Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Old 08-26-2015, 02:34 PM   #1
Diode Dynamics
Vendor Sales Rating: (0)
Member#: 406551
2015 STI
Lightbulb Diode Dynamics Performance Lighting Master Thread / Tail-As-Turn™/ Yellow SLF Fogs!
2015+ WRX/STI Fog Light LEDs
Diode Dynamics offers LED bulbs for replacement of your Subaru WRX/STI's fog lights, in all major sizes. They are available in HP, XP, and SLF models. This will make your fog lights a nice bright white (or yellow!) that closely matches factory-equipped HID/LED lighting! Features simple plug and play installation! We also offer Luxeon LED Housings for a complete replacement of your factory fog light housings (2015+ Subaru WRX/STI Model Years) that utilize OEM-quality components and geninune Phillips Luxeon LEDs.
Diode Dynamics carries the brightest, highest-quality lighting products available. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several bulb models so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Much brighter than factory. These are bright! USA Made!
*SLF is available in 3000K Yellow / 5700K Color Temperature Options*
Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumination, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
Included in your order is TWO BULBS (to fit your Subaru 2015+ WRX/STI).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2015+Subaru WRX/STI Fog Light LED
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline   Reply With Quote
Old 08-26-2015, 02:35 PM   #2
Diode Dynamics
Member#: 406551
2015 STI
Old 08-28-2015, 11:45 AM   #3
Diode Dynamics
Member#: 406551
2015 STI
Old 08-31-2015, 03:31 PM   #4
Diode Dynamics
Member#: 406551
2015 STI
Default Diode Dynamics 2015 Subaru WRX / STi Tail as Turn™ +Backup Module
2015 WRX/STI Tail as Turn™ +Backup Module
The Diode Dynamics Tail as Turn™ Module + Backup, for the 2015+ WRX or STI! This is a unique mod that was 100% designed by Diode Dynamics in-house, and is manufactured by us right here in St. Louis, Missouri. Made in USA!
The Tail as Turn™ modules will make your nice LED tail light flash as the turn signal as well. With an array of LEDs flashing instead of an amber incandescent bulb, you'll have a unique, modern look!
Then, since your old turn signals are no longer used, you can easily turn them into functional backup lights! You'll drastically increase your visibility.
With the OEM tail light connectors, installation will literally take about 60 seconds, and does not require any wiring at all. I don't think you'll ever find an easier electrical mod! This kit will work with factory or aftermarket tail lights.
The base kit is just $30, which includes a pair of modules with OEM connectors, to convert your LED tail light into the turn signal, with extremely easy installation.
Since you'll be eliminating the factory turn signal bulbs, your vehicle will think the turn signal is out, so you'll need a turn signal flasher module to slow down the hyperblinking. If you already have one, you don't need another. If you don't have one, we offer it with your order for $10.
All kits also come with the extra wire and connector to add backup lights where your old turn signals were, but you do need to run LED bulbs, since you're drawing on the factory backup light circuit. At Diode Dynamics, we also offer the highest-quality LED bulbs on the market, backed by a 3-year limited warranty. For the complete Diode setup, you can add a pair of LEDs to your order, or use any 7440-size white LED.
Your order includes:
(2) Tail as Turn Modules with OEM Plug-and-play Connectors
(1) Power wire to add backup lights
(1) CF18 turn signal flasher (optional, needed to stop hyperblink)
(2) Diode Dynamics LED Bulbs (optional, needed to add backup lights)
Remember: at Diode Dynamics, we're here if you need us for support and service, with our award-winning service team. We have been in business for over 8 years. We feature an industry-leading 3-year limited warranty. Something wrong? We ship you the new item with a return label. No waiting around!
Questions? Please feel free to post, PM, call, or email [email protected]
We are an American company, located in St. Louis, Missouri. We are open 9-5 Monday-Friday CST. Give us a call!
Nick C.
