Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 01-07-2012, 05:51 PM   #201
DetailerHaus
Member#: 305960
2006 Subaru STI
needs moar low
I have done this quite a few times... Everyone has their own process.
I apply some glue and label remover to the badge then use floss to dislodge. Removing the sticky backing from the paint is always the worst part. I typically apply more glue and label remover to a microfiber towel and let that soak into the backing. I then gently wipe the are with a microfiber towel to remove the adhesive.
After the material is completely removed, I use a stage 1 polish and an orbital to remove any scratches and correct any hazing caused by the glue and label. This step is then followed up with a coat of wax,
-Michael
DetailerHaus is offline   Reply With Quote
Old 01-07-2012, 06:58 PM   #202
mitchkeller87
Member#: 278819
2008 WRX
Red
Also a good way is to use a heat gun or some type of heat source. I did it and the glue comes off really easy. There might be a little glue left over but goo gone works great.
mitchkeller87 is offline   Reply With Quote
Old 07-11-2012, 01:39 AM   #203
NcKidd
Member#: 133267
2004 psm WRX
Lightbulb
With older cars like mine that tend to leave lots of double-sided tape on the car's surface (after removing the emblems), save yourself some time by spraying some Bug&Tar remover on the areas several times over 20 minutes & then carefully scrape of the majority of the residue with a razor blade. It's pretty hard to scratch your paint this way if you have a steady hand. This will save you 20-30 min of trying to 'wipe away' all the goop as others have described.
Then just rub down with some GooBeGone, let set for a few minutes and start applying some elbow grease with a terry towel. All that's left is to buff out & Wax.
Start to finish shouldn't take more than about 45 minutes.
NcKidd is offline   Reply With Quote
Old 11-18-2012, 12:30 AM   #204
sprocket_rocket
Member#: 335012
2012 WRX Sedan
I went with the bondo spreader technique. If you've got one lying around, give it a try. Use plenty of goo gone/goof off, and you'll be done in no time!
sprocket_rocket is offline   Reply With Quote
Old 11-18-2012, 01:01 AM   #205
Spec-C 2010
Member#: 337849
I used a head gun and a badge eraser wheel for the glue, but I also did it right after I got my car so they came right off no prob.
Spec-C 2010 is offline   Reply With Quote
Old 11-18-2012, 06:04 AM   #206
pghmtnbiker
Member#: 323023
2013 WRX Hatch
I used fishing line to remove the badges then just rubbed the left over glue off with my finger. Took 10 minutes to do the back of my new hatch. finished up by washing, sealing, then waxing.
pghmtnbiker is offline   Reply With Quote
Old 11-19-2012, 08:30 AM   #207
Ian G.
Member#: 303086
2008 Subaru WRX
Dark Grey
I just heat them up with a hair dryer til you can move them with your fingers. Get a credit card and pry them off. Make sure the area is clean first obviously (wash wax) . Spray some quick detailer where the badges are removed and get extra adhesive with finger nails. Any left overs I use meguiars scratch x and the ghosting is gone after one pass
Ian G. is offline   Reply With Quote
From me to you! (The merged Merry Christmas thread) subiepntbllr North West Impreza Club Forum -- NWIC 76 12-26-2008 12:54 AM
Attn: Jamz (the merged thread) subarurabbit New England Impreza Club Forum -- NESIC 42 04-12-2002 08:42 PM
Debadging technique yakabazzi Interior & Exterior Modification 9 10-20-2001 12:01 PM
