Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Old 09-04-2019, 05:21 PM   #1
BagRidersJohn
Member#: 372859
2006 WRX Wagon Ltd.
Sedan Wide Body UGM
Default 2010 Forester 2.5i MLS Head Bolt Strangeness
Hey friends,
EDIT - Realize I put "MLS" in the thread title, was going to ask about head gasket but figured that one out. If a mod would kindly remove "MLS" from the threat title that'd be mucho appreciated!
I'm currently rebuilding my wife's new-to-her 2010 Forester that we bought knowing it needed head gasket service, a job I've done a handful of times over the years to the point where its fairly routine for me.
I just pulled off the valve covers and noticed the head bolts are different than I've seen before, having a black coating. I've rebuilt mostly all mid-2000's NA SOHC EJ253 and I'm used to seeing all grey bolts with the center bolts having painted black heads. I decided to look it up and found a service bulletin that explains the change along with an updated torque procedure and learned that these head bolts are only found on 2010 Foresters and 2010/2011 Imprezas which explains why I haven't seen them before. Part numbers are 11095AA170 and 11095AA180.
Now here's the strange part. I noticed is on one side (right hand, passenger side) the "concave" bolts (with a dimpled head, PN 11095AA180) are not in the center; rather they're at the two "back" corners of the head (furthest from the cam pulley). The driver side is "as expected" with the "concave" bolt heads at the center. As far as I'm aware, these heads have never been removed (gaskets were leaking REAL bad and timing belt was severely cracked, mileage about 130k) so this must have been done at the factory ???
The service bulletin notes 'The bolts are interchangeable and can be mixed' but according to the parts diagram on parts.subaru.com (here: https://parts.subaru.com/a/Subaru__/...12-006-01.html) it clearly shows the 180 part number at the center position. I'm planning on reassembling with the 180 bolts in the center unless someone smarter than me chimes in with a reason not to do that.
Please leave "head bolt re-use" discussion out of this thread
I guess while I'm here I'll mention that I'm planning on using 114AA642 for a gasket unless there's a good reason not to.
Thanks for any input regarding the head bolt placement!
BagRidersJohn is offline   Reply With Quote
Old 09-04-2019, 11:13 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Head bolts are fine to reuse, just check to make sure they haven't stretched. Don't let anyone tell you otherwise on these things.
The two oddball bolts typically have a different size washer on them. Not so different that you're likely to notice if you don't look for it.
CosmoTheCat is offline   Reply With Quote
Old 09-06-2019, 07:04 AM   #3
BagRidersJohn
Member#: 372859
2006 WRX Wagon Ltd.
Sedan Wide Body UGM
Thanks, yeah I always reuse them and just liberally oil the threads/under bolt heads/washers and also pour some oil into the holes on the SB, let it sit for a minute, then turn it sideways on the engine stand and let it drain out right before it put the heads on. I found this works best to prevent squeaking as the bolts go in.
I know the dimpled bolts should be in the middle and plan to put them there when I put the heads back on. Its just super weird to me that they're out of place despite the heads having never been removed. I guess it could've been a mistake from the factory, but I'll never know for sure!
