Welcome to the North American Subaru Impreza Owners Club Sunday October 13, 2019
Old 03-09-2016, 10:39 AM   #26
JeffEngineer
Member#: 431092
2002 Impreza WRX
Blue (World Rally Pearl)
Default Body Sealant as a Culprit
If you can get somebody to wet your car with you in the trunk, you may be surprised where all water can get in. I discovered water coming out from between the body panels, which means the body sealant is beginning to break down. I found places around the rim of the trunk where the body sealant was showing signs of cracking, dug it out a bit, and back-filled it with flowable silicone (the theory being that the silicone would retrace the water paths and then set up). One of these days I'll go back and remove the top layer of silicone and seal the seams top side with some trunk joint sealer, then repaint.
JeffEngineer is offline   Reply With Quote
Old 03-09-2016, 11:31 AM   #27
Mitchwrxpaps
Member#: 415635
2016 WRX Limited 6MT
Lapis Blue Pearl
You do realize that this thread is from 2006 and that the OP is banned from Nasioc, right?
Mitchwrxpaps is offline   Reply With Quote
Old 10-24-2016, 10:24 AM   #28
keyrock
Member#: 457000
2008 STI
Gonna bump this thread back from the dead, since my 02 bugeye still has a trunk leak
After further investigation, my trunk had two separate leaks. 1) the spoiler was leaking water through the bolt holes and 2) the rain gutter beneath the rear windshield was compromised. Spoiler is now gone and the holes repaired with bondo. No more water from there. Now tackling the rain gutter.
keyrock is offline   Reply With Quote
Old 10-30-2016, 09:03 AM   #29
flanker08
Member#: 302880
2017 WRX Premium
Lapis Blue Pearl
My 2008 also leaks. I had some bodywork done and had assumed it was a result of that.
Ill start looking at this.
flanker08 is offline   Reply With Quote
Old 10-30-2016, 12:05 PM   #30
Christoph13
Member#: 456519
2011 Impreza 2.5i
Marine Blue Pearl
My '11 Impreza had/has the same issue. Was rear ended and ended up in a 4 car pill up only after a couple months of owning her. Noticed water in my trunk (under the foam boards off on the side of the trunk floor.
1) I removed the rear taillight assemblies and applied 3M's dum dum window sealant around the perimeter of the body of the car. Reinstalled taillight assemblies.
2) Inspected and cleaned out using compressed air my sunroof drain ports and any possible areas that might lead to a leak in the trunk.
After 2yrs of repair, I noticed after days of rain. That water is back in trunk at the same areas. Will inspect and update with findings.
Christoph13 is offline   Reply With Quote
Old 10-31-2016, 11:26 AM   #31
jram647
Member#: 457378
Default same problem
had same problem a few years now, still haven't figured it out
jram647 is offline   Reply With Quote
Old 10-31-2016, 11:29 AM   #32
jram647
Member#: 457378
Default trunk leak
changed trunk seal rubber, still leaking
Old 10-31-2016, 11:30 AM   #33
jram647
Member#: 457378
also re-sealed spoiler to trunk, still leaks
Old 12-03-2016, 04:55 PM   #34
SleepingWrex
Member#: 448222
Silver Metallic
So there's no point in just resealing my spoiler? I found wet spots on both sides of my trunk in my 02
SleepingWrex is offline   Reply With Quote
Old 12-03-2016, 05:48 PM   #35
Cyclonus
Member#: 161701
40 iTS U-R-A-BUS
BRW
I replaced my trunk seal and it solved my trunk leak issue. Not sure if anyone mentioned this method yet. If so then it's a reminder.
Cyclonus is offline   Reply With Quote
Old 12-04-2016, 01:13 PM   #36
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
If you still have a leak, remove all of the interior panels, etc. and then have someone (yourself) stay inside of the car while someone sprays down the car with a hose and of course look for leak(s).
Old 12-07-2016, 10:39 AM   #37
Mizzel
Member#: 432843
2002 Wrx
The gasket for my spoiler is where I was leaking from on my 02. It could be that for you or the actual trunk...get in the trunk to figure out exactly what it is for you.
Mizzel is offline   Reply With Quote
Old 12-08-2016, 05:17 PM   #38
keyrock
Member#: 457000
2008 STI
I think I discovered the source of the 2nd leak. It wasn't the gutter, rather it was the corners right underneath the rear windshield.
Here
Reason I know this is the leak continued until I applied a bead of silicone about 4" from each corner toward the middle. After I did that we had a huge downpour and no leak.
I hope this is useful to someone.
Old 12-11-2016, 03:19 PM   #39
Aphelion79
Member#: 459571
Very useful tips to look for leakage... Something to look out for when I go buy my 06 xD Thx all
Aphelion79 is offline   Reply With Quote
Old 12-16-2016, 07:05 PM   #40
NorM15
Member#: 451904
15 WRX
Cw
No leaks in the 15' wrx so far.
10' ob leaks as much as it always has..
