Welcome to the North American Subaru Impreza Owners Club Saturday September 26, 2020
Old 08-23-2005, 09:38 PM   #1
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
Default How do I spool up my turbo at the dragstrip?
I've never ever ever drag raced a turbo before.
I've taken my motorcycle to the dragstrip, so I'm somewhat familiar with a manual.
How do I spool up my turbo at the line? do I put it in gear and spool up with the emergency brake? Do I get my boost up with the clutch in?
Do I pop the clutch off the line?
I need help as I am going to the local dragstrip in a month.
Thanks!!
Vampyr is offline   Reply With Quote
Old 08-23-2005, 09:51 PM   #2
kcook
Member#: 78074
2005 STi
stage. rev to 5.5k .. and slip the clutch and ur off
kcook is offline   Reply With Quote
Old 08-23-2005, 10:16 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...start by having at LEAST $2k in the bank for a new tranny....and/or a new clutch....and go from there.
Old 08-23-2005, 10:19 PM   #4
flabele
Member#: 87475
2005 VF-34 / COBB
PSM SILVER ( not pms )
Rev it up and down from 1 to 5 and then slip the clutch really fast at 5,000. Make sure you catch it on the up rev.. Put some extra air in your tires to get them to spin too...And then you might have to buy that new tranny.. good luck.
flabele is offline   Reply With Quote
Old 08-23-2005, 10:20 PM   #5
Davenow
Member#: 23676
He has an STI. The tranny will hold.
And at you suggesting he could replace an STI tranny for 2k.
Old 08-23-2005, 10:21 PM   #6
flabele
Member#: 87475
2005 VF-34 / COBB
Didnt notice u had an sti. Different story i guess...
Old 08-23-2005, 10:22 PM   #7
cronic
Member#: 9749
Actually USDM tranny's are pretty cheap. They can be had for 2-2500.. That is of course just the box.
cronic is offline   Reply With Quote
Old 08-24-2005, 12:17 AM   #8
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Ya dont do like i did and be stupid with the boost turned down and pop the clutch at redline sure it works the first 2 times but the 3rd time when i turned down the boost BPLAAAOPP click click click click. Limped home on 2nd 3rd 4th. When first went out it threw out the snychro to 5th. That range up a nice 2 grand, luckily i didnt pay for it the warranty did. Also its not the best way to get traction, practice on empty smooth streets to get the hang of feathering the clutch, then let out the clutch when youve begun to roll. Your buttometer will let you know when you get a good launch And you wont blow your tranny cause the streets are more slick, so your tires will spin more. But 5 grand is good for a sti. I do mine at 4 cause there is no reason to go any higher in a wrx that dont have the top end
trxdam is offline   Reply With Quote
Old 08-24-2005, 01:00 AM   #9
Airborne Guy
Member#: 68516
2019 YOTA TRD BLK
R.I.P. MasterTuned©
I rev and hold at about 6k, then i feather it and take off. Usually very little tire spin!!
oh and spray the hell out of the I/C sprayer too
Airborne Guy is offline   Reply With Quote
Old 08-24-2005, 01:06 AM   #10
wrxwhat
Member#: 87653
97 Supra / 17 GTR
16 Z06 / 07 STI / 05 Evo
*** u dont have wheelspin? how!? (SARCASM)
wrxwhat is offline   Reply With Quote
Old 08-24-2005, 01:26 AM   #11
bo9877
Member#: 31452
1995 Legacy L FWD
Power Windows & Locks!
The STi tranny should hold, but the axle shafts might not...they can shear off if they get too much power at once. Even in the strongest systems, there is always a weak link somewhere.
bo9877 is offline   Reply With Quote
Old 08-24-2005, 01:49 AM   #12
Carlos_WRX
Member#: 63600
actually ive his car is a stock 2005 sti it should hold alot better then u imagine ive its a 2004 then worry a little more on the axles dont know why but havnt seen a 2005 pop them yet only 2004
Carlos_WRX is offline   Reply With Quote
Old 08-24-2005, 03:58 AM   #13
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Wait until your 5th gear syncro goes....be careful with that shift.
bezerk is offline   Reply With Quote
Old 08-24-2005, 04:11 AM   #14
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
lock the diff 50/50 to launch. that's what really tears up the axles, launching in auto mode.