Diode Dynamics
(314) 205-3033
Old 09-02-2015, 03:48 PM   #5
Diode Dynamics
Member#: 406551
2015 STI
Old 09-03-2015, 12:12 PM   #6
Diode Dynamics
Member#: 406551
2015 STI
Default Subaru WRX/STI Reverse/Backup LED Bulbs! Plug & Play!
Subaru WRX/STI Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb. We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs, for perfect fitment in your Subaru WRX/STI Model year selection.
Bulb Design
(921 Bulb Models)
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
(7440 Bulb Models)
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
(921 Bulb Models)
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
(7440 Bulb Models)
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures. Please click here to learn more about LED brightness measurement.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look similar to others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
Thank you!
Nick C.
Diode Dynamics
Old 09-09-2015, 03:05 PM   #7
Diode Dynamics
Member#: 406551
2015 STI
Old 09-15-2015, 03:41 PM   #8
Diode Dynamics
Member#: 406551
2015 STI
Old 09-16-2015, 01:13 PM   #9
Diode Dynamics
Member#: 406551
2015 STI
Nick C.
Old 09-17-2015, 11:14 AM   #10
Diode Dynamics
Member#: 406551
2015 STI
Default Subaru WRX OEM HID Replacement Bulbs! Only $40! Upgrade your HIDs Today!
Subaru WRX Replacement HID Bulbs
These replacement OEM-size HID bulbs will upgrade your Subaru's OEM bulbs, which are slightly warm in color (4300K), to a cool white, modern color. These are quality bulbs, with better performance than most other generic ones on the market. They will not flicker, and they will work every time you turn them on.
Manufacturer: Diode Dynamics has been distributing replacement OEM HID bulbs for over six years, and we have evaluated nearly every bulb manufacturer on the market. We've seen the best, and the worst, and after testing them all, we selected CNLight, because their bulbs are always superior in performance and last longer than others on the market. Look around, and you'll see other top suppliers also providing these bulbs, although some brand them under their own name. CNLight is simply the best aftermarket HID bulb manufacturer currently on the market. Even if you don't purchase them from us, make sure you get CNLight!
Bulb Construction: As we said, CNLight manufactures superior HID bulbs. What does that mean? All HID bulbs have basic parts: connectors, a plastic base, a device that holds the glass tube, and the glass tube, or bulb, itself. Most bulbs use plastic bases that are made up of multiple pieces and a plastic holder for the glass tube. CNLight bulbs use a one-piece base design, and a ceramic holder, which isolates heat from the base, providing much better reliability. It's more expensive to do it that way, but it's the best way to do it!
Color: The most common issue with cheap replacement bulbs is that they don't match perfectly in color. It's a real pain, and it ruins the look you're going for! Why does this happen? The color of each bulb is determined by the yellow stuff in the little bubble in the glass tube on the bulb. This stuff is a chemical mixture of halide salts. The composition of these salts much be mixed perfectly and deposited in precisely the same amounts to ensure a pair of bulbs matches. Cheap manufacturers skimp on this, because it's also an expensive material.
CNLight does it right, and their bulbs will always match perfectly. If you buy another pair of the same color a few months down the road, those will match too! We confirm exact color output by testing our bulbs in-house with the required scientific equipment. Any reputable supplier should have the necessary equipment to conduct this type of quality control, to ensure perfect color uniformity.
What if you get them, try them out, and don't like the color? We offer exchanges with no fees. Just let us know, and we can swap them out. That's our satisfaction guarantee.
Warranty: Do not be fooled by overrated "lifetime" warranties from other manufacturers and distributors. HID bulbs, under normal use, will last about 2500 hours, or 3 years, if used about 2 hours a day. We provide a three-year warranty to back them up for this entire period. Also, keep in mind that the warranty is only as good as what the company actually replaces. Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. We have been in business for over 8 years, and we'll still be here for years down the road.
Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on generic, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
Your order comes with:
*-One pair HID bulbs in your choice of bulb size and color
*-Three-year limited warranty on all components
*-Diode Dynamics 30-day satisfaction guarantee
CLICK HERE TO ORDER
$40 Everyday Low Price!