NorM15 is offline   Reply With Quote
Old 03-17-2019, 08:31 PM   #41
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Bumping this up, mine is leaking near the left front upper corner of the trunk opening. 07 impreza 2.5i / no spoiler obviously. It seems to be leaking at the area where the metal seams are, in that corner. There is water further forward and higher up on the seam, so not sure that could happen from the rubber seal since it would have to go uphill. I don't see any spots where the seam sealer isn't complete, but there could be something behind the rear glass on the lower corner. There is a good bit of dust/mud buildup under the edges of the rubber seal. but nothing chunky or large like leaves or debris. I will remove the seal and install another after cleaning then report back if it stops. May spray some soap and run the a/c on fresh to pressurize the cabin and look for foam.
Also for anyone worrying about the flap / pressure vents leaking. The lower area of that well has an opening to drain, and the only way water will remain is if that drain clogs and it can't get out. It still would have to fill up pretty high top spill over into the tire well area. Just clean out the drain in that case. It's almost impossible for water to get in though, due to their check valve design and how they're shielded pretty well behind the bumper cover.
2slofouru is offline   Reply With Quote
Old 04-15-2019, 02:59 PM   #42
02WRX_RallyProject
Member#: 500363
My 02 wrx sedan has a leaky trunk, has for most of its life, tried patching multiple times, water always finds its way in, I suggest picking up some weather stripping from a hardware store, doesn’t look as clean but it works wonders
02WRX_RallyProject is offline   Reply With Quote
Old 08-26-2019, 04:51 PM   #43
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow Old thread, but it's what popped up when searching...
So I am getting water in my trunk.
I checked everything and it wasn't until I REALLY washed the car with a ton of water that I see water is coming from this location. What would cause water to come in from this exact location? I replaced the trunk seal but that isn't the problem. Water is coming in from these two piece of metal. Appears to be on both sides.
How is water coming through this?
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 08-28-2019, 04:08 PM   #44
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
That would point to the body seam that is in the glass-side corners of the trunk having failed. I have this issue as well, but have yet to isolate the leak. My guess is that this is an issue that will affect every GD sedan at some point in it's lifecycle, but we haven't identified a simple, repeatable repair to date.
car_freak85 is offline   Reply With Quote
Old 09-06-2019, 08:04 AM   #45
Mclemo
Member#: 506063
Have had the same issue, checked around the whole boot and turns out the seal was simply peeling up a little bit, stuck it back down and seems to have fixed it, no leaks when washing. A large amount was getting through and the area of the peeling was only very small, hoping that was the fix.
Mclemo is offline   Reply With Quote
Old 09-06-2019, 04:22 PM   #46
Big-E
Member#: 123843
2016 STI LTD CWP
I'm also going to guess that if the rear window were to be removed, there would be corrosion of the body-opening.
Old 09-11-2019, 02:54 PM   #47
car_freak85
Member#: 13530
EJ205
Old 10-06-2019, 03:42 AM   #48
Jokerhotpocket
Member#: 507114
Remedy for consistent rogue shadow agent water leak in trunk:
1. Remove your tail lights.
2. Remove the molding/sealant on the inside of tail lights completely.
3. Clean all surfaces still containing old sealant and particles. You can use rubbing alcohol if you'd like or whatever takes the old sealant off.
4. Let your tail lights dry completely.
5. Source brand new rubber gasket/seals. You can use OEM or auto parts store universal seals just make sure its sticky on both sides, obviously.
6. Install your new gaskets/seals on tail lights.
7. Reinstall tail lights onto car.
8. Keep your car dry for 24 hours (or more) preferably.
I cannot guarantee this will fix all "water in trunk" issues. BUT I had an older impreza, late 90's model. I had a water in trunk issue for about a year. Could not figure it out. I cleaned the underside of car multiple times, sanded, primed, painted, and rhino lined the underside of trunk. STILL had water in trunk. Swore I had stealth holes in the rear quarterpanels or something to that effect....
Friend of mine was installing new JDM tail light assy on his car one day. He had a TON of double sided sticky auto sealant strips left over. We used that left over stuff to reseal my OEM tail lights just for the heck of it.
Believe me when I tell you that car must have had the dryest trunk in the North East from that day forward. I had actually given up on the water in trunk issue at that point, so to accidentally fix the issue for $0 and a very light amount of labor was quite incredible.
Hopefully this helps someone out. I remember now what a headache this was.
Jokerhotpocket is offline   Reply With Quote
who else has firefox + acrobat problems? mattjk Off-Topic 17 11-22-2005 12:44 PM
CDT and STi's... Who else has this combo? Kehmon Car Audio, Video & Security 11 04-02-2004 10:06 PM
reverse griding question...who else has this problem? M32WRXin3seconds Newbies & FAQs 18 05-27-2003 02:53 AM
OBS owners...who else has this rattle?? IMPREZAmike Technical Forum Archive 10 08-23-2000 12:29 AM
