Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 12-07-2003, 11:02 PM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default Pulled the motor and tranny out of the car saturday. Pictures and Info
On Saturday we pulled my engine and tranny out of the car. I decided to pull the engine out also so I can inspect it and add a few goodies on it. I also suspect that my cam tensioner is bad because of this knocking on my engine. I will be upgrading my fuel system a bit, making a new downpipe, modifying my turbo manifold, and possible adding cams.
Once we got the motor out we pulled the tranny out through the front. We separated the tranny from the engine and pulled parts out separately. We took the tranny out and inspected the center diff. It checks out to be in very good shape. Next we split the case down the center and found out what happened to the tranny and why it would not shift.
The second gear teeth are broken off on both shafts and all of the teeth were stuck behind the shaft were the shift fork slides. This is why i could not go into any other gear. The front diff was also good.
I am going get the STI 6 speed and hope it holds together. Enjoy the pictures.
STEALTH-WRX is offline   Reply With Quote
Old 12-07-2003, 11:17 PM   #2
Blitzkrieg
Member#: 14913
2003 Lock Stock and
2 Smoking Barrels "wrx"
wowzer, its insane to see what power can do to a weak tranny. Hmm ever thought of waiting to see if the Saab version of the wrx comes with a six speed w/out DCC?
BlitZ
Blitzkrieg is online now   Reply With Quote
Old 12-07-2003, 11:22 PM   #3
SJwrx
Member#: 14970
1997 GF8
multi
this was to be expected, since the extent of the modifications... its good to see a few pics here and there.
Did you ever get dyno #'s?
How much work was it to actually get the setup out of the car? Just a lot of unplugging or what?
How was the seperation of the tranny from the engine?
Rich
SJwrx is offline   Reply With Quote
Old 12-07-2003, 11:36 PM   #4
LargeOrangeFont
Member#: 28475
86 RX-7
CTS-V
BLAM
Im sorry I wasnt there to help.
LargeOrangeFont is offline   Reply With Quote
Old 12-08-2003, 12:09 AM   #5
ShotgunTC88
Member#: 30970
Dibs to the dude with the Mechanics gloves!!!!!
Everybody makes fun of me cause I wear em!!
(Mash your hand a couple times...........You will!. )
Get er back together bro!!
Peace
Shotgun
ShotgunTC88 is offline   Reply With Quote
Old 12-08-2003, 12:59 AM   #6
blackie
Member#: 42979
03 wrx
blizzzack stage IV
what power are u making? holy crap!
blackie is offline   Reply With Quote
Old 12-08-2003, 01:06 AM   #7
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
So what's the problem? 2nd gear should be just fine - NIIiiiiiice and quiet now when cruisn, no???
BOOM!!!!!!!!!!!
or was it
SSSSHHhhhhhrrrreeeeeeeeeedddddddddddddd gggggggrrrrrrriiiiiiiinnnnnddddddddd jingingnlgnginginlgnijgingijingg...
CirrusWRX is offline   Reply With Quote
Old 12-08-2003, 01:22 AM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Wooh thats one dead gear....
Glad to see the tear down went well, what are you looking at for cams? some STis?
Good luck!
Old 12-08-2003, 03:09 AM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Shotgun
I think you mean props not "dibs"
nhluhr is offline   Reply With Quote
Old 12-08-2003, 03:52 AM   #10
InfamousDX
Member#: 25413
Man you never stop with that car. You're gonna be happy with that sti 6 speed though.
Old 12-08-2003, 01:13 PM   #11
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
here is some info about the car:
it makes a lot of power.
it hasn't even had a chance to be dyno tested yet.
it was running 17 psi on 91 octane when the gear went, and nick wasn't racing. he was just driving to the store. he stepped on the throttle (not racing or anything) and that's when it happened. the car is way too fast for it's own good. 6 speed should help, although the low gearing won't be good for 1/4 mile racing. good thing it's a daily driver.
although only one gear was stripped, the other gears couldn't be accessed, because all the teeth were at the bottom of the tranny, and they jammed one of the shift forks, so it couldn't go into any other gear. just neutral. once all the pieces were cleared out, it shifts fine. it could be reinstalled into the car right now and all gears except 2 would work fine.
eric m. is offline   Reply With Quote
Old 12-08-2003, 01:16 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Gears often strip like that when driven easily. My second gear did the same thing, nice easy shift to second and all of a sudden it was gone. *shrug*
BTW, what's with the chain around the powdercoated intake manifold?? You know, there are brackets to put chains to on the motor already...
Old 12-08-2003, 01:36 PM   #13
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
that's actually an orange and black rope, not a chain. and the manifold is just painted, not powdercoated. but i think it's going to get painted again anyway, so it's ok.
