Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 01-03-2011, 09:49 PM   #76
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Originally Posted by Token-Negro View Post
In the engine bay you might also think about going to a softer cloth braided line the SS stuff is brutal on anything that comes into contact with it. You can also cover it with fire sleeve and tape the ends down if you really want the SS braid. Another trick is using heat shrink tubing over the SS braid.
Now that one I through of already! I purchased 20ft of fire sleeve which should get me through the whole project an I have been putting it on everything. Speaking if which, if you ever need fire sleeve, these guys have the BEST price and the stuff is identical to DEI's product:
http://performanceplusconnection.us
dexterous is offline   Reply With Quote
Old 01-04-2011, 07:47 PM   #77
one11
Member#: 255398
looks good
one11 is offline   Reply With Quote
Old 01-04-2011, 08:25 PM   #78
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
I love these homemade threads, sweet build!Subscribed to inspire me to build mine soon.
EROCS04SBRUSTI is offline   Reply With Quote
Old 01-04-2011, 09:11 PM   #79
john 1badSTI
Member#: 77470
04 sti [email protected]
on [email protected] 30psi--spinning
get on it eric spring is right around the corner.
john 1badSTI is offline   Reply With Quote
Old 01-04-2011, 10:31 PM   #80
dexterous
Member#: 23553
2014 WRX - Daily
My next post after this one should be with pics of the Twin Scroll EVO 9 FP Red turbo that I plan on running. I got a chance to see it the other day but I was actually going in for a photo shoot so I couldn't take it home yet. I am really excited about finally getting it!
Old 01-05-2011, 11:59 AM   #81
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Sweet! Can't wait for some pics!
u2_m4r1n3 is offline   Reply With Quote
Old 01-05-2011, 06:30 PM   #82
garagedefeat
Member#: 101399
2001 Forester L
Originally Posted by Fuj1wara View Post
Great build so far, looking to your progress
However, this image is the reason why I wont use that header, look at the excess length of the exhaust manifold. Excess length is less efficiency, and our stock header setup already is longer than it should be.
Good luck with your goals, I'll be following along to see how it goes!
Yeah, who in their right mind would put a header on a Subaru with "excess length?" Well for one, Prodrive, when they built Subaru's WRC cars. Many turbo headers are longer than what you think they *should* be
garagedefeat is offline   Reply With Quote
Old 01-05-2011, 07:04 PM   #83
Fuj1wara
Member#: 249207
2010 STi SE
Not going to clog up this guy's thread with a debate, we can go elsewhere or pm it. What I'm saying is it's less efficient. Not that its terrible and that it wont produce power. Look at the new legacy turbo placement.
Fuj1wara is offline   Reply With Quote
Old 01-05-2011, 07:09 PM   #84
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Agreed! Not to mention the above header (like nearly all WRC headers) has ALS, negating length and the time to spool issue.
KillerBMotorsport is offline   Reply With Quote
Old 01-05-2011, 11:24 PM   #85
dexterous
Member#: 23553
2014 WRX - Daily
As promised, here it is! This is an Evo 9 spec Twin Scroll HTA FP Red. It features the 84mm Flow Advancement Port™cover, an HTA wheel and a 10.5cm hot side.
Old 01-05-2011, 11:32 PM   #86
stav05sti
Member#: 222771
2005 Impreza WRX STi
Seems like a lot of research and thought has gone into this build. Congrats! Everything looks good! Hope it all comes out as you want. Subscribed to updates and very anxious to see a dyno graph.
stav05sti is offline   Reply With Quote
Old 01-06-2011, 11:35 AM   #87
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
^^^^Good Info^^^^
rexworx is offline   Reply With Quote
Old 01-06-2011, 03:19 PM   #88
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
cursed!! you beat me to it
also there is a deal of resonanace tuning that can be addressed. Not every setup is designed for the most effecient low end grunt.
WRC has ALS for low end and longer runners to help with VE's when approaching choke flow.
Quite anxious to see how this Red will perform.
Old 01-06-2011, 07:06 PM   #89
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Problem is john all the parts here, but no friggin heat,looking for a good wood burner motor/tranny to do and the weather is all to fast.
Old 01-07-2011, 10:14 PM   #90
dexterous
Member#: 23553
2014 WRX - Daily
Working without heat is horrible! Two years ago I installed a gas heater in my garage and it's awesome!
Old 01-08-2011, 01:11 AM   #91
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Default great build!
^^^^^Sorry to impose great build by the way^^^^^. Was thinking about gas too but I have to run the underground line.Garage not attached.Kerosine fumes are bad,Propane expensive,wood burner for cheap and $15 for a truckload of amish slabwood!Try busting a few knuckles when its cold out... Subect change..So the turbo is all billet wheel that I see?Like to see when full boost spools up at.Are you staying iwg or ewg?Subscribed of course...
Old 01-08-2011, 01:41 AM   #92
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
I'm in the process of putting together my fuel setup and your thread can help me with this. I will also do my due diligence with talking to different Manufacturer's tech support and some local Subaru enthusiasts. I have a Fuelab 140 lph pump on the way.
methaddict is offline   Reply With Quote
Old 01-08-2011, 06:54 PM   #93
garagedefeat
Member#: 101399
2001 Forester L
Big Snail!
Last edited by garagedefeat; 01-08-2011 at 07:20 PM. Reason: mountains, molehills and the like
Old 01-08-2011, 09:22 PM   #94
BumbleBeeTuna
Member#: 234879
2003 WRX WAGON
Glad to see there are more companies coming out with TS kits, after my vf37 install, I have definitely been bitten by the TS bug.
Awesome build, can't wait to see it done! Subscribing.
BumbleBeeTuna is offline   Reply With Quote
Old 01-09-2011, 10:04 AM   #95
dexterous
Member#: 23553
2014 WRX - Daily
That's a really good question. I was actually sitting here thinking the exact same thing. Once i have the motor in the car I will post lots of good Picts from angles that show the answer as clearly as possible.
PM me I you want more info. I have lots of thoughts of how it could have been done better a second time around.
Old 01-09-2011, 04:16 PM   #96
dexterous
Member#: 23553
2014 WRX - Daily
I posted a thread in another forum (exterior) but I figured that I would ask here as well. If anybody has experience with my question in THIS THREAD please let me know. Thanks!
Old 01-17-2011, 11:38 AM   #97
dexterous
Member#: 23553
2014 WRX - Daily
I just got a ton of little things that were holding me up plus my new Moore Performance turbo inlet. It looks very similar to the APS hard inlet only its much larger and curved at the end. I travel a lot during the week for work and I forgot to snap a pict on my way out the door today. Bummer. I should be flying home mid week and I will take picts then.
Old 01-20-2011, 07:58 PM   #98
dexterous
Member#: 23553
2014 WRX - Daily
Here's the inlet:
Old 01-20-2011, 09:24 PM   #99
Fuj1wara
Member#: 249207
2010 STi SE
nice. when I switched to a hard inlet I had to get rid of the hard crank case lines for it all to fit properly.
Old 01-21-2011, 06:59 PM   #100
dexterous
Member#: 23553
2014 WRX - Daily
This seems to fit pretty well. By the way, notice that the inlet does not have a return for a factory style BOV? I run a TiAL and speed density so that works out really well for me. It also makes fitment way easier.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