00Maddog is offline   Reply With Quote
Old 08-24-2005, 06:59 AM   #15
verendia
Member#: 54550
1995 LX
graphite grey
make sure u turn of your a/c and close all ur windows when u run .. i bet u thats y so many cars ran like crap at taht etown event..
verendia is offline   Reply With Quote
Old 08-24-2005, 07:04 AM   #16
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
The AC shuts off the compressor at full throttle and you are not allowed to have any windows open when you go down the strip.
2002WRXSTi is offline   Reply With Quote
Old 08-24-2005, 07:49 AM   #17
jays05
Member#: 78165
05 STI 35r + e85
As mentioned above, pumping the gas (and not just holding a certain rpm at the line) will spool the turbo nicely. I've been playing around on an open downpipe the past couple days, and when revving the engine in the 5000-5500rpm area you can hear that the turbo is already spinning pretty fast. There are a lot of different ways that people launch, I prefer to slip the clutch initially, then once the car is moving I drop the clutch to transfer all the weight to the back. I've cut 60' times as low as 1.66 so I guess this works. DCCD open and all the way to the back is the fastest, but as others have mentioned it is pretty abusive on your rear axles.
jays05 is offline   Reply With Quote
Old 08-24-2005, 11:10 PM   #18
metoo
Member#: 4764
2004 STi sold :(
forizzle
Find where your clutch is just short of engaging. Hold there. Rev to about 3K and hold. When you are ready to go, floor the throttle, as it approaches 6K, slip dump. Get ready for 2nd gear, because it will come up quickly.
metoo is offline   Reply With Quote
Old 08-24-2005, 11:14 PM   #19
Airborne Guy
Member#: 68516
2019 YOTA TRD BLK
R.I.P. MasterTuned©
oh so very true......
Old 08-24-2005, 11:34 PM   #20
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
if you really want to Build Boost on the line get some form of engine management that will do it. AEM or Hydra will allow you to build pretty good boost before your lauch, but you got a STI so its gonna have to be the Hydra.
snwman is offline   Reply With Quote
Old 08-25-2005, 09:50 AM   #21
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Thanks!!
http://www.beergoggles.org/subaru/20...k/MVI_1385.wmv <--- You can always launch off a two-step like the UTEC's launch control system.
Redline8k's '02 bug eye on the inside lane with a v. VII RA-C full driveline swap and an HKS2540 kit.
Doctornick's old school wagon with a v. VII STI full driveline swap with a green.
EDIT: P.S. if anyone wanted to know what a fujitsubo header sounds like, that's the car on the inside on the 2 step.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-25-2005, 09:58 AM   #22
cronic
Member#: 9749
Jorge (RiftsWRX)
www.ProjectWRX.com
Well what did they run?
Old 08-25-2005, 10:19 AM   #23
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Like crap, it was too damn hot and humid out.
Nick's best quarter (Redline8k) was a 12.4 and his best MPH was like 114, and Neal's (DoctorNick) was 12.6 and his best MPH was 109.
It was our midwest shootout day. Stage 2 STI's barely hit 13.2's at best, and the fastest stage 4 Rex hit 13.01.
One of our Rex turned EVO guys BARELY cracked into the 13's with a full exhaust.
It just sucked all around.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-25-2005, 01:54 PM   #24
Timdog1650
Member#: 45516
MY04 STi
If you want to keep your engine stock but setup a 2 step like Jorge said, you can always get an AFC and to put a sh i t ton of fuel in the car at like 75% throttle and 5800 RPM, then as soon as you go 100% throttle the car should pull out of it on like a bar or so of boost and you're off! It takes some tinkering, and some practice two stepping, but it's a LOT of fun and cheaper to pick up a used AFC than buying full engine management if all you want is to launch hard...that's ghetto style 2 step
Timdog1650 is offline   Reply With Quote
how do you hook up a turbo timer?? 92lssleeper Rocky Mountains Impreza Club Forum -- RMIC 9 12-14-2009 09:14 PM
How do I set up my desktop to be all pretty? MPRZIV Off-Topic 10 08-28-2006 04:20 PM
how do i set up my car the best? kkam030 Motorsports 11 07-25-2006 03:49 PM
How do I tell if my turbo legacy has an LSD? MY99 2.5GT Legacy Forum 7 02-08-2005 11:26 PM
how do i put up my car pic in the members club thingy?? VOLTIS5 Newbies & FAQs 3 07-23-2001 05:52 PM
