Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 03-21-2011, 03:16 PM   #51
tcarter
Member#: 12366
Yah I was really thinking about just taking to to get it emptied out, then in my own time replace the parts and take it to get it oiled/charged. I just didn't want to pay for that part when I'm capable of doing it myself.
tcarter is offline   Reply With Quote
Old 03-21-2011, 07:37 PM   #52
rick-l
Member#: 33868
2003 wrx
srp
Originally Posted by 2Fast4U1DAY View Post
The A/C system is one of the things on a car that you absolutely should not touch, unless you are Section 609 certified
609 certified just means you remembered to say I won't vent CFCs to the atmosphere when asked.
It has no technical qualification implications.
rick-l is offline   Reply With Quote
Old 03-21-2011, 09:48 PM   #53
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
It most certainly qualifies you to service other peoples systems. Without it you could be subject to hefty fines. And its not just about not venting to atmosphere (though you could be fined $25k+ if caught doing so).
2Fast4U1DAY is offline   Reply With Quote
Old 03-21-2011, 10:27 PM   #54
rick-l
Member#: 33868
2003 wrx
srp
You should go to EPA.gov and read about it. All it lets you do is buy CFCs like r-12
EDIT: $19.99 and an open book on-line test and you too could be EPA 609 certified. And to pass the test, repeat after me: "I will not vent refrigerant to the atmosphere".
RE-EDIT It went down in price.
Old 03-21-2011, 10:37 PM   #55
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Section 609 certifies you to work on other peoples A/C systems. It has very little bearing on technical knowledge of A/C systems. And technically, only one person in a shop has to be 609 certified.
I agree, though, that giving Jimmy a can of Autozone refrigerant (SEALANT! ICK!!) is a recipe for environmental, financial (on Jimmy's part), and automotive disaster. You're not going to get the correct charge by shaking a can until a cheap gauge set reads a certain PSI. You need an accurate, digital scale.
Long story short: You might save hundreds doing the work yourself or you might **** your A/C system up even more and cost yourself a LOT more money than just paying a pro in the first place.
Sealant=
Wrencher86 is offline   Reply With Quote
Old 03-22-2011, 01:26 AM   #56
rick-l
Member#: 33868
2003 wrx
srp
609 certifies you have had training to handle refrigerant. It doesn't
say you know squat about air conditioning.
Old 03-22-2011, 08:47 AM   #57
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Sealant=
If only one person is certified, than only that person can work on the system. It's not a shop certification. Its a per person certification. Working on someone elses system for profit without the certification is a violation of Federal law.
Old 03-22-2011, 09:26 PM   #58
z
Member#: 41762
04 STi
in ur Floriduh
I'm getting a little 'chirp' from the A/C fan clutch every time the clutch engages.
Anyone know much about this? Can I replace just the fan clutch on the compressor?
(or throw some grease in there somewhere?)
z is offline   Reply With Quote
Old 03-22-2011, 10:54 PM   #59
rick-l
Member#: 33868
2003 wrx
srp
Probably the belt is a little loose. Per the manual to have a used belt deflect 3/10 of an inch when you put 22 lbs force on it is incredibly tight.
Old 03-23-2011, 10:04 AM   #60
z
Member#: 41762
04 STi
in ur Floriduh
^Cool, i'll check that out.
I had recently taken everything off to pull the motor so I may have left it a little loose.
Old 04-10-2011, 02:05 AM   #61
HellaWRX
Member#: 261374
2012 Legacy 2.5i
Dark grey metalic
Just ordered a condensor w/dryer and expansion valve from here: http://www.rockauto.com/catalog/raframecatalog.php
Got a high pressure hose from a member here and going to follow the DIY when it all arrives.
HellaWRX is offline   Reply With Quote
Old 04-11-2011, 12:38 PM   #62
rick-l
Member#: 33868
2003 wrx
srp
Is the hose bad? Mine it was just the o-ring. That fitting sees a lot of heat and vibration.
If you get a used hose you want new o-rings anyway. lubricate them with PAG100 oil. belive it or not the amount in the manual for the condeser is 1/4 ounce???
http://forums.nasioc.com/forums/show....php?t=1780808
Old 04-13-2011, 02:34 PM   #63
HellaWRX
Member#: 261374
2012 Legacy 2.5i
Dark grey metalic
Replaced the O-ring on the high pressure hose at the compressor still had a leak. After cleaning all of the lines so leaks would show up easier I noticed dots of AC oil (and UV dye) equa-distant apart along the rubber hose eventually dripping down... I assumed the hose was bad
Received some parts still waiting on the rest to start the project.
