Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 07-05-2019, 01:32 PM   #1
alexise88
Member#: 496777
2011 Impreza WRX STI
Default Passenger window wonít work
My passenger window on the driver side of my 2011 sti wonít work with the passenger controls. If I use the driver controls the passenger window will go up and down. Does anyone have any solutions to this?
Thank you.
alexise88 is offline   Reply With Quote
Old 07-05-2019, 01:52 PM   #2
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Have you tried re-setting the switch? It's also possible the switch went bad from water/rain getting inside.
oichan is offline   Reply With Quote
Old 07-05-2019, 02:15 PM   #3
alexise88
Member#: 496777
How do I reset the switch? Thanks.
Old 07-05-2019, 02:18 PM   #4
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
You would hit the down button and hold for several seconds, your window should roll down. (if not, hit the button in the up position and hold for 10 seconds).
Then once all the way down, hit the button in the up position and continue to hold after the window rolls all the way up for 5 seconds.
Try this on the passenger door control first and verify if it awakens your driver side passenger window switch.
Old 07-05-2019, 04:15 PM   #5
alexise88
Member#: 496777
So the window works when using the driver controls, itís when I use the passenger controls when the passenger window doesnít work.
Old 07-05-2019, 06:37 PM   #6
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
You can test what oichan has suggested using the passenger switch.
Gallo2011 is offline   Reply With Quote
Old 07-08-2019, 05:31 PM   #7
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
same thing happened to me after the vehicle was at a shop.
after some investigating
found that shop did not plug in the driver side control switch pigtail(connector) in all the way. (until the pigtail 'clicks')
did this and both sides worked correctly
AliBenn is offline   Reply With Quote
Old 07-10-2019, 07:39 PM   #8
Aallgire
Member#: 489481
2008 Impreza WRX STI
Lightning red
My rear left was super slow. I found some corrosion, weak connection made it slow
Aallgire is offline   Reply With Quote
Old 07-25-2019, 11:32 PM   #9
Bikelok
Member#: 254851
2002 WRX wagon 5mt
This is for an older model but the principal is the same.
How to fix a window switch
http://forums.nasioc.com/forums/show...php?p=44430449
Bikelok is offline   Reply With Quote
Old 08-21-2019, 11:15 PM   #10
iDaHuy
Member#: 505548
Did you disconnect your battery? If so maybe you have to reset the window limit? Im probably reading your post wrong.
iDaHuy is offline   Reply With Quote