CLICK HERE TO ORDER
Any questions, feel free to ask via email ([email protected]), send us a PM, or call: (314) 205-3033
Thanks,
Nick C.
Old 09-17-2015, 05:35 PM   #11
Jay508
Member#: 358018
2013 WRX
PM sent regarding bulbs for MY 13 WRX.
Thanx!
Jay508 is offline   Reply With Quote
Old 09-17-2015, 05:39 PM   #12
Diode Dynamics
Member#: 406551
2015 STI
PM Response sent!
Thanks Jay!
Nick C.
Old 09-22-2015, 11:43 AM   #13
Diode Dynamics
Member#: 406551
2015 STI
Nick C.
Old 09-23-2015, 01:13 PM   #14
Diode Dynamics
Member#: 406551
2015 STI
Luxeon Type A LED Housings:
http://www.diodedynamics.com/store/c...category/1446/
Nick C.
Old 09-24-2015, 05:10 PM   #15
Diode Dynamics
Member#: 406551
2015 STI
We have license plate LED lighting available for every Subaru model
Nick C.
Old 10-09-2015, 11:44 AM   #16
Diode Dynamics
Member#: 406551
2015 STI
Don't forget to send us a PM for the free-shipping code!
(U.S. members only)
Thanks!
Nick C.
Old 10-12-2015, 09:16 AM   #17
Diode Dynamics
Member#: 406551
2015 STI
Old 10-13-2015, 08:59 AM   #18
Diode Dynamics
Member#: 406551
2015 STI
Old 10-16-2015, 02:48 PM   #19
Diode Dynamics
Member#: 406551
2015 STI
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
Old 10-22-2015, 11:38 AM   #20
Diode Dynamics
Member#: 406551
2015 STI
Thumbs up Diode Dynamics 2008-2014 Subaru WRX / STi Hatchback Tail as Turn™ +Backup Module
2008-2014 Subaru WRX Hatchback Tail as Turn™ +Backup Module
The Diode Dynamics Tail as Turn™ Module + Backup for the 2008-2014 Subaru WRX Hatchback! This is a unique mod that was 100% designed by Diode Dynamics in-house, and is manufactured by us right here in St. Louis, Missouri. Made in USA!
With the OEM tail light connectors, installation will only take about 60 seconds, and does not require any wiring at all. We don't think you'll ever find an easier electrical mod! This kit will work with factory or aftermarket tail lights. Installation is 100% Plug and Play
The base kit is just $40, which includes a pair of modules with OEM connectors w/built-in resistors to convert your LED tail light into the turn signal, with extremely easy installation.
(2) Tail as Turn™ Modules with OEM Plug-and-play Connectors
Remember: at Diode Dynamics, we're here if you need us for support and service, with our award-winning service team. We have been in business for over 9+ years. We feature a hassle-free 3-year limited warranty. Something wrong? We ship you the new item with a return label. No waiting around!
Nick C.
Diode Dynamics
(314) 205-3033
Old 10-23-2015, 09:49 AM   #21
Diode Dynamics
Member#: 406551
2015 STI
Old 10-28-2015, 04:53 PM   #22
Diode Dynamics
Member#: 406551
2015 STI
Old 11-18-2015, 09:43 AM   #23
Diode Dynamics
Member#: 406551
2015 STI
Some more exciting new things happening at Diode! We have recently invested in a state-of-the-art ROMER coordinate measuring machine and 3D printer, allowing us to bring new products to market quicker than ever before. Check out the link to our recent blog post below for the full write-up!
Automotive Lighting Designer Ramps Up Manufacturing at St. Louis Facility | Diode Blog
Thanks!
Nick C.
Old 11-27-2015, 11:25 AM   #24
Diode Dynamics
Member#: 406551
2015 STI
Old 11-28-2015, 02:54 PM   #25
Diode Dynamics
Member#: 406551
2015 STI
The amber turn signal on our C-Light LED replacements produce 1,200 lumens! (measured)
Nick C.
