 is offline   Reply With Quote
Old 07-30-2015, 09:46 AM   #30
libins26
Member#: 422375
15 WRX LMTD
LR
It's been a known issue for this gen. 15's had the same issue too for many people. 3rd gear hesitates to go in and go back to neutral and 3rd and you're good. Try to tidy up your shift to third because it'll happen often. Not as much, but often... and as many others have said already, bushing and cable on these gens aren't the greatest. Let us know what the dealer tells ya
libins26 is offline   Reply With Quote
Old 07-31-2015, 12:46 AM   #31
Maximum Gentleman
Member#: 399350
2015 WRX
I too have been having this third gear issue with my '15, but I'm not new to manuals, and it is only during turning to the right, under mild-moderate cornering load, at about 35-45% throttle, and 3500-4000rpms (it's actually always the same corner, and same driving conditions). On this particular corner, I can replicate the issue almost every time. It doesn't grind, and I don't feel like I blew the shift, it just feels like I hit a very tight rubber band wall. Guess it's time for the dealer to go beat the piss out of my car and eventually tell me the problem is me.
Maximum Gentleman is offline   Reply With Quote
Old 08-01-2015, 11:07 AM   #32
libins26
Member#: 422375
15 WRX LMTD
LR
You're better off waiting for more comments and opinions from others. This is a big club, wait for others to shed some light on this topic. Dealer will drive your car hard and come back saying "oh we don't see anything out of the ordinary" and you leave. What do you gain? nothing. Other than someone abusing your car.
Old 10-26-2017, 03:53 PM   #33
_ryuujin_
Member#: 471038
2018 WRX
WR Blue
'18 checking in, 3rd is difficult to get in i feel, it sticks just outside and needs to be reset and push into, much more than the other gears.
_ryuujin_ is offline   Reply With Quote
Old 10-26-2017, 03:59 PM   #34
golfer883
Member#: 475593
Pretty sure they did improve the shifting on the 2018 model refresh. Supposedly more smooth now. Hoping it's even better for 2020 model and dual clutch option for automatic
golfer883 is offline   Reply With Quote
Old 10-26-2017, 05:05 PM   #35
bcterp
Member#: 409569
2018 WRX
18 here as well, gears are all pretty easy to get into. Still notchy though.
bcterp is offline   Reply With Quote
Old 10-26-2017, 06:23 PM   #36
fishfangs
Member#: 425438
2015 WRX
ISM
I have a 2015 WRX that used to have a slight grind from 2nd to 3rd when car was at temperature and shifting at higher RPM. It appeared to be only when it was hot, and the issue was intermittent. I brought it to the dealer, they couldn't replicate it.
A few weeks later, I had warranty work that required changing the transmission fluid, and the issue hasn't been back since. A coworker also recommended changing the transmission fluid prior to the work being done, citing that there may be some break in material floating around the transmission.
fishfangs is offline   Reply With Quote
Old 07-17-2019, 03:27 PM   #37
nmdrum361
Member#: 499555
2018 Subaru WRX
WR Blue
I am having this issue intermittently on my 2018 WRX. Has anyone found a fix to it? It comes and goes, dealer says I need a new 7k transmission lol cause its blow up because everything on my car is modified.
nmdrum361 is offline   Reply With Quote
Old 07-18-2019, 10:15 AM   #38
Floody420
Member#: 419597
2016 WRX PRM 6MT
2002 Audi A4
Different take:
I got my 16 with 4 miles. Hated the shifting. Almost returned the car.
I turned off Hill Assist and everything seemed ok. Shifting was smoother in all gears.
DOESNT MAKE ANY SENSE but it worked for me. I have heard others claim the same.
I suggest giving it a shot. I YouTubed it for directions.
Floody420 is offline   Reply With Quote
Old 07-18-2019, 04:31 PM   #39
rtv900
Member#: 428511
2016 STI
^this is absolutely a placebo affect man, sorry
there's no way in hell the hill assist had any affect on how the car shifts while driving. That system has no ability in any capacity to affect that.
Old 07-18-2019, 05:26 PM   #40
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
This idea seems to be thrown around fairly frequently on here, but this is just nonsense.
Hill start assist has nothing to do with shifting. It just applies the brake electronically for 2 seconds, once clutch and brake are depressed and then released. At best, you may notice a slight difference in roll start from a stop if hill assist is disabled.
Likely explanation of the perceived improvement is that by the time you got to figuring out this feature and disabling it, you got used to the carís shifter and were then able to manage the shifts better.
Originally Posted by Floody420 View Post
Different take:
2018wrx_newbie is offline   Reply With Quote
Old 07-19-2019, 08:06 AM   #41
nmdrum361
Member#: 499555
2018 Subaru WRX
WR Blue
I am guessing this has nothing to do with hill assist, but I am no expert. People say these cars have a weird shifter and they do. You just have to get used to it. I have done almost every shifter upgrade to make the driving experience better. I would recommend all of these and has made me love the car that much more. Shift upgrades include Boomba short throw shifter, Boomba short shift plate, Perrin shifter bushing, Perrin shifter stop, and Raceseng Topology weighted shift knob. However, these were done 7000 miles before the issue with the noise started. It seems like the noise started about 1500 miles ago and has slowly gotten less loud and less often, could this just have been a weird break in? Just wait it out and see what happens? Car currently has right at 10,500 miles on it.
Old 07-19-2019, 09:37 AM   #42
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Can you describe the issue more precisely? Is it exactly the same as the OP of this thread reported 4 years ago?
Old 07-25-2019, 06:32 PM   #43
KTMXCW
Member#: 504227
I had the same issue a bit too but it has seem to get better as I have got adjusted to it. They are a little sloppy and I came from shifting tight honda transmissions so its a bit to get used to at least form what I have experienced.
KTMXCW is offline   Reply With Quote
Old 08-03-2019, 04:43 PM   #44
nmdrum361
Member#: 499555
2018 Subaru WRX
WR Blue
Yes it is the exact same issue they are describing.
Old 08-04-2019, 11:35 AM   #45
guiltysub
Member#: 504817
17 wrx
wr blue
I think you need to slow down release clutch when you 2 to 3, no problem at all
guiltysub is offline   Reply With Quote
Old 09-13-2019, 12:03 PM   #46
guiltysub
Member#: 504817
17 wrx
wr blue
Maybe the gear is too notchy? I saw people complaint about it
