Welcome to the North American Subaru Impreza Owners Club Monday October 21, 2019
Old 08-12-2015, 04:51 PM   #26
mrtouchdown
Member#: 258082
2010 WRX STI
Originally Posted by Gallo2011 View Post
The radiator of your car is fully functional in winter. The hoses go through the same heat cycling they do in summer. They become brittle and weak for that reason so outside weather shouldn't determine the replacement interval.
Replacement in the spring! Thanks
mrtouchdown is offline   Reply With Quote
Old 08-12-2015, 05:41 PM   #27
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Inspect the parts before you spend money replacing them. It's possible they're still in perfect working order. Especially if you're not seeing any symptoms to indicate the engine is overheating.
Gallo2011 is offline   Reply With Quote
Old 08-13-2015, 08:05 AM   #28
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
^this... If you inspect you radiator and hoses thoroughly and they check out, no reason to replace them when a proper flush will keep you operating smoothly.
bdubblu is offline   Reply With Quote
Old 08-13-2015, 09:49 AM   #29
AWDenvy
Member#: 202140
2007 Fozzie
Grey
Just bought a Forester last night with 80k on the clock. Great write-up, going to be putting it to very good use in the coming weeks/months.
AWDenvy is offline   Reply With Quote
Old 08-13-2015, 11:29 AM   #30
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
The key is to do this maintenance over time so that the bills and work are more spaced out and more bearable.
Ernest is offline   Reply With Quote
Old 08-13-2015, 12:57 PM   #31
reaganchung
Member#: 416769
2003 WRX vf48
Cracked my radiator pretty much the day after i read this..... 123K
reaganchung is offline   Reply With Quote
Old 08-14-2015, 12:14 AM   #32
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
measure the thickness of original rotors. If less than the value stamped on them, replace.
1 Lucky Texan is offline   Reply With Quote
Old 08-14-2015, 01:42 PM   #33
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Unless you know what you are doing the 100k maintenance can get pricey.
Scorpius is offline   Reply With Quote
Old 08-14-2015, 02:26 PM   #34
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
126K.
Fortunately, I have already done many of the items listed.
Unfortunately, I have not done many of the items listed.
Turbo inlet being one of them. Yes...I think (well....I know) I have an air leak. Faint, tiny, almost squeak like whistle under boost. Faint enough for me to ignore......at least until reading this post. I've done everything to my car myself (susp, turbo, inj....etc...) but for some reason the t-inlet has me intimidated.
Pitch stop and engine mounts are close behind in necessity...
Brock31 is offline   Reply With Quote
Old 08-14-2015, 02:47 PM   #35
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
Originally Posted by Unabomber View Post
countless hours performing trend analysis here on NASIOC.
Should I read this as "Sitting online reading NASIOC all day in my underwear in my moms basement"? Or is there more to your analyses?
Last edited by 86Dreams; 08-14-2015 at 02:59 PM. Reason: added clause about underwear
86Dreams is offline   Reply With Quote
Old 08-14-2015, 03:34 PM   #36
mrtouchdown
Member#: 258082
2010 WRX STI
Originally Posted by Brock31 View Post
126K.
i just ordered my T-I. having the same problems, very poor power with that thing leaking and causing CEL all the time when i boost. pain in the arse.
Old 08-14-2015, 03:55 PM   #37
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Fortunately no cel's and no noticeable power loss, but I'm sure that's not far down the road.
Old 08-14-2015, 08:27 PM   #38
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Originally Posted by reaganchung View Post
Do you know where to find part numbers for oem bcs?
16102AA160 or 16102AA360
Confirm with dealer
I highly recommend replacing the vacuum hoses to/from the solenoid as they will harden-up over time and crack (leak).
Old 08-14-2015, 08:32 PM   #39
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Why? 100k would be an oil change, timing belt is not due for another 5k
Old 08-14-2015, 08:32 PM   #40
Big-E
Member#: 123843
2016 STI LTD CWP
Timing belt and related items @ 105k miles <OR> 105 months, whichever comes first.
I, along with two friends, did mine at 100 months (and only 77k miles).
Old 08-14-2015, 10:11 PM   #41
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
That's a fairly accurate assessment.
Old 08-15-2015, 10:54 AM   #42
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Touche Hondaslayer.
Old 08-15-2015, 01:59 PM   #43
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
No harm in spreading it out a bit. Do the timing belt on time, but most other stuf could wait another 5 or 10k.
For example I did my springs and struts at 80k even though they had life. Got the cost done before I did timing belt. I had to do my TB based on time not miles, only have 108k after 12 years.
My stock radiator still looks good. That's likely my next thing.
Old 08-17-2015, 12:54 PM   #44
mrtouchdown
Member#: 258082
2010 WRX STI
Living in a climate that's so harsh, we have to get stuff done so much faster. Starting a car in -36C does not make any suby happy. The temperature swings don't help either, in the morning we are -20C and by noon we are +10C, silly Chinooks.
Old 08-17-2015, 01:10 PM   #45
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
Yeah my subie hates anything around freezing, can't imagine those temps.
Old 08-17-2015, 01:16 PM   #46
mrtouchdown
Member#: 258082
2010 WRX STI
Thats just without the windchill. Sometimes we get -45 to -50C with windchill. pretty well inhumane
Old 08-20-2015, 09:26 AM   #47
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
105k service:
Timing belt with ALL the pulleys/tensioner
Water pump and thermostat
Radiator and hoses
Accessory belts
Do all of those.
Old 08-25-2015, 06:55 AM   #48
Noah C
Member#: 428641
This is my new checklist for a rebuild/refresh over the next month.
Noah C is offline   Reply With Quote
Old 08-26-2015, 06:05 AM   #49
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Thanks again, as my 06 WRX has 200k on it now and I am the original owner, Ive been wondering what I should look at that I have otherwise overlooked. Thanks for the reminder on the MAF and the BCS. Those may be a missing link or two of mine.
left footed whooten is offline   Reply With Quote
Old 08-26-2015, 07:34 AM   #50
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
new gas cap???
