Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 11-20-2018, 05:18 PM   #1
JerryG
Member#: 393208
2006 Wrx
Crystal Grey Metallic
Default 2014 WRX - Hard Start / Long crank
If I park the car overnight or go to work (6-8 hours) the car starts fine no issues.
If I head to the gym/school and come out after 1-3 hours and try to start it I have this issue shown in the video.
I took it to a mechanic and a Subaru dealership, both times the car magically went back to normal. I brought recordings and everything but they couldn't get it to happen. When I picked up the car from a shop and the dealership the car started up like normal.
It just gave me a code for a missfire in cylinder #2. I'm going to see if maybe the spark plugs are worn out and check the coilpacks as well.
The car has 46k miles I bought it with 42k. If anyone can maybe help me out on what else to check on thursday I'd appreciate it.
JerryG is offline   Reply With Quote
Old 11-21-2018, 08:58 PM   #2
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Could it be a leaky injector?
jasonwrx86 is offline   Reply With Quote
Old 11-22-2018, 12:12 PM   #3
tramp
Member#: 459629
2017 WRX base
WR Blue
Plugs are cheap. How long since last set?
tramp is offline   Reply With Quote
Old 11-24-2018, 09:09 AM   #4
JerryG
Member#: 393208
2006 Wrx
I was researching and I saw that it could be a possibility.
Old 12-07-2018, 12:57 AM   #5
some dude
Member#: 100300
06 WRX
CGM
That's similar to how my car starts after the battery has been disconnected.
Only the first start after reconnecting it, but really really similar to your video.
some dude is offline   Reply With Quote
Old 06-06-2019, 08:10 PM   #6
Treslocos
Member#: 502940
Default 2014 Hard start
So did you ever figure out what it was? My car just started do this today!
Treslocos is offline   Reply With Quote
Old 06-10-2019, 04:37 PM   #7
Treslocos
Member#: 502940
So my car went to the shop, loose ground touching starter, causing sparks to be seen underneath the car when I tried to start it. Also CAM position sensor went bad again. Suppose the bad ground could have caused this to fail, last one was inatalled 1 year ago. Problem solved.
Old 06-20-2019, 05:48 PM   #8
JerryG
Member#: 393208
2006 Wrx
No, I still haven't figured out the issue. I've swapped out the fuel pressure regulator as well cleaned out the MAF sensor. I still have this issue and it's beyond frustrating.
Old 07-17-2019, 08:46 AM   #9
Kyrocon
Member#: 504346
That sounds like your sparkplugs or maybe a failing injector? I was having a similar issue in my 04 and I replaced the sparkplugs and it was fine and CEL went away.
Kyrocon is offline   Reply With Quote
Old 08-20-2019, 07:23 AM   #10
JerryG
Member#: 393208
2006 Wrx
I have no CEL
