Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 09-11-2019, 01:00 AM   #1
Ecall
Member#: 504005
Default Car sounds horrible after walnut blasting and tgv/egr deletes
Video example
https://drive.google.com/file/d/15OU...ew?usp=sharing
Any idea why the engine sounds like this after a walnut blasting, tgv/egr delete, and a grimmspeed EGBCS were installed? Or is this normal for a car to sound without a tuner's basemap?
The noise seems to lessen after 10-15 seconds and the ticking stops altogether when the throttle is pushed in but returns when idling.
I am planning on changing the oil this weekend and bleeding the coolant. Any other suggestions to do? Is there a diagram that shows exactly how the intake manifold is supposed to go on in case I missed something? Is this normal if you have not applied an egr/tgv delete tune yet?
I think I may have left a bolt somewhere near the EGR delete which hopefully explains the ticking (and not actual rod knock)
Ecall is offline   Reply With Quote
Old 09-11-2019, 10:20 AM   #2
TheOtherAdrianG
Member#: 466686
Did you have the exhaust manifold off? It could be a leak at the exhaust flange or some kind of exhaust leak very near the cylinder.
TheOtherAdrianG is offline   Reply With Quote
Old 09-11-2019, 11:04 AM   #3
Ecall
Member#: 504005
Nope just the intake manifold. Removed the skid plate below though
Old 09-11-2019, 11:30 PM   #4
MedicMoses
Member#: 470679
2018 WRX
Pure Red
Heat shield? Might be off just enough that when it cools it hits something, but is clear with engine torque and heating up?
MedicMoses is offline   Reply With Quote
Old 09-11-2019, 11:53 PM   #5
Ecall
Member#: 504005
Ah haven't touched it. I'll try it later.
Old 09-13-2019, 07:48 AM   #6
waltersh
Member#: 447706
2017 WRX Base
CWP
Definitely sounds like an exhaust leak. At least, that's all I can hear in the video.
waltersh is offline   Reply With Quote
Old 09-13-2019, 04:03 PM   #7
Ecall
Member#: 504005
Thanks for the input! To fix an exhaust leak I would just trace the source from the turbo to the turbo back right? Or would I try and find it elsewhere?
Old 09-13-2019, 04:51 PM   #8
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
agreed.
CE lite?
did you put in Phelonic(sp.) spacers?
Old 09-14-2019, 11:51 AM   #9
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
You mentioned EGR delete. Sounds like your block-off plate for EGR port on the head is leaking. Did you use a new gasket on the plate ?
Old 09-15-2019, 06:07 AM   #10
Ecall
Member#: 504005
Yes here are the codes (Applied the tune today):
P1492
P1494
P1498
P2016
P2021
Also is this normal to have these codes thrown for a provided basemap to get the car to my tuner before a dyno? Did they forget to remove the codes?
I did install a new gasket for the egr delete. I wonder if I put the gasket on backwards I'll check today.
Old 09-15-2019, 09:41 PM   #11
AliBenn
Member#: 487
Acadia Green RS-T
Well Iím guessing:
Those codes point to manifold and EGR system
Itís possible manifold leak (bc of something with gasket) this in turn, giving false readings to EGR system
Very possible tht sound you hear is cylinders coming through that leak
Old 09-16-2019, 03:18 AM   #12
Ecall
Member#: 504005
Thanks guys! The sound was definitely the lower egr plate. I sealed it up properly and now no more noise. I'm still getting those codes but I did some research and it looks like those codes need to be turned off by the tuner. Taking it in tomorrow for my dyno so I'll check with the tuner.
Old 09-16-2019, 05:50 PM   #13
AliBenn
Member#: 487
Acadia Green RS-T
^^^^^^alright!!!!!!!
Old 09-16-2019, 11:01 PM   #14
Ecall
Member#: 504005
Dyno tune was a success! Said the installs were great minus not torque'ing the skid plate but all went well.
