Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Old 08-07-2017, 01:08 PM   #101
Diode Dynamics
Vendor Sales Rating: (0)
Member#: 406551
2015 STI
Diode Dynamics is offline   Reply With Quote
Old 09-14-2017, 12:51 PM   #102
Diode Dynamics
Member#: 406551
2015 STI
Diode Dynamics 30" (SS30) Stage Series Light bar installed!
@ 20jonizzlewrx
Old 09-29-2017, 10:58 AM   #103
Diode Dynamics
Member#: 406551
2015 STI
@ Rubythesubie added an SS12 light bar for additional reverse lighting on this Subaru XV!
Amazing photo!
Nick C.
Old 11-27-2017, 02:41 PM   #104
Diode Dynamics
Member#: 406551
2015 STI
Don't forget to send us a PM for the free-shipping code!
Nick C.
Old 12-27-2017, 05:18 PM   #105
Diode Dynamics
Member#: 406551
2015 STI
Diode Dynamics: Tail as Turn WRX Hatch - Reid Elattrache
Old 01-22-2018, 04:34 PM   #106
Diode Dynamics
Member#: 406551
2015 STI
How to Install 2008-2014 Subaru Impreza SLF Fog Light LEDs | Diode Dynamics
Old 02-13-2018, 11:42 AM   #107
Diode Dynamics
Member#: 406551
2015 STI
Diode Dynamics SmartTap™ CF18 LED Flasher Module
In stock and ready to ship!
Nick C.
Old 02-23-2018, 05:47 PM   #108
Diode Dynamics
Member#: 406551
2015 STI
How to Install 2004-2017 Subaru Impreza Headlight LEDs | Diode Dynamics
Old 02-26-2018, 10:24 AM   #109
Diode Dynamics
Member#: 406551
2015 STI
How to Install Pro Series RGBW Demon Eyes by Diode Dynamics
Old 02-28-2018, 10:55 AM   #110
Diode Dynamics
Member#: 406551
2015 STI
Why Do Yellow LEDs Look Green? | Yellow LED Fog Lights from Diode Dynamics
Old 03-15-2018, 11:30 AM   #111
Diode Dynamics
Member#: 406551
2015 STI
SL1 LED Headlight for Subaru WRX
Diode Dynamics is pleased to offer the USA-made SL1 LED headlight for Subaru WRX applications.
SL1 LED Headlight. If you're looking to improve your visibility at night, you've probably seen many options available for LED upgrades. There's plenty of LED bulbs on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months. With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, the SL1 LED finally provides a true upgrade in performance.
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your car's headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. To correct this, the SL1 LED headlight bulb was engineered with advanced optical design software, to perfectly match filament location. This allows the SL1 LED to focus light just like an original bulb, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern on the road, in compliance with photometric standards, for a safe, functional output, which we call Street Legal.
Tested to Perform. We test the SL1 bulb in factory headlamps, and measure the entire beam pattern using specialized equipment. It's an elaborate affair: a headlight is mounted to a computer-controlled rotating head called a goniometer. Light shines down a tunnel, where a sensor collects data as the headlight is rotated. The entire beam pattern is mapped, and we compare the total output to the original halogen, confirming that the SL1 bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, like the 2015 F-150 Halogen lamp below, there is 30-70% more light in the critical hotspot, with no added glare or spread of light. With optical engineering, testing, and validation in the application, we can assure correct optical performance.
*THIS IS NOT PHOTOSHOP*
Staying Cool. You may have seen bulbs that use large straps for cooling, or fans that just make noise. These bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless microfan. The result is a highly-effective and reliable cooling system, keeping the bulb running at maximum potential.
Fitment. With its patent-pending design, the SL1 LED fits where other bulbs won't, without cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right in, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed for exact applications, not one-size-fits-all, and the compact driver easily tucks away.
Reliability. Every part of the the SL1 LED was designed for reliability, from the high-temperature teflon wire, to the zinc castings, to the reinforced plastics. The compact driver uses a unique boost-mode circuit, which prevents thermal imbalance in the LEDs, and has transient protection for long life in automotive circuits. Finally, the SL1 bulb was put through its paces in our environmental testing chambers - where the bulb successfully performed through dozens of thermal cycles, from -40 through 150 degrees Celsius. The SL1 will keep performing for years, and is backed by a three year warranty.
