Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 02-06-2003, 01:05 PM   #1
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Default Removing the digital clock housing out of the dash.
the title explains it all, im planning on dropping in a gauge pod where the digital clock housing is up on the dash. Just wondering if theres a proper way into removing it w/o damaging it.
LinuxGuy is offline   Reply With Quote
Old 02-06-2003, 02:01 PM   #2
Droorz77
Member#: 5896
WR Blue
Just pull straight up on it. It has clips that hold it in, give her a dug and it will come right out.
Droorz77 is offline   Reply With Quote
Old 02-06-2003, 02:52 PM   #3
PsiRRizzed247
Member#: 17503
2002 05450x
ride red!
its kinda a pain in the bung! but youll eventually get it
PsiRRizzed247 is offline   Reply With Quote
Old 02-07-2003, 12:50 AM   #4
Killculture
Member#: 28042
The back two clips (windsheild side) are easy to pop out, but the front two are a pain. I took of the AC vent panel and went underneath to help with the front clips. It is kind of a PITA but you'll get it.
Killculture is offline   Reply With Quote
Old 02-07-2003, 05:13 AM   #5
tdxflex
Member#: 13634
definately take the top vents out, you'll be able to see the clips as you try to take it off. cause if you break one of them, it's a pain to put back together. also don't snap in your pod unless it's already painted or whatever you want to finish it with. even harder than the stock one to pull out.
tdxflex is offline   Reply With Quote
Old 02-07-2003, 08:43 AM   #6
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
When I pulled the pod I was afraid to pull too hard because I thought that I would break something. But, to get it out you do have to give it a strong yank and then the clips release. Make sure that you don't drag the clips accross the dash as you are taking it out . I now have some scratches in the top of the dash because I wasn't careful enough. As tdxflex said some of the aftermarket replacement pods such as Defi have rather big stiff plastic retaining clips (not flexible ones like the stock one). On my Defi, I ground off and rounded the "hook" part of the retainers a little because it looked like it would never come out once I put it in. Mine is snug and secure but pulls out easily with a firm yank.
Dale
iceNine is offline   Reply With Quote
Old 02-07-2003, 12:17 PM   #7
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Im planning on reusing the D.C. housing, since all im doing is drilling a few holes in it to fit up a boost gauge, I figured this would be the easiest place to mount it since I can splice into the wires for the clock, and route the vacuum tube easaly to the boost gauge.
Thanks Guys!
Old 02-07-2003, 11:44 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Do what Dale (iceNine) said. I did the same thing (except for the part of jacking up my dash).
Kean is offline   Reply With Quote
how do the rear axles come out of the rear diff? sti-zy wagon Transmission (AT/MT) & Driveline 3 07-29-2008 09:29 PM
Pulled the motor and tranny out of the car saturday. Pictures and Info STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 66 01-23-2008 04:24 PM
The Monkey has snuck out of the trunk! TmT NASIOC Official News, Articles and Polls 28 08-15-2007 02:37 PM
The green bean comes out of the wood work! RS22b Tri-State Area Forum 23 06-19-2005 01:17 PM
My First Sporty Car, the AHoles really come out of the woodwork rally_wannabe Mid Atlantic Impreza Club -- MAIC 11 05-11-2002 04:00 PM