Old 12-08-2003, 01:40 PM   #14
STEALTH-WRX
Member#: 7822
We didnt have any chain at the time so we used my 3 braid rope. I was waiting for someone to say some thing about it. My intake manifold is paited so its okay if it comes off. I was going to repaint it. The rope is very strong. It has a working load of 278 lbs with one length. I wraped it around 3 times on each side so that should be good for 834 lbs. Plus the breaking strength on them is 3340 lbs each.
As for the gear breaking. I was driving it hard, shifted into second, the wheels spun, as soon as it grabbed, the gear broke. Then the tach went to the floor and I heard some nasty noise.
Old 12-08-2003, 01:44 PM   #15
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
looks like you're at it again. Check out the JUN 272 cams Mine drive fine with 10psi or power. Still waiting on a FMIC
IA Performance is offline   Reply With Quote
Old 12-08-2003, 01:46 PM   #16
STEALTH-WRX
Member#: 7822
rope
Old 12-08-2003, 01:47 PM   #17
STEALTH-WRX
Member#: 7822
I dont know if i want such drastic cams. I was thinking of the 264's or sti 256's. I just want something that will drop in. Will I have to have my shims re-done if i put any cams in?
Old 12-08-2003, 01:48 PM   #18
LargeOrangeFont
Member#: 28475
86 RX-7
CTS-V
Nick... you need a mustang 5.0 throttle body. or lets at least PNP yours That is like drinking coffee through those small stirer straws
Old 12-08-2003, 02:04 PM   #19
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ahhh, rope. I see now.
Yeah, I never have chain either, but my engine crane is as basic as you get. 2x10 across the attic opening with a large tow strap looped over and hanging down, and a come-along to attach through the tow straps to the motor. Lift motor, push car back. Simple, but it works.
Old 12-08-2003, 02:04 PM   #20
STEALTH-WRX
Member#: 7822
sounds good, but what does PNP mean.
Old 12-08-2003, 02:17 PM   #21
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
If you mean "if I change my cams will I have to buy buckets to allow for proper valve clearance?" The answer is yes. Maybe not all 16 (that is, if you are already shimless), but you'll be buying some.
BTW, if you find out where to get these reasonably, let me know....I need 'em also.
n2xlr8n is offline   Reply With Quote
Old 12-08-2003, 02:18 PM   #22
IA Performance
Member#: 25194
Dark Gray
SHIMS? Ah man, come on. Shimless buckets are in need The 272s didn't seem to compromise to much bottom end, but then again I only have stock stis to compare this with :/ 264s would be fun, but in the back of your mind you may always wonder what 272s feel like I know you need new springs with the 272s, but I believe Ron said I can squeeze by with the stock valve springs on 264s. That was stock JDM sti valve springs though. They are an upgrade over the wrx ones. Shoot, I just sold my set last week too. Any who, I may have some JDM Sti v8 cams in a week if you are looking.
Old 12-08-2003, 02:18 PM   #23
LargeOrangeFont
Member#: 28475
86 RX-7
CTS-V
PNP = Port N Polish. All you need to run a 5.0 throttle body is a atapter plate and the ford TPS.
A BBK throttle body is like $189 for a 70mm and $199 for a 75mm from summit.
Old 12-08-2003, 02:24 PM   #24
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Just out of curiousity, what gearset did that used to be in your car?
Templar is offline   Reply With Quote
Old 12-08-2003, 02:26 PM   #25
STEALTH-WRX
Member#: 7822
n2xlr8n:
Currently I dont have the shimless buckets.
East Coast Scooby:
I dont want cams that are too large because I dont want to change too much stuff. Its still a street car and I dont have that much money. Remember that i am still a 22 year old guy in college, and I work alot. With installs and my day job it adds up to 50-60 hours a week of work. I dont want to cheap the car, but i think sti cams or 264's will do the job. What are my options? Money is an issue with my car and I stopped using credit cars about 12 months ago, so it takes alot longer to save money.
LargeOrangeFont:
My throttle body is already ported and polished, along with my intake manifold, and sti injector housings. Also since there is so little room under my hood, if i get a mustang throttlebody and adapter, the throttle body would sit closer to the firewall. Then my air/water intercooler may not fit.
The Attic Buena Park 4th of July Car Show Pictures xknowonex Southern California Impreza Club Forum -- SCIC 15 07-05-2009 04:12 PM
questions on emissions, out of state cars in ca, and law schools legacy2003 Southern California Impreza Club Forum -- SCIC 12 12-31-2006 02:02 AM
How much does the A/C take out of your car? stryfewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-26-2005 06:23 PM
Removing the digital clock housing out of the dash. LinuxGuy Interior & Exterior Modification 7 02-07-2003 11:44 PM
My First Sporty Car, the AHoles really come out of the woodwork rally_wannabe Mid Atlantic Impreza Club -- MAIC 11 05-11-2002 04:00 PM
