Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Old 09-13-2019, 01:50 AM   #1
cashrolling
Member#: 125064
2013 JDM STI spec C
Default Coil spring replacement HELP
Hi, I'm not expert in coilovers at all. I have OHLINS DVF on my 2013 gvb STI, the springs are 200mm x 65mm and rate is 9kg.(fronts). Can I replace the spring with a softer one? How do I convert the spring rate to compare with lbs. Like stock that is close to 300ft lbs...I think. If I can replace the spring, can it be any brand as long as the size is that? Where can I find a selection of springs? Sorry but I have no knowledge on this topic
cashrolling is offline   Reply With Quote
Old 09-16-2019, 03:32 PM   #2
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
You can just google the conversion” convert 9kg/mm to lbs/in” you can also find charts.
Yes obviously any spring that physical size will fit. The real size issue is what adjustment you have available in the shock to deal with the rate change. Too small a rate and you’re overdamped making it ride really rough to large a rate and you’re underdamped making the car bouncy. A dealer can tell you how much you can change before needing to revalue the damper.
uofime is offline   Reply With Quote
Old 09-16-2019, 10:33 PM   #3
cashrolling
Member#: 125064
2013 JDM STI spec C
Old 09-17-2019, 01:21 PM   #4
Bru1212
Member#: 178770
06 STi
17 Fozz
https://www.redline360.com/garage/sp...-kgmm-to-lbsin
Bru1212 is offline   Reply With Quote