I'm replacing:
Condenser and dryer
Expansion valve
high pressure hose (have spare low pressure)
and Fram ventilation filter (while i'm in there behind the glove box)
I'm thinking of getting the system pumped and recharged by a professional instead of buying a pump (no one rents them around here), manifold tubes, and recharge can. Depending on what they will charge $$$... no pun intended
Old 04-13-2011, 07:43 PM   #64
tcarter
Member#: 12366
Quick question. If your AC is cold for 1-5 minutes then goes warmer and warmer to the point of not being AC at all is that a sign of bad condenser/dryer? I have no leaks at all it was tested for leaks. Should I replace the condenser/dryer and expansion valve? Or could it be the compressor? I am getting the system discharged and doing the other work myself and then taking it back for the recharge. Should I replace everything or just the condenser/dryer and expansion valve?
Old 04-13-2011, 11:20 PM   #65
rick-l
Member#: 33868
2003 wrx
srp
When it hasn't been cooling for a while and you park the car does it leave a big puddle of water under it (evaporator frozen up)?
Do you have gauges to see what the pressures are when it is not cooling (expansion valve sticking)?
Old 04-14-2011, 09:03 AM   #66
tcarter
Member#: 12366
I have no gauges. Yeah I think it did leave more water under the car than a normal AC would. I'm not 100% positive as I gave up on AC about 3 years ago. I was just getting back to it and thinking about fixing it. If it is freezing up and there are no leaks what is the next step?
Old 04-14-2011, 02:02 PM   #67
rick-l
Member#: 33868
2003 wrx
srp
Looking at your post again 1-5 minutes would be pretty quick to form ice on the evaporator but there is a TSB about that: Look herehttp://forums.nasioc.com/forums/show...orator+ice+tsb
You could be just low on r-134. You can look at the pressures to see if the evaporator is starved.
Unfortunately the only way to fill it is to start from zero either by removing all the r-134 or if it all leaked out and you pulled it to vacuum.
You could do a search for expansion valve and see if your symptoms match
If you got some gauges and a thermometer you could ask a question over at this palce. http://www.autoacforum.com/categories.cfm?catid=2 The guys that run it know this stuff.
Old 04-19-2011, 06:11 PM   #68
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
good info
cueballsi is offline   Reply With Quote
Old 06-06-2011, 09:28 PM   #69
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
How's AC system in you guys' Subaru? Do you really have to crank up the A/C to get the cold air going? Also, RPM / vacuum shifts significantly to the point it's annoying to drive at times.
That's my observation on my 02 WRX after I did work to replace expansion valve and condenser/drier.
Old 06-06-2011, 10:07 PM   #70
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
No problems here on my 02, original compressor and almost 150k. Just had to replace the top compressor o-ring. I get a pretty steady 40 degrees out of the center vent whether I'm idling in traffic, or on the highway.
NitroTrike is offline   Reply With Quote
Old 06-07-2011, 06:11 AM   #71
oguitar
Member#: 206720
2002 WRX Wagon
In the extreme heat of summer my AC seems to get heat soaked. If I am moving it works great but if I get stuck in traffic it does not seem to work so well.
oguitar is offline   Reply With Quote
Old 08-18-2011, 02:46 PM   #72
Luizwrx
Member#: 188577
2003 EJ207
Hey guys do i have to put some type of ac conditionor on the o rings?
Luizwrx is offline   Reply With Quote
Old 04-02-2012, 10:02 AM   #73
Parky50
Member#: 292176
2012 GR STi Hatch
Anybody know the Autozone part # for the o-rings listed in the first post?
Parky50 is offline   Reply With Quote
Old 05-11-2012, 12:28 PM   #74
stompinstu
Member#: 189330
2008 Impreza STI
2Fast4U1DAY must work for Oshlapa. he's so worried about being compliant that he forgot that the government works for him. not the other way around.
subject to heft fines just means 'we can legally tax you more money'. and its not illegal unless you get caught. I dont need them one bit, but they sure as hell need us. the EPA is a joke. any government program is a joke.
i'll change my stance on the above when this statement proves to be false: 'If throwing money at people worked, then it would have worked by now.'
stompinstu is offline   Reply With Quote
Old 05-16-2012, 10:13 AM   #75
Dat8687
Member#: 243261
2004 WRX
Java black pearl
MY ac went out.. The clutch on the compressor messed up. You can turn it but then it gets hard to turn then easy to turn then impossible to turn.
1,100 to fix.. Getting done now at the dealership. Replacing the compressor and other parts as well
Dat8687 is offline   Reply With Quote
Auto AC Repair...Fix teh hole or replace the line? volume311 Off-Topic 17 08-03-2013 10:57 AM
DIY AC Air filter clean Liberty1996 Legacy Forum 3 07-11-2006 10:50 PM
AC repair question - Is the repair suggested reasonable? Malik Service & Maintenance 4 06-17-2005 12:47 PM
HELP: home furnace/ac repair subie2b Mid Atlantic Impreza Club -- MAIC 0 08-20-2004 05:20 PM
Home AC Repair suggestions... kschmohl Mid Atlantic Impreza Club -- MAIC 8 07-01-2004 02:54 PM