Experience. After over a decade in business, Diode Dynamics is the most trusted name in automotive LED lighting. Unlike every other LED distributor, we manufacture and engineer products ourselves in the United States, for high quality and fast time-to-market of the newest and brightest LED technologies. We pride ourselves in offering only quality LED products, that will exceed your expectations.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp (CCT): 5700K Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
Click To Order Your Subaru WRX SL1 LED Headlight Replacements:
Diode Dynamics SL1 High Beam LED Conversion Kit for 2004-2018 Subaru WRX
Diode Dynamics SL1 Low Beam LED Headlight for 2008-2018 Subaru WRX
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Old 05-16-2018, 03:16 PM   #112
Diode Dynamics
Member#: 406551
2015 STI
Stock Tail Lights vs Tail As Turn (2011 WRX STI)
Video Posted by BlackProjectSTI
Old 05-17-2018, 03:47 PM   #113
Diode Dynamics
Member#: 406551
2015 STI
Diode Dynamics' SL1 LED Headlights & Yellow SLF LED Fog Lights installed on Austin's 2017 Subaru WRX:
Nick C.
Old 07-02-2018, 12:54 PM   #114
Diode Dynamics
Member#: 406551
2015 STI
Don't forget to send us a PM for free-shipping!
Nick C.
Old 07-02-2018, 04:20 PM   #115
Diode Dynamics
Member#: 406551
2015 STI
Please send us a PM for the free-shipping code!
Old 07-18-2018, 05:41 PM   #116
Diode Dynamics
Member#: 406551
2015 STI
Old 08-09-2018, 11:20 AM   #117
itsse03
Member#: 36864
2019 WRX Sport-tech
CWP-K1X
i'm interested in adding your Tails as Turn module and SmartTap flasher relay to my new 2019 WRX. i'd like to ask a few technical questions around compatibility of features in the SmartTap that Subaru already has in the vehicle like one-touch lane change and welcome light approach/departure.
does the SmartTap tap-to-signal and arrival/departure mode supersede the OEM features in the car without any issues?
for my 2019 model year with LED headlights, the exterior welcome light approach/departure use the headlight/c-light and rear tail c-light. in your SmartTap videos with 2015-2017 vehicle, your arrival/departure mode uses the turn signals front and back. if i add the SmartTap to my vehicle will it use the original default exterior lighting or would that change to the turn signals?
lastly, the load resistors installed in the Tails as Turn module to compensate for hyper blinking, can they be removed if i install the SmartTap? as i would like to avoid the extra current drawn and heat generated from load resistors if they are not necessary. looking at your original Tails as Turn photo release in this thread, the load resistors were not in the initial design and i'm guessing was added later to counter hyper blinking without additional modification.
itsse03 is offline   Reply With Quote
Old 08-09-2018, 11:21 AM   #118
itsse03
Member#: 36864
2019 WRX Sport-tech
CWP-K1X
double post…
Old 08-09-2018, 01:17 PM   #119
Diode Dynamics
Member#: 406551
2015 STI
Hi there!
We're not aware of any compatibility issues whatsoever with the 2019. It should be noted that some vehicles don't allow for the arrival mode with our SmartTap, but the module won't affect the use of the default exterior lighting.
For the resistors, you can definitely remove them if you're going to be using the Tail as Turn.
Thanks!
Jake H.
Diode Dynamics
Old 08-09-2018, 03:56 PM   #120
itsse03
Member#: 36864
2019 WRX Sport-tech
CWP-K1X
so you're not sure if the SmartTap arrival mode works with my 2019 WRX? but if it doesn't work then it won't affect my OEM welcome approach/departure feature. can the SmartTap arrival mode be turned off in case i want to keep using my OEM welcome approach/departure, particularly if different exterior lights are being used between the two? i'd much prefer to use my headlight/c-lights and tail c-lights instead of the turn signals.
Old 08-13-2018, 10:11 AM   #121
Diode Dynamics
Member#: 406551
2015 STI
That's correct, we haven't confirmed the arrival mode function for the 2019. If it does, it will function the same way it does in our
. In the event that it doesn't the car's arrival mode will function as it does from the factory.
Jake H.
Diode Dynamics
Old 08-30-2018, 11:47 AM   #122
Diode Dynamics
Member#: 406551
2015 STI
Do LED Headlights Work In Projector Headlight Housings? Diode Dynamics SL1 Review
Headlight Revolution
Old 09-23-2018, 02:11 PM   #123
JimmyD3135
Member#: 459519
2018 Impreza Limited
Magnetite Gray Metallic
Looking to get LED backup lights for my 2018 Impreza hatchback but you guys don't show anything on the website for the 2018 Impreza. Not seeing them for the 2017 Impreza either. Would the 2018 WRX LED backup lights work on my 2018 Impreza?
JimmyD3135 is offline   Reply With Quote
Old 09-24-2018, 12:16 PM   #124
Diode Dynamics
Member#: 406551
2015 STI
Great question!
Since we haven't confirmed fitment on the '18 quite yet, please feel free to give us a call at 314-205-3033 Monday-Friday 9 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our service team will be happy to find the right bulbs for you!
Jake H.
Diode Dynamics
Old 10-11-2018, 10:07 AM   #125
JimmyD3135
Member#: 459519
Originally Posted by Diode Dynamics View Post
Great question!
Jake H.
Diode Dynamics
Thanks
