Welcome to the North American Subaru Impreza Owners Club Sunday October 13, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine Management
Old 12-08-2017, 02:09 PM   #776
Motion Lab Tuning
Vendor Sales Rating: (7)
Member#: 228856
It's Wednesday December 6th and we at Motion Lab would like to be your one stop shop for your engine management and electronic needs. We have the ability to tune vehicles utilizing a wide range of management systems & the best deals on the AEM Electronics. Free ground shipping for all COBB AccessPorts anywhere in the 48 states!
AEM EMS - Series 2: AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
Legal in California only for racing vehicles which may never be used upon a highway.
AEM Series2 Key Features:
  • Plugs directly into the factory harness. No rewiring necessary.
  • Uses all the factory sensors.
  • Includes start up calibrations.
  • System is fully enabled and unlocked - Never pay for upgrades!
  • Context sensitive help eases tuning process.
  • Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
  • Runs on Windows-compatible software.
  • 12 peak and hold injector drivers (Supra only).
  • 8 direct-fire coil outputs.
  • 16 general-purpose outputs.
  • 8 definable switch inputs.
  • 4 EGT inputs with fuel control.
  • 1MB of internal data logging.
  • Electronic boost control.
  • Full idle control.
  • Programmable traction control.
  • Software definable knock control.
  • Two step launch control.
  • User configurable soft-cut rev limiters.
  • Wet or dry nitrous control.
  • Tune using new USB communication port or serial port.
  • Works with all AEM gauges.
AEMTUNER Software Features:
  • Support Pane gives tuners context sensitive help and uses tuners’ actual calibrations to describe each function.
  • Internal conflict detection notifies tuner if obvious errors exist in assignment of inputs/outputs.
  • Compare Calibrations allows tuners to graphically compare tables and maps for easy analysis.
  • Workspaces are easily customizable and configurable.
  • Colored tables and maps.
The Infinity ECU delivers state-of-the-art electronic fuel injection (EFI) control technology which provides durability, flexibility and capabilities typically found only at upper echelons of Motorsports. We have now made this technology affordable for both professional race teams and amateur racers. Built around a latest-generation 200MHz automotive processor, the Infinity ECU is capable of processing 400 MIPS (millions of instructions per second) and is perhaps the fastest ECU available today.
All Infinity ECU’s come fully enabled without the need for feature add-on purchases for a limited time. Combined with AEM’s industry leading after-purchase support, including free technical support, the Infinity is the ultimate engine control solution for both professional race teams and weekend track cars.
Inifinity EMS Features:
  • Compatible with most factory and performance aftermarket sensors
  • Includes start up configurations (supported applications only)
  • Fuel control resolution to 1/10th of a microsecond (.0000001 sec)
  • ECU set up wizard
  • USB 2.0 High-Speed communications
  • High-speed USB data logging to mass storage device (4GB included, tested to 64GB)
  • Internal data logging playback mode on every channel, synchronized with all controls
  • Tune using USB communication port (optional weatherproof extension cable sold separately)
  • 2-Channel CAN included
  • User interface features 3D graphics
  • Internal simulator
  • AEMdata data analysis software included
Infinity EMS Capabilities:
  • Airflow model based calculations
  • VE-based engine startup
  • Multi-fuel capable
  • Flex fuel compensated – fuel, ignition and boost with blend
  • Multiple boost control strategies (time, gear, vehicle speed, switch and more)
  • Drive by wire (with Advanced Tuning Package)
  • 2-step programmable launch control (3-step with Advanced Tuning Package)
  • Programmable traction control, 2-wheel speed or engine acceleration (4-wheel speed with Advanced Tuning Package)
  • No-lift shift (Requires Advanced Tuning Package)
  • User configurable anti-lag
  • Map switching (4 Separate ignition maps, 4 separate Lambda target maps, 2 separate VE tables)
  • Single stage wet or dry nitrous control (4-stage with Advanced Tuning Package, coming soon)
  • Integrated engine protection strategies
  • Target Lambda table, 10x10
  • Open-loop fuel pressure compensation
  • O2 lean-out protection
  • 2-channel adaptive knock control
  • Configurable coil dwell (RPM, voltage and load based)
  • Individual cylinder ignition trim (RPM based)
  • Individual cylinder fuel trim (RPM based)
  • 3D ignition trim maps (coolant and air temp)
  • Real-time sensor diagnostics
  • Ignition table, 20x20
  • VE airflow table, map vs. engine speed, 20x20
  • User adjustable charge temperature blend (CLT/AIT, engine speed dependent)
  • Idle control (stepper and pulsewidth)
We offer the lowest pricing on the net for AEM Electronics! Check out all other AEM Electronics HERE We are sponsored by AEM and have pricing better than the distributors! Let us know what you need from AEM and we can get the lowest prices for you Nasioc members. AEM gauges available in Digital or Analog & Great low pricing on their Meth injection system as well!
Cobb Accessport V3: The Accessport is the world's best selling, most flexible, and easiest to use ECU upgrade solution for your Subaru. Unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. Follow our staged upgrade path with pre-loaded Off-The-Shelf (OTS) maps or use custom mapping for any modification level. It's the last engine management solution you'll ever need.
Features of the Cobb AccessPort:
  • Simple Installation: Everything is included for the simple installation! Intuitive on-screen instructions identify your exact vehicle and available maps.
  • Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
  • Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
  • Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
  • Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 10 hours.
  • Performance Measuring: Welcome to your own performance evaluation suite! Measure 0-60 mph time, 60 foot and mile ET’s. and Trap Speed.
  • Launch Control: Set RPM threshold for performance launching the car from a stop. Builds boost and generates instantaneous horsepower off the line.
  • Flat Foot Shifting: Keep the throttle on the floor during shifts and maintain boost between gears with this customizable RPM setting.
PM, call, or E-mail for most up to date pricing! We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
[email protected]
MotionLabTuning.com - Engineering Performance
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
[/CENTER]
[center]
[/center]
Motion Lab Tuning is offline   Reply With Quote
Old 12-12-2017, 01:29 PM   #777
Motion Lab Tuning
Member#: 228856
It's Tuesday December 12th and we at Motion Lab would like to be your one stop shop for your engine management and electronic needs. We have the ability to tune vehicles utilizing a wide range of management systems & the best deals on the AEM Electronics. Free ground shipping for all COBB AccessPorts anywhere in the 48 states!
  • ECU set up wizard
Thanks for looking!
Alex Goodwin
[email protected]
__________________
Email:
Facebook:
Instagram:
[/CENTER]
[center]
[/center]
Old 12-19-2017, 04:40 PM   #778
Motion Lab Tuning
Member#: 228856
It's Tuesday December 19th and we at Motion Lab would like to be your one stop shop for your engine management and electronic needs. We have the ability to tune vehicles utilizing a wide range of management systems & the best deals on the AEM Electronics. Free ground shipping for all COBB AccessPorts anywhere in the 48 states!
  • ECU set up wizard
Thanks for looking!
Alex Goodwin
[email protected]
__________________
Email:
Facebook:
Instagram:
[/CENTER]
[center]
[/center]
